Author Topic: Using an oscilloscope to view current waveform through a stepper winding  (Read 4006 times)
Offline presse55Topic starter
Hello group,
I wish to analyze the current waveform through the my stepper's windings.
Reason: uneven steps - .  As you can see, the application runs fine, the stepper steps, forwards, reverse, accelerates, etc; just the steps are uneven at low speed.
I will be receiving a Rigol DS1102E shortly. I have no experience with an oscilloscope, and am looking for guidance on viewing the current waveform on this stepper.
The stepper is driven by a Pololu A4988 motor driver with voltage regulators, configured at 16 uSteps/full step;
The stepper’s characteristics:
  • Stepper rated voltage: 12V
  • Stepper rated current: 0.33A
  • Supply voltage: 18VDC, Li Ion battery, floating, ie not ground referenced
  • L=48mH
  • R=32.6ohms
  • f= 10Hz - 100Hz (ie 10 to 100 full cycles of 16uSteps per full step per second)
My questions:
  • I do not have a current probe, so plan to use a shunt resistor in series.  The only technique I have found on the internet involves the use the A-B differential method illustrated here to measure voltage difference between two probes.
    Is there another more appropriate or direct way to plot the current waveform using this scope?
  • For shunt resistor value, my calcs so far if I am correct point to a 1 ohm resistance.
    Does this look right?
Feel free to redirect me to any existing post dealing with this topic.
Thanks in advance for your responses!
Ron
Montreal
PS: I'm a bit of a noob with electronics, but I've been through the phasor representation for this setup.
« Last Edit: September 26, 2018, 05:45:07 pm by presse55 »
Offline MrW0lf
  • Country: ee
    • lab!fyi
Re: Using an oscilloscope to view current waveform through a stepper winding
« Reply #1 on: September 26, 2018, 07:11:59 pm »
This best you can do with 2 ch scope, shunt and floating DUT to see current and voltage. Main thing: Ground clips must be connected  together to same place. 1ohm is fairly large for shunt. I use special 0.1ohm non-inductive max. But in this case might not matter much since this is pretty civilized motor not near-short like brushless outrunners.
« Last Edit: September 26, 2018, 07:14:02 pm by MrW0lf »
The following users thanked this post: threephase
« Reply #2 on: September 26, 2018, 07:35:10 pm »
Cool, thanks for the reply MrW0lf!
I like your suggestion cause that way I'll get to see both voltage and current!
Thanx!
Offline threephase
« Reply #3 on: September 27, 2018, 07:08:14 am »
Good advice MrW0lf :-+
Offline korlatos
« Reply #4 on: September 27, 2018, 03:57:18 pm »
You can easily build a low-cost current probe that covers DC-200kHz range. Please look at the attached application note for details.
