Author Topic: TH2830 vs TH2832  (Read 55799 times)
Offline GnomeZA
Re: TH2830 vs TH2832
« Reply #350 on: January 18, 2024, 12:27:32 pm »
"Today" I got the new firmware for our ST2830 from Sourcetronic (the guy asked me if I knew about the new firmware through a certain "Josh"...  ;) ).
I then asked again what exactly had been changed, the question was passed on and I may get an answer soon (which I will then post here).
This is interesting because I have to pay attention to the calibration.
Any chance you could also share this ST2830 firmware Martin?
I think having both is not per-se a bad thing
Online Martin72
  • Testfield Technician
« Reply #351 on: January 18, 2024, 02:23:50 pm »
No problem - tomorrow..
(Kierkegaard)
The following users thanked this post: GnomeZA
Online Martin72
« Reply #352 on: January 24, 2024, 06:11:33 pm »
(Kierkegaard)
The following users thanked this post: KungFuJosh, GnomeZA
Offline KungFuJoshTopic starter
  • TEAS is real.
« Reply #353 on: January 25, 2024, 01:36:26 am »
One of my contacts at Sourcetronic was kind enough to share how to do the Dissipation Factor test. He said:
For the D test, Cs-D fundamentally has the same information as Cs-Rs, as the loss factor is directly connected to the ESR Rs.
That also means that you can fake the D by putting actual resistors in series to the capacitor, and you get different sizes of D depending on the resistance you put up.
So I tried it out, and it works. I threw different value resistors in series, and it gave DF values similar to what was expected using math (eww, gross)...just kidding, I used a calculator. 🤣
Measured Rs of the cap was about 29Ω at 1kHz. So using some standard R values, I can do something like this:
29Ω = 0.00018 (cap only)
79Ω = 0.00049 (29Ω + 50Ω)
162Ω = 0.00101 (29Ω + 133Ω)
797Ω = 0.00506 (29Ω + 768Ω)
1609Ω = 0.01010 (29Ω + 1.58k)
16029Ω = 0.10071 (29Ω + 16k)
160029Ω = 1.00530 (29Ω + 160k)
I'm sure those numbers aren't perfectly accurate, but they should be close enough to test it on a new test board. 😉
Thanks,
Josh
PS. Abbreviating Dissipation or Dissipation Factor as just D, leaves some hilarious statements out of context.
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
  • TEAS is real.
« Reply #354 on: July 14, 2024, 02:51:32 pm »
Here's an update on the Dissipation Factor test values.
Tested at 1kHz:
1nF cap (no series resistor) -> 0.00010
50Ω (actually 49.9) -> 0.00050
133Ω -> 0.00100
768Ω -> 0.00500
1.58 kΩ -> 0.01000
16 kΩ -> 0.10000
160 kΩ -> 1.00000
Those values are pretty spot on for the cap I used. I used Panasonic 0.1% 25ppm SMT resistors.
Thanks,
Josh
