Author Topic: TH2830 vs TH2832  (Read 59149 times)
Offline GnomeZA
Re: TH2830 vs TH2832
« Reply #325 on: January 10, 2024, 09:07:07 am »
Well, that worked great. A nice consistent/smooth fan sound. It's quieter, more efficient, and the buzzing is gone.
My fan holes were 3mm.
I had to severely cut up the rubber grommets from Noctua to fit.
I wasn't down to drill out the holes in the instrument.
Alternatively I could have used some 3mm BHCS to mount them (original screws are far too short)
But I seeing Josh' picture I decided to give the grommets the opportunity.
If I take pure fan/air noise, the Noctua is louder than the original fan IMO.
The original fan had an annoying buzzing which made it far more annoying, but if you ignore that, the pure fan noise "part" of the sound is either same or slightly higher on the Noctua.
Overall I still think the upgrade is worth it, the fan moves a LOT more air and you don't have this annoying buzzing noise constantly going on.
Also Noctua fans are rated for a LOT of hours, it is unlikely the instrument will need a new fan in the next 20 years based on how much I use it.
Noctua is really up there in terms of their fan engineering (quite a few very nice videos about it on YouTube).
Offline KungFuJoshTopic starter
  • TEAS is real.
« Reply #326 on: January 10, 2024, 01:55:46 pm »
I might have used the original screws inserted backwards to pull the metal mounts out of the chassis using an angled plyers. 😉
My stock fan was obviously older than yours, so for me it got quieter. It's comparatively quiet now, but same as you, the consistent sound is much less annoying than the buzz the stock fan had.
Offline GnomeZA
« Reply #327 on: January 10, 2024, 02:07:34 pm »
(slight OT if people want to ignore)
Hello,
I too do not live in the US.
Noctua FANs are made in Austria. I find it usually best to order on their EBay shop.
Very fast and reliable service !
Best Regards,
rudi
Unfortunately getting things from America is just a lot easier than getting things from the EU.
For some reason everything is always more expensive and more work to get from the EU (EU stores are much less helpful with regards to export)
I don't get it because ordering from China and Japan (when things are actually made there), is cheaper unlike the EU situation.
So for example, ordering a Makita tool from Japan is much cheaper than the US.
But if you take Wera tools, they are more expensive ordering it from Germany than the US.
And not just shipping, the actual tool is cheaper from the US :-//
So basically I don't even bothering checking EU prices anymore.
  • TEAS is real.
« Reply #328 on: January 12, 2024, 09:19:01 pm »
Here's a stock twenty eight thirty fw dated 12/2023. Hopefully we'll have a slightly different model's improved version if our friend @tv84 has some time. 😉
The following users thanked this post: GnomeZA
Offline GnomeZA
« Reply #329 on: January 12, 2024, 09:25:54 pm »
Wow that is newer than even the one I got with my meter.
Have you tried it yet?
Which meter branding does it have?
How on earth did you get this?  ;D
Any chance you could do some testing on that baby?
  • TEAS is real.
« Reply #330 on: January 12, 2024, 09:32:09 pm »
It's installed, and it has the ST branding on it.
The ST people are AWESOME, that's how. That's why when anybody asks, I tell them to get the ST version if they can. The TH people will straight up ignore you until the end of time.
I plan to. 😉
Online tv84
  • Country: pt
« Reply #331 on: January 12, 2024, 10:02:17 pm »
Here, test and report.
Header: 414243446C0B070024951300
Signature: "ABCD"  (MAGIC OK)
Block1 Size:  00070B6C   [00000018-00070B83]
Block1 Checksums: 385C   [00070B84-000743DF]
Block2 Size:  00139524   [000743E0-001AD903]
Block2 Checksums: 9CA9   [001AD904-001B75AC]
Block1 - Checksum is OK!
Block2 - Checksum is OK!
The following users thanked this post: KungFuJosh, Martin72, GnomeZA, lownoise
  • TEAS is real.
« Reply #332 on: January 12, 2024, 10:24:37 pm »
You're awesome, thank you!!
Flashing went fine, and I'm happy to see I can do 100Ω DCR test now. I'll let it warm up, and then I'll do a full test with my test board.
Thanks!
« Last Edit: January 12, 2024, 10:27:40 pm by KungFuJosh »
The following users thanked this post: tv84, Martin72, lownoise
  • TEAS is real.
« Reply #333 on: January 13, 2024, 02:00:09 am »
Well, looks like things are better than they were for sure. This certainly appears to be the best firmware yet.
The bigger issues like 100Ω DCR and 100kΩ at 200kHz both look better.
The ~700mH inductor looks better than it was, but it still appears to be too far of a jump between those frequencies.
Results attached.
The following users thanked this post: Martin72, GnomeZA
Offline GnomeZA
« Reply #334 on: January 13, 2024, 11:26:12 am »
All the results in that document look well within tolerance.  Very promising!
Ah you mean its inductance looks completely different between 1kHz and 10kHz?
