Some time ago, I've purchased a Fluke 8060A(parts only, $42.00 - little expensive). Install new alkaline, turn on - no display. Open up, start checking - why the brand new battery has only 8.2V?
Well, the Gorilla was here, and left two shorts(Gorilla1-2.jpg; red arrow:short on the bottom, continued on the top thru a capacitor pin hole). Removing the shorts, the LCD came back to life; time to start the capacitor replacement.
Oops, more Gorilla footprints: broken LCD bracket(LCD_Support.jpg) and button support(Assembly_Support.jpg), Well, I need to dig out/install the Tools_of_Trade: Dremel, vertical tool stand, 0.5mm Carbide drill.
Glued the parts together with CA(Loctite.jpg) as placeholder, then proceed with the drilling. After drilling, add a drop of CA on the top of the hole, move the wires(0.45mm, leftover from the 10µF replacements) in-out a few times to fill the hole with CA, add a drop of accelerator on the top, then let cure for 24 h.
Replace the caps(surprisingly, no leaks) and the MAC socket, let the PCB and MAC soak in isopropanol for 24 h, short iso rinse, then dry for 24h more. Assembly, test - almost spot on. But since it has a good family to join, I've adjusted a bit...
Anyway, when I will have the time, I will make some tools to properly adjust/calibrate the whole family...
