BUMP !
BU ? Anyone ?
Anyone has a datasheet in English I can actually read/use, or are they just regular 723 and I can just download any random 723 datasheet instead of the original Cyrillic one (attached) that I can't read ?
Merci / Thanks / Danke Schôn,
Yours Truly.
Options:
1. Google translate. Czech to English.
2. Assume it's the same as a LM723.
3. Buy some RCA ones instead
Yeah, the jumble of characters that the czech language represents to the uninitiated can be quite intimidating. Sadly, these are not OCR'd so translation is no super-straight-forward.
Option 2 is your best bet here, and if you really have to know a specific parameter(usually, you won't anyway) a few educated guesses and comparisons to a more legible datasheet are the way forward - at least the "symbols" like
Uz,
Ucc etc. are mostly the same, so you'll get by. East-european datasheets of this vintage are
not highly measured and tightly toleranced anyway (they make up for it by having detailed schematics of the IC though!) Tl;dr: Just assume it's a LM723 and go from there.
Edit: Also, all the original "Tesla" datasheet can be had from there:
https://teslakatalog.cz/io.php
