Author Topic: Test equipment is a disease...  (Read 2808 times)
Offline asis
  • Country: ru
Re: Test equipment is a disease...
« Reply #50 on: July 19, 2024, 07:39:39 am »
But have you connected all the ports in series yet? :)
.... and when you run out of wall sockets, you start rushing around - where to plug...
And, you run into major troubles that can arise even due to the lack of contact in the grounding pin.
« Reply #51 on: July 19, 2024, 02:25:06 pm »
If I connected all mine together in series, including voltage sources, it'd be up around 5kV. Probably not a great idea...
Offline Fungus
« Reply #52 on: July 19, 2024, 02:35:48 pm »
Offline Martin72
  • Testfield Technician
« Reply #53 on: July 19, 2024, 02:45:58 pm »
When you consider that anyone can call something like this, no matter how old or whether experienced/inexperienced... :palm:
But at least the gene pool is kept in balance.
(Kierkegaard)
Offline Fungus
« Reply #54 on: July 19, 2024, 02:57:25 pm »
How many amps?
Online KungFuJosh
  • TEAS is real.
« Reply #55 on: July 19, 2024, 04:00:24 pm »
Did the guy not figure out that he very likely internally shorted the cap?
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
Offline tggzzz
« Reply #56 on: July 19, 2024, 04:01:18 pm »
My single largest working PSU is 1kV 250W, a nicely limited electrophoresis PSU. Unfortunately the output is unacceptably noisy for my purposes, so I must get back to finding a way to reduce that noise.
« Reply #57 on: July 20, 2024, 01:46:05 pm »
How many amps?
Going on the principle that the lowest current output is the limiting factor, I think 8mA, which is the maximum output of my LKB 2197 at 2.5kV, iirc (I don't use it very often).
