Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17742005 times)
Eric-H, onsokumaru and 85 Guests are viewing this topic.
Offline tggzzz
« Reply #127800 on: July 28, 2022, 04:08:03 pm »
Page 5111 AT LAST !
Almost 2AM, geez I can go to bed now  :=\
So here it is, my Tek scope type 5111.
There are two reasonable responses to the preceeding posts:
  • somebody please go back and delete one of their messages. I'd volunteer, but all my posts are worth preserving in a museum
  • this group is going to get really repetitive for a while...
Tggzzz, your page counter is broken, you need to do something about it...maybe call your HA that will try to contact the IT guy who sold you your computer...
He is the IT guy :-DD
By modifying settings in your profile, you can change the number of messages per page 8)
Yes I know, was just poking him  :popcorn:
Meh. Have to try harder than that! I've got a daughter, and am currently babysitting her dog.
Offline tggzzz
« Reply #127801 on: July 28, 2022, 04:16:42 pm »
If the posts are worthy of putting in a museum, does that imply that the poster's proper place is in a museum too? Asking for a friend...
No, that doesn't follow; you've just failed the critical thinking test.
Nonetheless, with bits becoming less functional and fit for purpose, it is beginning to feel that way :(
When daughter asks what I want her to do with my body after death, I tell her I'd be more than happy if she fed me to her dog. We are unconvinced we can find a way to make that legal :(
« Last Edit: July 28, 2022, 04:18:32 pm by tggzzz »
« Reply #127802 on: July 28, 2022, 04:19:46 pm »
Ah, but I passed the test for thinking critically.
« Reply #127803 on: July 28, 2022, 04:26:11 pm »
It looks as if someone has done your bidding for you, it must be the museum quality of your posts that persuaded them I reckon.
Online ch_scr
« Reply #127804 on: July 28, 2022, 04:38:11 pm »
Fitting to the page number, todays star is the EG&G / PAR / Ametek Model 5113 Low-Noise Preamplifier
After the incident the two input dual-gate FET 2N5564 were replaced with parts from Linear Systems and it would amplify small signal AC again - but the overload light was still always lit. Recently a fresh look revealed an huge DC offset and the AD744 opamp as it's likely source.
Today, (how nice!) the replacement arrived and was promptly soldered in place. To my delight, the overload light turned offf! I will have to take a closer look at it to check, if it truly is "like a bought one" now, but I'll sleep good tonight nonetheless ^-^
Over the PCB sits a small shield (look closely, it complains!) and a full size metal tray with two flat 12v lead acid batterys for floating use.
Edit: Now to check, if I can find all the case parts again   :-DD
« Last Edit: July 28, 2022, 04:44:04 pm by ch_scr »
The following users thanked this post: Vince, Cubdriver, med6753, capt bullshot, factory, cyclin_al, syau, AVGresponding, Zoli
Offline Zenith
« Reply #127805 on: July 28, 2022, 04:51:14 pm »
There must be a way to do it. Gunther von Hagens made a name for himself by turning corpses into art.
https://bodyworlds.com/plastination/gunther-von-hagens/
She could argue that the dog devouring your mortal remains was an installation.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #127806 on: July 28, 2022, 04:53:47 pm »
DEEP in the repair queue...
but it fits the page
-Pat
The following users thanked this post: Vince, med6753, mnementh, Specmaster, capt bullshot, bd139, ch_scr, factory, cyclin_al, AVGresponding, m k
Offline factory
« Reply #127807 on: July 28, 2022, 05:07:54 pm »
No, no they are 3 Pin plugs, in Germany they're called "TF Stecker".
https://www.ebay.at/itm/Varianten-Siemens-Halske-TF-Stecker-3-Pol-DIN-41268-9REL-kli-6-V01-SuH-TF/303134412781
I think TF is derived from "Trägerfrequenz", carrier frequency in english. They were (maybe still are?) extensively used in POTS applications.
That is a nice one: TF-to-BNC connector:
https://www.ebay.de/itm/234337742989
That's horrible.
« Reply #127808 on: July 28, 2022, 05:29:42 pm »
Yes, but you aren't Turing-complete unless you're at least half-drunk.  >:D
I, OTOH, need to be considerably more inebriated... :o
Offline factory
« Reply #127809 on: July 28, 2022, 05:31:34 pm »
Random question. Does anyone know what these HP trimmers are? I know they are made by CTS that is all.
Some of the ones in this HP427A are rusty so I’m intending replacing them with something a little more modern. Plan is to find the data sheet and make a mini adapter PCB for a modern Bourns trimmer.
Edit: after much googling I found a datasheet eventually (attached)
The datasheet is saying something about "RoHS compliant". Are those trimpots in your 427A that young?
I think they just got lucky with whatever they made them out of  :-DD
They are pre 1970  ???
Probably wouldn't have rusted if they were plated with a tin/lead mix.  :-//
« Last Edit: July 28, 2022, 05:33:40 pm by factory »
« Reply #127810 on: July 28, 2022, 05:34:20 pm »
That is a nice one: TF-to-BNC connector:      https://www.ebay.de/itm/234337742989
That's horrible.
Meh... add a little 3DP, you can sell it to AudioPhools for gigabux.
or glue it to a pile of gears and call it SteamPunk...   >:D
« Reply #127811 on: July 28, 2022, 05:42:10 pm »
Q: what's 2+2?
Politician: 10 or 1, depending on what I want you to hear.
Poor accountant: 3.99999999
Average accountant: 4
Good accountant: "what do you want it to be?"
So... Pick a number. Any number[1]
[1] for number = 5, 10, 20, 50
Two plus two is five for large values of two.
Everybody knows that.
