Haul from the Rugby hamfest. Although I saw him, I think I got there before the amorphous blob that snarfed the HP9100A at last week's FRARS rally.
The Advance [EDIT:
OFS2A] OFS2B off-air frequency standard looks like a dead loss. No manual available. The output never syncs, and since there are only two ICs (both 7490), it looks like it presumes Droitwich is at the original 200kHz rather than the current 198kHz. I'll either flip it at a hamfest, or use the mechanics and replace the PLL etc with something of my own design.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1571848)
The HP654A works reasonably, but could probably do with a little tweaking and switch cleaning. I'm in two minds whether to do that, or to simply flip it "as is", using photos showing intact cal stickers. I haven't seen a sig gen with several output impedances from 50ohm to 600ohms, with switched knobs marked in dBm. Apart from that, I suspect its internals are the same as my HP651B, but with a lower peak output voltage. The output level is easily tweaked, and appears to be within 1sB of where it should be.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1571842)
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1571836)
The Tek 468 basically works and has the feel of a Tek 465B. Ch2 is finicky in the usual ways: it can work as advertised, but touch the attenuator controls and the amplitude and frequency response goes to hell. Ought to be a standard cleaning operation, but accessing the attenuators is complicated by the wart on top. No, I don't like DM44 variants! I do have a Tek465B which could probably fuflill its remaining function as a parts mule for attenuator components.
The voltage/time measurement only operates on digitised signals, not on the analogue waveforms with DM44 variants. The digitiser is clearly "early" and experimental". 40ns sampling interval, <<100MHz, and a choice of sine or pulse reconstruction filters. The method of moving the cursors is odd, but works well. Haven't assessed the "envelope" mode. Nice to see a "save waveform" mode.
Standard clean 3.5ns risetime without digitiser
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1571812)
Gibbs effect with "sine" reconstruction filter, and asymmetry with "pulse" reconstruction filter. Time is measured between blobs on leading edges.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1571818)
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1571824)
The Pico TA041 isolating differential probe works nicely up to 25MHz. I'm in two minds whether to flip it or keep it with my other similar probe. The Pico has the advantage of not being /20 or /200, and being battery operated, but the disadvantage of fixed heavy duty probes.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1571830)
