Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16946209 times)
Kosmic, Ice-Tea, Robert763 and 140 Guests are viewing this topic.
« Reply #118625 on: April 29, 2022, 09:10:12 am »
One of our machine rooms was built by a contractor who decided to fit M5 threaded cage nuts in everything. It's the only room so fitted.
Now that is true deviant behaviour!   :scared:
<snip>
No, there is every sign that this was intentional from the contractor and no-one in our organisation understood the contractors perverse manners until it was too late. Because why deviate from M6? Nobody does that!
The only up side with M5 is that DIN / ISO specifies Philips 2 for M5, and since people (except yours truly) who fit things in racks never have a Philips 3 driver as required by M6, but instead bodge everything (including PH1 and Pozidriv) with a PH2 driver, this is an adaptation to reality in some sense.
« Reply #118626 on: April 29, 2022, 10:28:30 am »
Engineer: "Order me some new cage nuts and screws please"
PO: "Wait a moment, I have my notes here somewhere" -struggles to read notes- "Ermm, 500, umm, M...5? And 20mm screws for them"
On site, when the driver arrives from the supplier:
Driver: "Here you go mate"
Engineer: "Cheers"
Driver leaves, engineer checks order more closely and curses, then shrugs and uses what he has to hand.
You left out the bit where the delivered screws are countersunk.  >:D
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #118627 on: April 29, 2022, 10:33:38 am »
"Pozidrive is the same as Philips right?"
The following users thanked this post: mnementh, Peter_O
Offline Brumby
« Reply #118628 on: April 29, 2022, 11:01:41 am »
Close - but different.  The devil is in the detail.
Offline Neper
« Reply #118629 on: April 29, 2022, 11:06:00 am »
Different enough to ruin the head with the wrong tool.
Online Robert763
« Reply #118630 on: April 29, 2022, 11:09:13 am »
No it's like JIS  :popcorn: :popcorn: :-DD :-DD
The removable flatish bit in my Leatherman Charge fits just about every cross recess screw from size 1 to 3.
« Reply #118631 on: April 29, 2022, 12:24:41 pm »
Engineer: "Cheers"
You sick, sick bastard. :-DD
And of course, you'll gladly provide appropriate cup washers for a nominal fee...  >:D
« Reply #118632 on: April 29, 2022, 12:31:41 pm »
This fits 'em all...     :-DD
...and replace 'em with Tamper-Resist Torx.    >:D
The following users thanked this post: Specmaster, Peter_O
« Reply #118633 on: April 29, 2022, 12:37:03 pm »
Just whack the butt of your PZ2 screwdriver with a hammer; you'll make it fit.  >:D
*ordinary tinkerdwagon, contemplating the universe and unscrewing the inscrutable*
« Reply #118634 on: April 29, 2022, 12:38:30 pm »
Am I the only one that realised Terra was playing the role of the PO here? I would have thought the quotation marks gave it away!
The following users thanked this post: mnementh, TERRA Operative, cyclin_al, Peter_O
« Reply #118635 on: April 29, 2022, 12:40:06 pm »
I completely forgot about those. Shows how long it is since I built any racks up!
« Reply #118636 on: April 29, 2022, 12:42:24 pm »
Just spent the last 90 minutes or so sweating and swearing at the Inshitnia, as I tried to get the serpentine belt back on. My own fault really, need to remember to take it out of gear before lifting the clutch when I park without turning the engine off.
Offline Brumby
« Reply #118637 on: April 29, 2022, 12:59:55 pm »
Yeah - but where's the fun in that?   ;D
« Reply #118638 on: April 29, 2022, 02:04:56 pm »
I've got both No. 1 and No. 2  PZ and PH in my Charge Ti...
Edit: I bought a 1,2,3 set of Vessel JIS drivers. A wonderful bite they have, indeed. In some sense it feels they're better suited to Philips than my iBost, Wiha or Bahco Philips drivers.
« Last Edit: April 29, 2022, 02:08:19 pm by mansaxel »
  • Country: jp
« Reply #118639 on: April 29, 2022, 02:06:28 pm »
I could hear the whoosh as it flew over their heads from here...  :-DD
« Reply #118640 on: April 29, 2022, 02:09:27 pm »
"They're made by the same company, so it's just a compatible upgrade, shirley."
« Reply #118641 on: April 29, 2022, 02:36:25 pm »
I've just spent my time not swearing at the BMW. I've spent the afternoon converting the temporary dashcam wiring to permanent (even has its own fuses) wiring. That involved disconnecting (and reconnecting) three batteries (high voltage, 12V main, 12V stop/start) and taking out all the interior trim down one side of the vehicle, and part of the rear seat, to route the dashcam cables to the rear camera and power along the existing wiring loom routes and, most importantly, not over any of the gazillion airbags. Then putting it all back again.
Provided that you've got the BMW workshop documentation that shows you where all the trim clips are hidden it's not an unpleasant job. A bit fiddly just becuase there are so many bits of the vehicle that you touch. Nicer to work on, for this kind of job anyway, than anything I've had before.
I now have a dashcam that turns on with the ignition, puts itself into parking mode when the ignition goes off, stays powered 24/7 and reports any nefarious activities while it's parked via an LTE modem. Also I now have none of the cables shoved into bits of trim and seals where they don't belong. All in all a useful afternoon's work, even if I now ache a bit from all the twisting and turning necessary to get into all the corners. [Fx: reaches for the bottle of Ibuprofen]
The following users thanked this post: Cubdriver, mnementh, Specmaster, cyclin_al
« Reply #118642 on: April 29, 2022, 02:52:13 pm »
 :-DD
« Reply #118643 on: April 29, 2022, 02:55:59 pm »
Nope. That's why I took the gag and ran with it. Twice.  :-DD
*toddling off to the grocery*
« Reply #118644 on: April 29, 2022, 03:07:52 pm »
No whoosh here. Fell with a thud. I know posi not phillips not JIS.   :-+
And then the Canucks are fond of their Robertson.   ;D
« Reply #118645 on: April 29, 2022, 04:33:53 pm »
I was just going to post that, but you beat me to it.
« Reply #118646 on: April 29, 2022, 04:37:57 pm »
I think CNG is not a suitable fuel for motor vehicles, in the event of crash or a fire, it has the power to either demolish a whole block a become flamethrower if fitted with PRV.
Or even want a BMW, sorry C  :-DD
« Last Edit: April 29, 2022, 04:45:38 pm by Specmaster »
Offline 25 CPS
« Reply #118647 on: April 29, 2022, 04:41:45 pm »
We are!  I showed one of my American friends the Sears Kenmore dryer that came with my house and he coudn't get over the Robertsons on it.  It would've been made here by Camco or Inglis, probably Inglis.
Then there's the story of the Canadian Westinghouse Ltd. motor generator set that nobody was expecting to see down in Baltimore...
« Reply #118648 on: April 29, 2022, 04:58:42 pm »
Did it come with a hoser to fix it? Eh? :P :-DD
« Reply #118649 on: April 29, 2022, 05:16:23 pm »
Yeah, the only crazier thing would be to replace CNG (~39GJ/tonne) with something even more energetic like Diesel (~45 GJ/tonne) or Petroleum (~47 GJ/tonne).
Thats' OK, as a Skoda driver by choice we can tell you're not really interested in cars.  :)
BTW Skodas burn just as well as BMWs:
