Author Topic: Test repeatability formula  (Read 1389 times)
Offline DavidDLCTopic starter
« on: September 09, 2015, 03:13:53 pm »
I need to do a tester repeatability.
Wikipedia says:
Repeatability or test–retest reliability is the variation in measurements taken by a single person or instrument on the same item, under the same conditions, and in a short period of time
But there is no formula nor targets.
Does anybody have the formula and targets for it ?
David.
Offline Neilm
Re: Test repeatability formula
« Reply #1 on: September 09, 2015, 06:27:32 pm »
This depends on what you are testing. For example, a multi-meter measuring a resistor should be very repeatable - within a digit. However, I did read an international standard on testing transformer oil that says if you get within about 7% for reputability it is doing good.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline tggzzz
« Reply #2 on: September 09, 2015, 09:37:28 pm »
Wikipedia says:
David.
Depends on what the specific situation requires.
I know of one piece of test equipment that was accurate to 0.1dB (of attenuation) but had a stability and repeatability of 0.001dB. Since the requirement was to measure changes in attenuation, the absolute accuracy was relatively unimportant.
