![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1703278;image)
OK I have ordered the caps I need to complete the PSU recap of the 7603 scope. The cap situation is still not resolved, could hardly buy what I wanted or needed, had to make do with I could find. Now is not the best of times to be picky about electronic components
![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif)
35 Euros for just a handful of caps... add the 2 I just fitted yesterday, I am already in the 40+ Euros just to recap the PSU of this thing.. which is what I paid for it IIRC. Recapping old TE is expensive (and usually a pain in the butt to do as well). One more reason for which I will slow down on boat anchor harvesting, and will be very picky about which ones in my stock, will get to be restored, and which ones will be for parts...
I most definitely won't be restoring my 25/30 hollow state Tek scopes, that's for sure...
Anyway, today I switched to the Tek RM17. I bought it 9 months ago and since that time it's been waiting for caps too.
Had problems with the vertical pre-amp, all of which were due to a 3 section can.
I meant to replace it with a little adapter PCB, so I had pulled the can out of the scope back then, to take measurements... but never got round to doing it, begin overwhelmed by the details, that I wanted to get right the first time. The devil is always is always in the details. No, I won buy ready made ones from Ebay, I don't like them and way too expensive for what it is. I want to design my own the way I want them.
Anyway, so no PCB for now, but still wanted to button up the scope. So instead I thought I would reuse the old can, this way the new caps would still mount on the existing cap base/socket, problem solved. I never messed with can caps, so I thought cool, good excuse to do my first one. I saw it open centimeter above its base, so as to be sure to get the seal intact.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1703284;image)
Inside it's not as messy as I was told... it's all dry as a bone.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1703290;image)
I carefully unrolled the foils to get to the metal plates/pins without damaging them.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1703302;image)
The 3 new caps fit peeeerfectly inside the base, could not be happier....
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1703314;image)
.....I thought. Except I could not solder the leads of the new caps to the inner terminals of the old can.... solder just WILL NOT STICK !
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
No matter what.
Geez... but I thought people DID restuff these old cans eh ?! So how do they do ?!
Maybe they remove the old terminals, leaving holes in the seal, and just thread the leads of the new caps through these holes... yeah maybe. Could have done that... but didn't think of it. Next time maybe.
So instead I soldered them directly to the wires that used to go to the can. The new caps are so small and light, no big deal. Put a bit of heatshrink tubing to cover the solder joint on the hot lead of the 3 caps.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1703320;image)
Then to connect the common ground / negative leads, lucky me, right next to the old can was power resistor, mounted vertically on the chassis, solidly anchored. One of it's terminals was connected to ground via a tab, a tab which had an extra hole, waiting for me to shove all 3 leads of my caps through it ! So the 3 caps are firmly held in place, perfectly safe, they are going nowhere. Looks good enough to me.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1703326;image)
Might fit a PCB in 20 years when I finally design one, but for now it's good enough.
Gave it a quick test ride to make sure it still worked.. it does, but I noticed a new problem. Sitting for 9 months is never good for any old TE eh...
Video of the problem below.
It looks like a problem in the horizontal section this time. The trace does not go all the way to the right edge of the graticule. IT depends on the sweep speed setting. Up to about about 10ms/DIV, the trace goes up to about 7.5 DIV. Then from that point, as you keep cranking the speed up, the trace extends a bit more to the right, each time you crank the knob one step. Once you reach 50µs/ DIV it almost extends all the way to the right edge.
When you set to not extend fully, you can see the right tip of the trace trembling a little bit, it's not rock solid.. and once, all of a sudden it fixed itself and jumped all the way to the right... and a split second later came back to its former shorter self again
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
So it looks like a bad contact somewhere, an intermittent issue..... or a bad cap again. That's one of the reasons I replaced this 3 sections can. Of of the 3 sections was causing horribly noisy signals when using the most sensitive settings of the vertical amp. Looked like a bad contact but was that cap.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
I will try to fix that problem right now if I can, while it's on then bench and while I am waiting for 7603 caps to arrive.
I does not look like an amplifier issue. Looks more like a sweep length issue. So will look at the amplitude of the sawtooth signal first...
