Author Topic: Deek-Robot MiNi DC Power  (Read 1964 times)
Offline PluscrafterTopic starter
  • Somewere on earth
« on: November 30, 2018, 06:03:24 pm »
 Has anybody experience with the Deek-Robot MiNi DC Power? And how it will behave on a short circuit?
Offline Fungus
Re: Deek-Robot MiNi DC Power
« Reply #1 on: November 30, 2018, 06:17:19 pm »
No idea, but the Deek web page says: "max. 2A load with short circuit protection."
http://www.deek-robot.com/productShow.asp?id=18
Offline tsman
« Reply #2 on: December 01, 2018, 12:50:41 am »
There is a comprehensive review at https://www.voltlog.com/voltlog-120-mini-dc-power-supply-review/
Good points are that it is quite compact, nice looking case and capable of the rated output. Bad points are that the output is quite noisy, no accessible current limit adjustment, silk screen is wrong and they've made a mistake during construction of that unit which means the 5V output current reading is 1/10th the actual value.
The XLSEMI XL4005 is what is providing the short circuit protection so dig into the datasheet for that if you need more information.
If you can get a correctly assembled one and it is cheap then probably okay for basic usage but beware that noisy output.
