If a UPS is boiling a car battery, it would cook an SLA in half the time; the float voltage should be lower, and if it isn't, it's either (1) badly adjusted and/or (2) a POS.
If you deep discharge any lead acid you reduce its life, including so called deep cycle ones, and you do not deep cycle UPS batteries, unless you (a) have a lot of power cuts and also (b) don't do a controlled power down when the mains fails, and just run the UPS until low battery cutoff.
Maybe you have routinely seen One Hung Low brands in tiny UPSs like that, but I can assure you that the kind of places that use proper machines (50kVA and up) would shit a brick if you put crap like that in their battery string.
Yuasa and the like have much better quality lead. I don't care if it does come from the same place, they use the premium line, and the locals use the value brand.
And we are NOT talking about those machines;
I know the difference, man... gimme a fucking break. You're making a straw-man argument here. Completely different class from the ones I serviced regularly, and
I specifically stated that. As soon as I said 1.5-5KVA, I KNOW you knew the difference.Those systems I worked/work on are mostly used used in retail, so aren't going to be the top tier, "failure is not an option" class machines... but even
they are not the same class as this decades-old consumer grade unit from CompUSA.
What those classes of deployment use is irrelevant here.
That is not appropriate technology for this application. That UPS probably came with a PowerSonic or equivalent Chinesium battery, and spending 40-50 bux on a genuine Yuasa "upgrade" is
money wasted in this application.As for the float charge... I think you need to review that. I know from personal experience that a new known good motorcycle or garden tractor battery used in this application will start to boil in a few days or a week; I've tried it on two different occasions.
Shallow-cycle starting batteries do not tolerate constant float-charge the same way that deep-cycle batteries do.I think you'll find the difference is in fact the IR of the battery... but I don't want to start
another shit-flinging match here.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
![Tweak :-/O](https://www.eevblog.com/forum/Smileys/default/smiliey_cal.gif)
