![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1557130)
I've got a couple of vintage TE clocks, these were made by a few TE manufacturers for adding timecode to recorder printouts & tape recording. In the case of the HP can also be used to automate the printing, with several selectable rates.
Wowwwwww.... this thing looks the business !!! ![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
Beautiful, I want one as well now ! What do you mean it took you 20 years to find one and it's the only one you have ever seen ?!
Oh well.... ![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Even though HP made so many millions of their TE, some of their old stuff none the less is as rare as hens teeth nowadays.
I am sure you must be very glad you stumbled upon this one ! ![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
If I pay you 20 quid, can I visit your lab for an hour and play with this thing ?! ![Evil >:D](https://www.eevblog.com/forum/Smileys/default/evil.gif)
I found the digital recorder/clock about 9 years ago, took quite some to arrive via slow parcels, from somewhere in Europe, very important it was a 50Hz version. Weight is only 83lbs (37.65kg) according to the book.
And yes I've not seen another complete recorder/clock combo since, come to think of it haven't seen any of these large digital recorders (on their own) for many years now. Have seen a couple of the clocks on their own, think one was on youtube.
You might have to wait a while before you can play with it, still need to move to somewhere I can set up a proper lab to work on my boat anchor size TE, the tiny room in my Dads workshop is not big enough.
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
Another problem the recorder part is completely seized up, large motor is much louder than any other TE fan here. On the plus side it uses standard size paper & typewriter ribbon.
The PSU that runs the electromechanical clock, also runs a bunch of vacuum bulbs (comparator circuits), this also runs part of the counter or voltmeter it would connect to, via changeover relay in the counter/voltmeter (need to be added too as neither counter has the extra parts fitted). It would be nice to run the clock continuously from a separate supply, with another changeover relay to allow printer use as well.
![Undecided :-\](https://www.eevblog.com/forum/Smileys/default/undecided.gif)
Hey, hey.. You should repurpose those things, as... Nixie clocks!
Wait a sec.........
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
(Needs moar blue LED
My eyes hate blue LEDs, along with cold white ones and any used with excessive brightness.
![ThumbsDown :--](https://www.eevblog.com/forum/Smileys/default/icon_thumbsdown.gif)
The amber plastic filter in front of the tubes would help block the light, from those pesky blue LEDs.
![Azn ^-^](https://www.eevblog.com/forum/Smileys/default/azn.gif)
