Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16671963 times)
Neozealaceous and 49 Guests are viewing this topic.
« Reply #122575 on: June 12, 2022, 08:10:55 am »
Since I was on 3rd shift and a contractor I was not aware of field fail data but it is my understanding that a node fail in a Z is an extremely rare event. But there was one instance where a customer engineer fucked up a node install in a pre-announce machine in a Walmart data center that caused an enormous stink. The smell was so bad that all of us techs were given additional training on the proper node removal/install.  :o
« Reply #122576 on: June 12, 2022, 08:16:46 am »
I decided to get in on the action, posting pics of pliers/cutters. Instead of gathering all of them together though, impractical in terms of space, I have done a "contrast and compare", my largest pair next to my smallest, with AA leak tube for scale.
The following users thanked this post: SeanB, Vince, mnementh, Specmaster, ch_scr, cyclin_al
« Reply #122577 on: June 12, 2022, 08:26:21 am »
Well hell...since we're comparing dick sizes I might as well show my prowess too.  :-DD
The following users thanked this post: mnementh, exor, cyclin_al
« Reply #122578 on: June 12, 2022, 09:02:01 am »
Fear not - in what seems like the blink of an eye, you’ll be old and broke, like the rest of us are.   ;)
-Pat
Call me old again and I'll beat you with my cane and run over you with my walker.  :P :-DD
You’ll have to catch me first!!   :P :P :P   ;D
-Pat
Nah, that is so easy, he'll have his career grab you so you can't escape  :-DD
Offline exor
« Reply #122579 on: June 12, 2022, 09:08:42 am »
I almost forgot these more robust ones. And these I mainly use.  ;D
The following users thanked this post: Neomys Sapiens, cyclin_al
Offline m k
« Reply #122580 on: June 12, 2022, 10:09:24 am »
I HATE DIODES !!!!!
Currently trying to identify/sort/organize all my salvaged beefy diodes. Most were pulled from CRT TV's or monitors.... their datasheet says they are "damping" diodes, for CRT Horizontal deflection.
The datasheet will tell you all sorts of things relevant to their intended use case, logical, fair enough, with all sorts of repetitive or non repetitive voltage or current stimuli, BUT they will never tell you the most basics of specs I wanna know for a freaking diode : what is the maximum  DC voltage and current they can sustain !!!   :scared:
I don't care if their diode can do 1,500Volts repetitive at 32.5kHz or 115,567kHz on a square wave with 35.78% duty cycle...... just tell me what freaking DC voltage and current it can handle FFS !!!  :rant:
So basically I have lots of cool beefy diodes but I can't contemplate reusing them because I have no idea what current and voltage they can actually handle, hence I might as well throw them away !!   >:(
I
What package types?
Maybe the name is an omen.
Don't know what "omen" means sorry  :-\
Package is irrelevant, the problem is the datasheet... but here it is anyway. I don't know how it's called, datasheet doesn't say. It's like a TO220 (on the pic as well, for size comparison), but much bigger.
FMQ-G2FS is 1500V/10A and FMQ-G5FMS is the same.
Whole set is over 1000V so that's pretty safe.
Number 5 seems to be among beefier ones so maybe 5A is safe.
Yes I know that of course, I already have that datasheet, hence my original post bitching about it.
Pretty nasty part you've selected.
I'd say that
FM maker
Q IR 0,5 mA
G
5 TO-3PF-2Pin
F 1500V
S
Not much sense.
Lower voltage of D2 file is clearly a fast recovery time point.
So Robert's rules are also clearly all there will be.
BTW,
Back in the day off duty firemen did larger safe migrations.
At the end they all showed their income-tax cards and cost was equal net amount to all.
And so, one more for the slide rule.
Proto is made but can't find it.
Making one sided without a rivet.
- Glue the print to something thick enough.
- Cut all circles.
- Glue outermost ring to something stiff enough.
- Insert other rings, without the glue.
- Done.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-YFE
Offline m k
« Reply #122581 on: June 12, 2022, 10:26:34 am »
Anybody has a picture of Fluke 8860A mainboard MK3870 MCU?
Mask ROM version if possible.
« Reply #122582 on: June 12, 2022, 10:48:54 am »
That bloody Avo lamp has been relisted again|O |O |O
« Reply #122583 on: June 12, 2022, 10:52:45 am »
Then buy it, stick an M80 in it, and blow it to hell.  :-DD
Offline GreyWoolfe
  • NW0LF
« Reply #122584 on: June 12, 2022, 11:39:59 am »
More fun to take it to the range and disintegrate it with .223.
« Reply #122585 on: June 12, 2022, 12:10:00 pm »
Only if the seller is still holding it, then I want to see how good my aim is with a 16mm LMG, after not firing one for a few years. Think finding the Alouette mounting will be the hard part, you tend to need lots of Araldite rapid after use, to put the floor back together. Record was 47kg of Araldite, to fill the holes, and put the seat and other mounts back into the floor.
« Reply #122586 on: June 12, 2022, 01:06:39 pm »
Now I have one question: is it safe to put it below the stack of HP multimeters?
