Robbing vacuum tubes out of Tek scopes to fix an hp scope? Well.....OK.....just don't make a habit of it.
I'm hoping Vince actually means 'borrowing' the tubes from the Teks, and that once the HP is known to be operational he will buy it its own set of tubes...
-Pat
Nope sorry, a tube is a tube.. a 6AU6 doesn't care if it's socketed inside a Tek or HP scope !
Half my Tek scopes are donors, so they might as well save the life of an HP scope
Anyway... BAD news....
I have just retrieved all the required tubes from a couple Tek scopes : x3 6DJ8 and x5 12AU7. Then I fitted also x3 6U8 from the 16 NOS I bought from Russia...
Scope powers up, no big bang nor smoke. Tubes light up, and "some light " on the CRT... cool
However as I was playing with the controls to see what I could get out of the CRT, it soon became apparent that... the ONLY tube that I can't replace, the CRT... is FUCKED !!!!!
How do I know you ask ? Good point... especially since I have never had a bad CRT so far ! So it's new to me..
I made a littel video of it
Basically, the CRT is noisy. Yes, a CRT can make noises... it's blatant, not faint at all. My camera had no trouble capturing it.
It sounds like a metallic rattling noise inside the CRT, in the neck.... where all the plates and grids and all the delicate stuff is
They are not vibrating of course.. instead I think they are arcing badly !
The thin metal parts inside must have got bent during shipping or damage prior to that I don't know, one of them must be too close to another, and it's arcing.
Using the CRT controls I can acutally kinda control this noise and turn the CRT into a musical instrument, no kidding ! Kinda fun... well not
Using the brightness control I can make the noise louder or quieter, and the pitch go higher or lower.
Using the vertical or horizontal position controls, I can make the noise come and go at will --> as soon as I move the spot outside the screen, noise disappear. Put the spot back in the visible area, noise comes back...
Of course as it's arcing it makes weird things on the screen, as you can see. The frequency of the igh show on the screen, is 100% correlated with the noise/pitch of of the CRT neck.
I was so excited to fix it and have it all working nice and all... and it's dead
Can one find a CRT for this scope these days ? Or one that would fit and be electrically compatible at least ? How expensive are they, if at all available ?
I rescued the scope because it's cute and was free.... I can't justify nor afford to put lots of money for a new CRT... that would need to get shipped of course so might be damaged as well when getting to me
It's 00H36, I am about to go to bed... and I am very sad, I won't be making sweet dreams.....
EDIT : the parts list in the manual says the CRT is " P31 PHOSPHOR INTERNAL GRATICULE " , part number 5083-0353
EDIT #2 : just google the P/N. It found one on Ebay USA, sold for .... 570 dollars ! for 450kHz CRT !!!
Scope is a write off
https://www.ebay.com/itm/274969806314
