And with that, I will now add my own TRW Swap Meet find!
Hot on the heels of buying an HP-3400A on ebay for $77+tax recently (in "it worked 20 years ago" condition), I came upon two HP-3400A meters at the TRW swap meet. They looked much newer than the one I just got, as they were not yellowed and had the modern "IEC" power connector. Serial numbers only a few hundred apart.
The seller wanted $30 each (not bad considering I've seen them sell around $300...) and for whatever reason I asked for $50 for the pair. She couldn't seem to get a hold of her husband on the phone so I just paid the $60. But a few minutes later, he showed up, and she made him agree and gave me back the $10. I felt ...almost... bad about it.
Got home with the meters. The switches needed a spray. One meter works very well, just a half dB off from what I think is correct. The other is 3dB down (suspicious indeed) and sometimes exhibits syndromes of neurological disorders (random meter movement here and there). Likely a bad cap on the meter movements. The 3dB down thing could be a bad contact on the step attenuator knob perhaps. I will see. The nuvistor board was also dislodged from its holders, so maybe this unit saw some action. There's a bit of dust too, although not much really.
But let me tell you. The good one (on the right in the photos), when I opened it up to clean it, it was SO clean. You could eat your dinner off it. Not a scratch anywhere, no dust, no sticky goo, capacitors looking NICE. Wires bent like some sociopath put it together with perfect right angles. You could not ask for a more clean example of HP construction. Or maybe I've been buying too much old yellow HP... I think with a quick cal it will be good to go. Even the foam was intact around the nuvistor board, although it did shed some when I touched it.
The swap meet had all sorts of great test gear. I also scored rolls of Kapton tape for $1.50 each, loads of heat shrink tubing (including some low-outgassing "flight" tubing, didn't ask where that came from), a GHz-friendly directional coupler ($10), probably more I'm forgetting. I saw some programmable HP power supplies and loads of scopes and analyzers, just too bad I already have that sort of thing otherwise I could have dumped even more money. Additionally, I sold my IC-736 (the subject of many videos on my youtube channel) for $350 and my Yeasu VHF HT ($15). Prices might seem low but I'm just here to have fun, what can I say.
Now, what to do with the meters... I could get all three that I suddenly poses all cleaned up and calibrated (as well as I can), and then pick one to keep and two to sell. I should easily make what I put in to them, and that's all I need to do.
Oh, and my HP-3490A arrived. After it blew out a RIFA cap (flames like a torch, loud noise, awful smell, you know it), it's working fine. I am considering adding a true RMS circuit of some kind or another inside it, because.. why have a 6 digit meter without actually reading RMS... We can do this, it's 2023, there's dozens of ways to measure RMS and it'll be fun to experiment. This thing has the most satisfying switches and rolling unit selector you've ever felt. Click!
