Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17765977 times)
0 Members and 27 Guests are viewing this topic.
« Reply #121250 on: May 30, 2022, 07:32:25 pm »
On the subject of food, this just out of the oven: one tarte tatin. Ingredients: flour, butter, apples, sugar, water, that is all.
(The colour balance is a bit off but I can't be arsed to fix it.)
The following users thanked this post: Vince, BU508A, mnementh, Specmaster, exor, bd139, ch_scr, cyclin_al, Neper
« Reply #121251 on: May 30, 2022, 07:49:12 pm »
Please refrain from posting picture of my sister  :popcorn:
Oh that's cruel.  ;D Ex-wives are fair game but not your sister. Have a heart.  :P :P :-DD
I owe her that one after the elephant's arse comment  :-DD
Are you sure that you aren't just a tad worried that she might just try out one of her veterinary surgical skills on you  :P
« Reply #121252 on: May 30, 2022, 08:16:22 pm »
Looks delicious, a dollop of nice clotted ice cream on top would finish that off a treat.  ;)
Online tggzzz
« Reply #121253 on: May 30, 2022, 08:24:50 pm »
Poor ice cream maybe, but it would be a waste of good ice cream.
Lemon and mint, or parma violet, or blueberry and spiced gin ice cream would not go harmoniously with that!
Offline Neper
« Reply #121254 on: May 30, 2022, 08:28:49 pm »
Good old tarte tatin. You might want to try it with pears instead of apple, for a change.
« Reply #121255 on: May 30, 2022, 08:36:30 pm »
   ...So I've got this neat model of an 3 phase induction motor.
« Last Edit: May 30, 2022, 08:40:18 pm by mnementh »
Online AVGresponding
« Reply #121256 on: May 30, 2022, 08:46:59 pm »
   This is far superior. It measures consistently 2.35 to 2.40 milliohms "plug" to "plug". I tweaked the "plugs" for a gentle fit into a 4mm socket, it works well...
Plus you can stick it in a drill and whisk your omelettes on Sunday morning.  :-DD
Sacrilege! You beat the egg by hand, with a fork or a whisk, never with power tools!
« Reply #121257 on: May 30, 2022, 08:51:15 pm »
Sorry... my drill is variable speed.  >:D
Besides... I'm saving that wrist action for more important stuff.  :-DD
« Reply #121258 on: May 30, 2022, 08:56:49 pm »
I was unhappy with the results I was getting testing the resistance across the banana plugs on that last design, they were very inconsistent, between about 80 microohms and 4 milliohms. I seriously doubt the credibility of the 80 microohms reading, I think I'm getting noise from the TE effect between the plug and wire, and some inconsistent contact also.
So I changed tack, and decided to make a short using only copper:
EDIT: The inductance between plugs measures <20nH, which is basically in the noise as far as this LCR meter is concerned.
Sorry if this is being stupid... why not simply take an oxy-acetylene torch and melt / fuse the 4 copper wires together ? That would make for a reliable and low impedance connection wouldn't it, and no TE effect. Just.. a blob of copper.  :-//
Sure, I could try that. Do you have a spare oxy-acetylene torch I can borrow?
It wouldn't work though. Heating the copper like that would make it oxidise badly. You could try using a flux to stop that happening of course, but that would introduce more chemicals to the mix, no problem if you're welding, but likely very problematic in this use case. Not to mention what the heat cycling is likely to do to the electrical properties of the piece.
« Reply #121259 on: May 30, 2022, 08:58:03 pm »
The speed is irrelevant. What is relevant is the loss of feel for the stiffness of the mix.
Offline Vince
« Reply #121260 on: May 30, 2022, 09:08:15 pm »
It wouldn't work though. Heating the copper like that would make it oxidize badly. You could try using a flux to stop that happening of course, but that would introduce more chemicals to the mix, no problem if you're welding, but likely very problematic in this use case. Not to mention what the heat cycling is likely to do to the electrical properties of the piece.
