Oh look some TE content
Ok Tek 465B update. Couldn't resist it and have some dead time to burn. Literally burn today. Eish.
So stripped down the 465B and decided to test the pin that was controlling the faulty address line to make sure that it wasn't being shorted to something other than the 5V rail before stuffing a new chip in it. Tested fine. Looks like the chip was a random failure of some sort. I will see if I can crack open the cerdip and have a look at some point at what happened but I lack a suitable vice and microscope (at the moment
To do this, I slipped the leg off something else into the hole and clipped it with the Keysight micrograbbers. They are quite good. Fluke 75 because, well it was already on the desk.
After I was happy I probably wasn't going to blow the investment up immediately, in it went:
The entire unit channel switching was retested and all is good
Showcase shot of course of both working 465's connected to the DG811. They have been put away as they suck up 90W and it's too fucking hot to run them for more than that.
Not visible too well from the picture is the 465B is super crisp compared to the 465. Once I get my probe situation sorted I will check the power supply out on the 465. It may need some filter caps. I have a plan for a new way to solve the capacitor problems in these scopes which I will detail shortly. It involves a simple "module" on one PCB. No individual adapter boards!
Remaining issues are the CH1 attenuator knob on the 465B is on the wrong location clearly because I was drunk when I cleaned it. The slope switch on the 465 delay timebase is broken and they both need new feet. I will sort those issues out when I've moved.
Now I'm going to sit in front of the fan with a pot noodle and beer like a chav
Payment has been sent to the seller as discussed with them on iMessage. Always good to foster good business relations because I'm probably going to need them in the future and I'm sure they need reliable customers too.
