NIXIE DVM REPAIROK I am motivated, well at the moment anywho.
I decided to resume work on fixing my turd of a Nixie DVM, Rochar type A.1335, for those who remember this thing.
IIRC that will be round 3.
Just powered it up and quick test to see if it's still alive since the last time I worked on it... 2 or 3 months ago ? Can't even remember when that was. A while ago.
Well at power up, nothing on the Nixie, all dead.... then after 4 seconds some light coming out of them, partially lit digits, then eventually it all comes back to life and they are all rocking.
Strange that. Maybe some leaky caps somewhere that makes for this progressive wakening. I don't know.
Once all the Nixies were properly woken up and working, I could see what it was doing, and it's not looking good... it was free running again... which then cured itr self after 5 minutes of warming up... yes that very problem that drove nuts last time, and that I thought (?) I had fixed.... it's back
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
I don't want to lose my sanity just yet, so I won't be looking into that just now.
Instead, my plan of attack is to work on the defective Nixie board, because it's perfectly repeatable, does it hot or cold, and I guess is bound to be easier to troubleshoot.
So I will work on that first, to make some progress on this troublesome meter, while at the same time being kinda relaxed, as I guess it should not be too difficult to diagnose and fix...
So, low hanging fruits first, to boost morale !
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
.... then move on to the more challenging issues...
So what's the problem with that Nixie board ? Well you can see it in the pictures below.
It's the third (starting from the right / LSD) Nixie. It can count only from '0' to '1'. Also, it looks like it fails to overflow, which means it never increments the 4th / last digit next to it, the latter is stuck to displaying '0' as consequence. Swapped board with the other, working meter to figure that out 100%.
So that will be my first activity on the meter... it's 17h15 I will spend a bit of time this evening on it, and maybe an hour or two every evening after work.
A little bit at a time, hopefully I will eventually make progress and fix the thing.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1571068;image)
