This afternoon I've been sorting out two of the problems with the Systron Donner 6016 counter, which I got at a local radio sale earlier this year.
First was easy, one display choob was stuck showing two & a decimal point (not used in this position at all), I borrowed it's neighbour last week to confirm the decoder/driver IC was fine, the bad choob has internal shorts. Yesterday I had located a board with some spares, fitted one of these and that cured it.
Second was the broken off reset switch, I had already found a similar style button cap some time ago, from a very dead Farnell sig gen.
Next was disassembly of the sides, front panel, BNC & control, to get to the switches, the lower switch bank & BNC input board had to moved out of the way, to access the top switch bar.
Top side required removal of the display counter board & BCD output board, to get to the rear of the mainboard for soldering.
With the front panel trim removed I noticed a hidden switch, this is the auto switch in the 6057 counter, in the 6016 it is cut off flush where the button would attach. I did try this switch with the counter partially reassembled and it does nothing, must be other bits missing on the plug-in boards.
Now I had the switch removed I had to search my spares for a replacement, I found some Toko-Schadow ones from a Sanyo music centre (that we recycled after we failed to sell complete, this was left with the house when we moved in), the pins were too long, but they are easy to take apart & swap bits over with the broken switch, must be good quality as neither had any tarnished contacts.
Here is the repaired switch installed, still need to file the button down.
With the counter mostly reassembled I wanted to check the some transformer connections, the diagrams for the 6016 show a 6.3Vac winding (this is used in the 6057), I found 7Vac-ish on the display board and checking around the rectifier board, quickly found the other voltages, that are used by the mini-CRT in the 6057, so yes these counters appear to have the exact same transformer fitted.
Bonus picture of the 200MHz input board.
