Found the restoring video of this thing: it is an HP 150A:
Thanks for posting that, I did watch the first part some time ago and skipped through most of it, as sanding & painting it was not very interesting to me, plus he painted the wrong color.
Watched the other three parts last night, much better
Thank you so much for the link, just like you I had seen only the first episode but got a bit put off by it, now I watched the rest and they where quite good!
They did achieve one other thing for me: I'm totally put off buying a vacuum tube oscilloscope after seeing all that, I would not have the patience to repair such a beast!
And just as mansaxel writes here below another good reason is the electricity prices!
Currently as I'm writing this it's almost at 10SEK or around 90€/$ cents including taxes!!!
At least it has motivated me to setup a Home Assistant module that shuts off my water heater, and come winter when heating will be required the heater too based on hourly electricity rates:
...snip...
Topic discussion: Old TE is energy inefficient. Having large power costs influences the Addiction. Besides, electricity is sort of on-topic. I hope.
It's definitely not a scope for Summer use, but this & many other hollow state TE double as fan heaters, 10MHz is enough for Winter isn't it?
The HP 150A I have, original owner must have been the US Navy, judging by all the labels.
The 6¼A fuse for operation from 115V.
Took some pictures of the HV module, still waiting to be reunited with the scope, still has a couple of mixed dielectric? Sprague black beauties, that should probably be replaced.
The 150AR I have (first picture was taken by the last owner), original owner was N.P.L. , google that & you get National Physical Laboratory, but I can't confirm they were the N.P.L. on the label.
The Tek Museum are looking for a HP 150A for their collection.
https://vintagetek.org/home-2/David