If so that would save a lot of space and would help me appreciate it a little bit more, as it is, I can hardly work in the "work"bench  :-DD
   No it's not safe to stack equipment.  :scared: I'd never stack more than 10 items. I can't reach any higher  :-DD :-DD :-DD
And Murphy guarantees that, no matter what order you stack them in, it will be the one at the bottom that will need to be repaired.   :-DD
-Pat
You just gave me an interesting idea for mechanical or mechatronics design. The StackJack(TM). Sold in sets of four. The solution of a problem or a recipe for desaster?
 :scared:
Already available from your local building supplier. 4 strongboys and support jacks
https://safefence.co.uk/strongboy-lintel-support.html
Used to support brickwork when installing a window or door in an existing wall.
*looks at your stack, then back at the relatively flimsy little strongboy*
You'll want to double up on those. :-DD
Online tggzzz
« Reply #122587 on: June 12, 2022, 02:15:34 pm »
Well, that was a surprisingly good hamfest up in the hills amongst the Cd and Pb mines. I sold some unwanted crap[1] found a new home for some surplus treasures, and didn't buy much.
The IC clips were £5, and the collection of GR-874 adaptors was £10. Both will go straight into the stock cupboard in the fond hope I'll never need to buy either again.
Does anyone know the type of connector shown in the last picture; there's no useful info on the adaptor other than "QRP"
[1] not really; it all worked as designed :)
« Last Edit: June 12, 2022, 02:21:28 pm by tggzzz »
« Reply #122588 on: June 12, 2022, 02:32:37 pm »
More nails in the coffin for EV cars as they currently stand.
Offline vk6zgo
« Reply #122589 on: June 12, 2022, 02:37:46 pm »
I think it is a "C" connector---very much like an "N", but a "bayonet" type.
They used to be relatively common, not so much, anymore.
« Reply #122590 on: June 12, 2022, 02:47:24 pm »
The mail has been delivered.      Verrah naace....   -Pat
Are they in fact brand new...? Those fingerprints all yours...?  :-DD
*goes back to eBay and looks again*
Offline Saskia
« Reply #122591 on: June 12, 2022, 02:48:05 pm »
after blood sweat and tears unloading the 4 pins I brought up north from 600 km away I finally managed to do something productive.
May mansaxel exhibit a slight smile.
For those who can't see the progress:
HostID and MAC recovered. Still needs OS install. After that it should be ready to run.
The following users thanked this post: mnementh, ch_scr, mansaxel, cyclin_al
Offline Mortymore
  • Country: pt
« Reply #122592 on: June 12, 2022, 03:38:58 pm »
My little pliers, cutters and stripper
The following users thanked this post: BU508A, mnementh, exor, Neomys Sapiens, cyclin_al
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #122593 on: June 12, 2022, 03:43:34 pm »
They certainly appear to be.  >:D
-Pat
« Reply #122594 on: June 12, 2022, 03:51:29 pm »
And his conclusion at the end? "I still, on the whole, really like it." And he's thinking of dumping one of his household's fossil fuel cars and getting an additional electric car. So "nail in the coffin" is a serious misrepresentation of what this video actually says.
« Reply #122595 on: June 12, 2022, 03:53:19 pm »
I might, for a laugh, and for old time's sake, dig one of my SPARC machines out of the pile and see if it still boots.
Offline Saskia
« Reply #122596 on: June 12, 2022, 03:57:08 pm »
isn't it about old times ? Preserving the stuff that we grew up with ?
Anyway.
As for EVs: 20 hours of driving while pulling a trailer loaded with about 700 kg going over Eifel, Hunsrück, Taunus, Bergisches Land (translation: up and down the hills, can't call them mountains, but still steep climbs), doing 1600 km (1000 miles) without too many breaks (only for sleeping ...)
I don't think that an EV could have done this. Not without forced stops due to outta juice and a very painful charging experience.
« Reply #122597 on: June 12, 2022, 03:57:57 pm »
Beat me to it, it is indeed a C type. 50R version (75R exist but are rare. Specfic feature of C type is high voltage / peak power handling. Both male and femaile pins are fully insulated when mated unlike N type which has a bout a 3mm air gap. Most common useage of C types are aircaft "L Band" pulse radar systems (IFF / Transponder, DME/TACAN) and nuclear instrumentation like scintillation and proportional probes
The following users thanked this post: mnementh, Neomys Sapiens, cyclin_al, syau
« Reply #122598 on: June 12, 2022, 04:00:05 pm »
How odd, I was digging in a Really Useful Box earlier today and it had an Ultra 10 MB  and PSU in it..
« Reply #122599 on: June 12, 2022, 04:05:29 pm »
   May as well pull up a comfy chair and have a taco... you're fucking doomed. >:D
Oh god... I'm too young (and broke) for this!
Fear not - in what seems like the blink of an eye, you’ll be old and broke, like the rest of us are.   ;)   -Pat
       BWAHAHAHAHA!
That right there is a microcosm of all that is TEA...  ;)
"Sometimes you just wanna go where everybody knows your name..."
« Last Edit: June 12, 2022, 04:08:09 pm by mnementh »
The following users thanked this post: Atomillo
