I've been playing around with the Tek J16 Digital Photometer tonight.
One of the standard accessories that was originally supplied with the unit was a 1m extension cable to allow the sensor head to be used somewhat remotely from the main unit.
Taking a look at the internal wiring to the 15-pin connector on top of the unit, I noticed that three of the wires were shielded coax. Hmmm, to preserve signal integrity and minimise crosstalk and induced voltages, I should continue the shielded coax down the extension cable all the way to the other end where the sensor head will connect.
But how to do it? A standard multicore cable won't cut it, as the conductors aren't shielded from each other even if the entire bundle has an outer shield....
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Then it hit me. A 15-conductor cable, of which 3 are individually shielded coax conductors, isolated from the outer shield...
There
IS a cable I can use, a common and cheap cable that can be bought almost anywhere!
It's called a VGA cable!
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
15 conductors, 3 of which are individually shielded and isolated coax (For the RGB signal). We are only dealing with DC here too, so cable impedance is meaningless. Perfect!
So, I bought one from Akihabara, along with some 15-pin D-connectors and shells.
I cut off the VGA connectors and wired it all together in straight-through configuration. Perfect!
I also wanted to make a calibration fixture. The connections are described in the manual and consist of a D-size battery, a jumper link to short two pins together, and a connection to a multimeter to allow for the adjustment of the internal DVM.
The appropriate parts were also purchased from Akihabara and assembled into the little fixture you can see plugged into the top of the unit in the pic below.
So after all of that, I officially declare tonights test equipment activities a complete success.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
