The LeSiglent T3DSO2102 is my big Father's Day present from wife and dad
IIRC it's a SDS2102X with inbuilt 25 MHz AWG and 140 Mpts mem depth. You should be able to improve it to 300 MHz however it probably comes with 100 MHz switchable probes although it has autosense which IIRC will detect 10x and 100x probes.
I had the 300 MHz 4ch model for a few years and have a pile of FW versions for these although you might need some tv84 CFG magic to convert it back to a Siglent.
Oh and mnem, keep your eyes open for the SPL2016 16ch digital probe set but not just in Siglent colors as these also are used by LeCroy, Tek and Rigol and there's also the DIY thread to make a set:
https://www.eevblog.com/forum/testgear/diy-logic-analyzer-probe-and-pods-for-siglent-scopes/
However the OEM sets with the nice 10 way silicon ribbon coax is far superior to anything you can cobble up at home however Defpom did a reasonable job converting a set he got off ePay to fit his SDS2104X Plus.
What's your take on TK's adapter for the HP pods? Yay or nay vs oz2cpu's adapter?
TBH if you can be bothered to cobble something together use the oz2cpu/Defpom method.
Why, because of mwyatt's contribution simulating my measurements to come up with the values of the passives in the networks of the OEM probe.
These things OEM whom as yet I've not found who makes them are damn expensive but don't forget a 20 lot of decent quality grabbers alone will set you back a C note !
Or if you not in a hurry, keep an eye out for one that looks identical but made for LeCroy, Tek or Rigol and a little sleuthing on each of their websites will get you the Pt. # to look for.......then post them in the DIY thread for the benefit of others.
I'm 100% they all have the same OEM and the twin thin silicone 8 way ribbon coax (that's a mouthful ! ) is a thing of beauty and near impossible to emulate unless you got mates in the company where it's made to get offcuts !
That's why Defpom went the route he did so to get something nice for his efforts rather than some cobbled together twisted pair mess.
Last year Siglent were specialing SPL2016 + MSO/LA and AWG/FG licensing with a new SDS2000X Plus for just $ 219 that was one hell of a deal compared to shelling out retail for each.