I don't have a torch because I don't have a garage, but as soon as the garage is built my old man will give all his tools, so the oxy-acetylene gear will be part of it  ;D
Oxidization hmmm... would that not be limited to the surface of the blob ? Was hoping the core of the blob would still be pure copper. OK well, too bad uh... so TIG welding with a shielding gas it is then ! >:D
OK, if you don't have a torch, you probably don't have a MIG never mind a TIG.... back to square one... I am trying my best ! :-DD
So get a MIG with a a tank of gas so that next time you are better prepared ! >:D
You live in an apartment, no garage/workshop ? OK I give up ! >:D
Looking at you picture, I am not sure the crimp is doing much at all does it ? The wires are twisted over such a long distance that I guess the total contact area between them is what makes for the good connection rather than the crimp at the very end ?  I bet if you just remove/cut crimp, the shunt would still measure just as good ! >:D
« Last Edit: May 30, 2022, 09:11:18 pm by Vince »
« Reply #121261 on: May 30, 2022, 09:10:26 pm »
I notice you're not disputing the statement... only exacting revenge.  :-DD
Bring it; I already know the shadow of my arse weighs 20 lbs... >:D
Not in the least bit.  >:D
   "Watch out! It is coming at you!!!"
« Reply #121262 on: May 30, 2022, 09:13:38 pm »
My mix gets plenty stiff... with or without power tools.  >:D
Besides... it's just omelette. Not crepe or something critical like that. ;)
« Last Edit: May 30, 2022, 09:15:22 pm by mnementh »
Offline capt bullshot
« Reply #121263 on: May 30, 2022, 09:17:38 pm »
The following users thanked this post: mnementh, DC1MC, mansaxel, cyclin_al
« Reply #121264 on: May 30, 2022, 09:24:06 pm »
Ok 3465A is now fixed. It was a leaky clamp diode. Would have never found it if the diode didn't fall to bits  :-DD
2N4117A subbed in as a diode connected FET as suggested by both HPAK and EEVblog forum members. Works perfectly, clamp works too.
Did DC and ohms cal. I don't have any test cables (  ::) ) to do the AC cal yet.
Will update the other thread and HPAK group now :)
The following users thanked this post: xrunner, Vince, BU508A, med6753, mnementh, Specmaster, ch_scr, cyclin_al, syau
Offline Vince
« Reply #121265 on: May 30, 2022, 09:25:12 pm »
Mine is much cheaper, and much better credentials, sorry  8)
... and in search of a good home currently...
The following users thanked this post: mnementh, capt bullshot, bd139, cyclin_al
« Reply #121266 on: May 30, 2022, 09:36:45 pm »
Get a proper one:
Gonna be really hard to make it fly with that one.  :-DD
The little one is already overkill by a factor of about 20, at least from your power readings. No idea what the draw would be like once you up the frequency tho. :o
« Reply #121267 on: May 30, 2022, 09:44:12 pm »
It did! (Although it wasn't clotted cream ice cream, just plain old vanilla Hagen-Das.)
« Reply #121268 on: May 30, 2022, 09:53:25 pm »
I have, and have to agree that they make a great tarte tatin. Peaches is good too. It was apples this time because I wanted to enjoy the last of the locally grown (Kent) apples before the season switches to almost all imported apples.
I'm actually just having another piece cold, and the remains will probably go with coffee for breakfast.
« Reply #121269 on: May 30, 2022, 09:54:10 pm »
I suspect that because of the sheer size of the shorting plug and the fact that copper is such a brilliant conductor of heat, that the oxidizing could be restricted to just the "blob" zone.
Offline hendorog
« Reply #121270 on: May 30, 2022, 09:55:08 pm »
The EMEX organisers felt very sorry for me having to spend three days in close confinement with tautech in the Siglent booth. So they gave me my own booth!!!
Of course being the upstanding gentleman I am, I let him use it....
The following users thanked this post: Vince, tautech, BU508A, mnementh, Specmaster, bd139, ch_scr, cyclin_al
Online BU508A
« Reply #121271 on: May 30, 2022, 10:20:04 pm »
This stand needs definitely more Siglent TE.  :-DD
Offline hendorog
« Reply #121272 on: May 30, 2022, 10:25:50 pm »
Had to leave some room for the dance floor  :scared:
Offline Neomys Sapiens
« Reply #121273 on: May 30, 2022, 10:42:25 pm »
Alas, I got only 1 out of three - work did make me lose the TCP202 and an evil bidder the P6248. Dang. At least 1 HV differential probe for which I do not need batteries anymore. But a P5210 for a measly 279.- is a good catch already. Once I have at least one P5205 to go wih it (2 are target), I will sell off one or two of my non-Tek Isoprobes.
And I will have another go at a TCP202, it seems. I just hope that I did not tip that s*****g off with my cautionary post.
The following users thanked this post: Vince, Cubdriver, mnementh, capt bullshot, Mortymore, ch_scr, Kosmic, cyclin_al
« Reply #121274 on: May 30, 2022, 11:08:20 pm »
Good deal. It's nice to see you back in the "groove".  :-+
The following users thanked this post: Specmaster, bd139, cyclin_al