With inductors and changing frequency like that, I would expect some inductors to behave in unexpected ways.
So I'm not completely sure whether to think this is a meter/calibration issue or more data needed.
Don't get me wrong, I'm not writing this off, just trying to think through it in my head.
All of this said, the results still look incredible!
  • TEAS is real.
« Reply #335 on: January 13, 2024, 04:41:26 pm »
Yeah, I don't understand how they work well enough to speculate on that, but referring back to my previous test when I used the Shannon ST42 tweezers for reference:
The different for the ST42 in those two ranges was 37mH, but for the 2830 it was a difference of 150mH. Now the difference is only 100mH, which is still a bit much by comparison. Maybe somebody else has an excuse for it. 😉
Yes, I'm very happy with the improvements now. I'd say it's stable enough to be more trustworthy than any of their previous firmwares.
100KΩ at 100 and 200kHz is still very slightly out of spec, but not as bad as previously. I may test with a different fixture to see if that improves the accuracy in those ranges.
Online Martin72
  • Testfield Technician
« Reply #336 on: January 13, 2024, 05:05:52 pm »
Results attached.
Great work man, and this makes me laugh:
 :-DD :-+
(Kierkegaard)
Offline GnomeZA
« Reply #337 on: January 13, 2024, 05:40:45 pm »
I've made the switch on my meter to this firmware.
Thanks again @tv84 and also for the verification @KungFuJosh
  • TEAS is real.
« Reply #338 on: January 13, 2024, 11:06:55 pm »
Results attached.
 :-DD :-+
Me too 🤣
I'd love to know how though. Putting D on the screen isn't difficult, but I have no idea how to cycle through those ranges. Maybe they're based on the impedance range option? I dunno.
Online Martin72
« Reply #339 on: January 13, 2024, 11:13:21 pm »
This cannot be recorded in this way either; it is a calculated variable that only "works once", for example.
You had intended 1nF/1kHz for this, then you only get one value, namely the value for 1kHz.
In your next table, I would not include this as a range to be tested.
(Kierkegaard)
  • TEAS is real.
« Reply #340 on: January 13, 2024, 11:28:01 pm »
I copied the note from the cal cert that was shared:
Online Martin72
« Reply #341 on: January 13, 2024, 11:43:52 pm »
Ok,
Then I have to say it the way you wrote it in your table. ;D
It may also mean something other than the DF that comes to mind.
Edit:
Ah, this could be different 10nF caps...
« Last Edit: January 13, 2024, 11:45:56 pm by Martin72 »
(Kierkegaard)
  • TEAS is real.
« Reply #342 on: January 13, 2024, 11:52:07 pm »
Ok,
Edit:
I still have no idea how to test it. 😉
Online Martin72
« Reply #343 on: January 14, 2024, 12:08:44 am »
It can only be that capacitors with different dissipation factors but the same capacitance have been used.
This is because the frequency and capacitance are the same for all ranges (10nF/1kHz).
But now find the right capacitors for it...
Or the different losses were created "artificially".
Tonghui should know.
(Kierkegaard)
  • TEAS is real.
« Reply #344 on: January 14, 2024, 12:38:16 am »
🤣🤣🤣 They should, but if they do, they'll never tell me. They're terrible.
I sent my results to my ST contact. If he knows, he might tell me.
Online Martin72
« Reply #345 on: January 14, 2024, 12:43:43 am »
Please report then.
Same here with Hioki, East Tester... :P
(Kierkegaard)
  • TEAS is real.
« Reply #346 on: January 14, 2024, 12:47:46 am »
Please report then.
Even Hioki? Is it cause of it being an older model? That's disappointing. Hioki at least has firmware and stuff available on their website. Tonghui is douchebags about it to everybody. It's tedious to get anything from them, and certainly nothing has been available on their website.
Online Martin72
« Reply #347 on: January 14, 2024, 01:09:00 am »
This is something I hadn't even posted here in the forum, I actually got a direct response from hioki earlier this year, probably because I contacted them with my company address this time.
Previously the distributors said there was nothing for my LCR because support was discontinued in 2015.
Now Hioki themselves had replied to me and written that they don't release anything to the public.
At least they are honest.
Tonghui and East Tester lie to you directly and say they have nothing.
(Kierkegaard)
  • TEAS is real.
« Reply #348 on: January 14, 2024, 01:13:35 am »
Yup. Tonghui told ST their newest fw was 2021. Then I sent ST a photo of Gnome's newer firmware version. After that is when TH gave ST the 2023 fw. I dunno if that's correlation or causation, but it's certainly interesting...and ridiculous.
Online Martin72
« Reply #349 on: January 17, 2024, 11:54:43 pm »
"Today" I got the new firmware for our ST2830 from Sourcetronic (the guy asked me if I knew about the new firmware through a certain "Josh"...  ;) ).
I then asked again what exactly had been changed, the question was passed on and I may get an answer soon (which I will then post here).
This is interesting because I have to pay attention to the calibration.
(Kierkegaard)