 ;D
« Reply #127812 on: July 28, 2022, 05:44:29 pm »
That's horrible.
Those who find irony or sarcasm may keep it.   :D
Offline factory
« Reply #127813 on: July 28, 2022, 05:45:39 pm »
OK who deleted a post?
Edit: I agree it, makes no sense whatsoever.  :blah: Screenshot from preloaded pages I read offline at work.
« Last Edit: July 28, 2022, 06:11:25 pm by factory »
« Reply #127814 on: July 28, 2022, 06:01:58 pm »
If you want to assemble something by yourself, those Stäubli (MultiContact) 4mm banana plugs may be useful:
Yes, the idea has occurred to me. Thanks for pointing out a quality alternative!
The following users thanked this post: Vince, Specmaster, ch_scr, factory, mansaxel
« Reply #127816 on: July 28, 2022, 06:09:06 pm »
Much prefer trying to get Ethernet to work though, sounds a lot cooler to me  8)  Plus, I need to figure this stuff out anyway, once I get to buy a second PC to computerize the lab. I will want both computers to access the internet, and be able to share files and resources.
The easiest way is to get a network card with DOS drivers and install it. Then you can set up a FTP server on your Real Computer and install a TCP/IP suite on the DOS machine; those tend to include a FTP client, which is just fine on a LAN like so. Not anywhere else.
This is untested by me, but looks the part, at a very quick glance: mTCP is a set of TCP/IP applications for personal computers running PC-DOS, MS-DOS, FreeDOS, and other flavors of DOS
The DSL modem / broadband gw thingy usually does DHCP, so that needs to be accomodated on the client, unless you want to play rogue.
Offline Vince
« Reply #127817 on: July 28, 2022, 06:29:04 pm »
Wow that's for really ancient computers.... says it runs on MS-DOS2 2.x  :wtf:
Even my Bull Micral 30, mt first computer 30 years ago, with no HDD and a couple 5 1/4" drives was running IIRC, DOS 3.3.
Nope, my GPIB computer is much more recent that this.... Pentium running Win95. So hopefully Win95 will be able to do most of the network stuff on its own, out of the box, and for the stuff it can't do, hopefully there is somewhere some Win95 based, user friendly, easy to use/configure program....
Offline factory
« Reply #127818 on: July 28, 2022, 06:37:39 pm »
They aren't completely useless, I've bought a couple over the years to provide the HP logo, feet and the plastic meter case parts for repairing other HP TE, eg 3400A. I'm sure I've used other bits but can't remember.
The sensors are usually missing because the last user fooked them, they are very easy to ruin.
Trouble is most of the the 435A/Bs listed at the moment, are too expensive to consider as part donors.
The HP432A cost a tenner. I didn't know anything about them - but for a tenner. It would be interesting to find out about. There was a meter movement which might do for one of the 3400As if their meter failed (I think HP used the same 1mA movement in lots of things), screws, there might be other interesting bits.
I had a girlfriend who used to go shopping with her friends and if she hadn't bought anything she felt guilty, so she'd buy a packet of chewing gum or something very cheap, to satisfy the urge. I laughed.
I was at a rally and I hadn't bought anything, so I came away with the HP432A. Maybe I shouldn't have laughed at her.
£10 to £15, unless they came with the sensors, and then you couldn't be sure they were any good.
No the meter parts I meant were the plastic casing, zero adjustor & glass (not the movement), I've had a few delivery victims that got smashed, or were missing parts, the 3400A was just an example of one I used the parts for. The movements in those are individually calibrated to the scale plate, need to carefully clean or mend the flaking scale and scan it at high resolution while it's out.
Meters with a logarithmic meter movement use different case parts & have no mechanical zero adjustment, eg this option H57 3400A, which was one of the worst victims of shit packing by the seller, the 435A/B would be an unsuitable donor in this case.
Forgot to mention you can salvage the power reference from the 435 too. Oh and it's difficult to find these meters for under £20 on ePay, maybe better luck at a Ham sale, but it's rare to find HP stuff at my local ones.
« Last Edit: July 28, 2022, 06:40:50 pm by factory »
Offline Vince
« Reply #127819 on: July 28, 2022, 06:37:50 pm »
Bastards !!  :blah:
The following users thanked this post: Specmaster, bd139, factory, cyclin_al, Zoli
« Reply #127820 on: July 28, 2022, 07:02:06 pm »
-Pat
I especially like the "/div" Sharpie note!  Some more pages before my 5440 is due. Also in the repair queue.
Offline pcprogrammer
« Reply #127821 on: July 28, 2022, 07:04:56 pm »
I always tell the wife that the waste bin is good enough for me. No need to waste money on it. >:D
« Reply #127822 on: July 28, 2022, 07:07:36 pm »
I want one of these interfaces:
http://chrisacorns.computinghistory.org.uk/8bit_Upgrades/Acorn_ANK01_IEEE488IF.html
And then stick one of these in as the host processor:
https://github.com/hoglet67/PiTubeDirect/wiki
That gives me a 274MHz 6502 programmable GPIB host  :-DD
With respect to practicality I’ve designed on paper an 8085 based lab computer based on my old Z80 design and the Intel SDK-85. I’ll probably never get around to building it.
« Reply #127823 on: July 28, 2022, 07:08:27 pm »
Bastards !!  :blah:
Wasn't me, but that is what you get: "play with the bull, you get the horns" :-DD
« Reply #127824 on: July 28, 2022, 07:09:47 pm »
The trimming and joinery for the additional TE equipment display cabinet shelf is done. Coat of stain applied and drying. After that 2 coats of poly then install.
The following users thanked this post: Vince, Cubdriver, BU508A, Specmaster, bd139, ch_scr, grizewald, cyclin_al
