Then the 35 other scopes is just for fun
ONE OF US! ONE OF US!
As far as needs go, I could probably get away with a 20MHz Hameg and solve all remaining problems with initiative
Actually some times I'm tempted to do that just to be difficult
As far as
needs go... we don't need a lab at all, to begin with ! 99.99999999999% of people don't have one and are perfectly happy in life !
Don't know about the UK, but these old Hameg scopes are plentiful here (I guess due to the geographical proximity with Germany), our local site leboncoiun.fr is flooded with them at all times. Nobody wants them. I have one, It's a 60MHz version, incredible... for many years it was my best and only scope.... my dad gave it to me, when he retired it from his work place.
These days I only use it when I am doing something a bit sketchy and fear I might blow up the scope and don't want to risk my other scopes
It's all discrete off the shelf components I think, so cheap and easy to fix if it blows. Plus it has a component tester, and the attenuators go up to 20V / DIV versus only 5V / DIV for most other scopes I have.
That said it's got its weak points as well... a few years ago a plastic shaft coupler inside, broke/cracked (sweep delay control IIRC) and now IIRC also, the vertical position control on channel one is kaput. mechanical problem again..
But the troublesome part is not easily accessible, it's stuffed deep down a hole IIRC, between two metal plates. Can't reach it easily, so... not using it any more.
I would get rid of it to make space (if just because it's ugly AF), but I can't .... it's a gift, it's sacred. Plus the memories associated with it. When the old man claps out I will be glad to have it as a souvenir.
So.... I think one day I will move my butt and fix the thing.
