Hardly a
*mic drop* moment buddy, but a decent set nonetheless.
I have a number of sets of conventional ratchets in all different levels of quality. What we were talking about is
specialty ratchet wrenches and screwdrivers.
The great value of this one is how effing
tiny the head is... and the ultra-fine ratchet with tiny thumbwheel that really works, and the near-zero ratchet drag. All added up, it is a tool that simply does everything
better when working in a confined space.
You can get in
2-3mm away from a corner wall with it, and the depth is... well, however long your 1/4" hex bit is plus 0.5mm. I've cut down the hex shank on a bit with a Dremel to make it another 10-12mm shallower in a few cases...
TL/DR version: When you need it, this thing is a lifesaver.mnem
*witchet-watchet...witchet-watchet...*
