Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18121370 times)
Vince and 36 Guests are viewing this topic.
« Reply #118300 on: April 24, 2022, 08:21:39 pm »
Gone are the days when the only thing that you needed to do something with your oscilloscope were some probes.
I'm looking for a keyboard for the incoming TDS5104 now. It should be as compact as possible and best would be one with an integrated trackball. I found a Siemens Nixdorf one with a touchpad, which has the desired PS2 interfaces (2, as one for the keyboard and one for the pointing function). But knowing that S-N gear was in many cases not really compatible with anything else, I am a bit wary. Looking on. If someone does know a unit fulfilling the requirements outlined above, please let me know..
You probably want a Cherry ML4400 G84-4400PPADE/01 keyboard. This kind of keyboards were widely used in 19 inch server racks.
Example: https://www.ebay.de/itm/273797654692
The following users thanked this post: mnementh, Neomys Sapiens
Offline tggzzz
« Reply #118301 on: April 24, 2022, 08:25:42 pm »
I have one of these http://www.riitek.com/product/k12x.html
Bluetooth, touchpad, usable keyboard with some tactile feedback.
Offline Neomys Sapiens
« Reply #118302 on: April 24, 2022, 08:33:10 pm »
Nice, except for the Bluetooth, which has (imo) no place at the lab bench.
« Reply #118303 on: April 24, 2022, 08:40:51 pm »
This one looks just right.
« Reply #118304 on: April 24, 2022, 08:41:23 pm »
...then measure the same voltage but using the HV probe, note difference and run the math to know what error is introduced by the probe, and take that into account... or calibrate it out of course if the probe has such a luxury.
That would be Calibration and Adjustment, not Calibration only.
 :horse: :horse:
/HTH, HAND
Edit: My probes are calibrated with the meter they came in a kit. I trust them, but have of course pondered how to create a suitably high DC voltage to make a dent in the reading while also having a non-probe-fitted meter that will measure it.
It's not so clear to me. the Tek manuals for my old scopes, to me, make it sound like Tek uses "adjustments" in order to perform the "calibration". So the calibration is the act of .. well acting on the scope so that it meet its spec again. The "adjustments" are the form that this act, takes.
In French we use the term "Etalonné", that's not ambiguous and means that performance has been checked/measured, but measured only. No action has been taken to correct anything.
When we say "calibrate", in contrast, that means acting has been performed on the TE to bring it back to spec. Said action of course is in the form of adjustments... rarely in the form of a sledge hammer, or throwing the TE out the window from the 5th floor...
I don't know if there is a word in English like that, to clearly say that the performance has been checked but no adjustments have been made. You say that's the very meaning of " calibration", but reading Tek manuals, it's not how they use the term.Well, the way I read it of course... I am not a native English of course...
If fear there might be some difference between the rosy world of a dictionary definition of the term "calibrate", and how it gets used in practice.
This has always been my understanding as well, I have workshop manuals that refer to calibration, then they proceed to instruct you in the test parameters are and what to adjust if the equipment does not match the reading that the manual states. The manuals also give a performance check section, again where they tell you what parameters to set up, and they also tell you what indicated values you expect to, this section of the manuals is then followed by the calibration section.
With that in mind, when you send something away to be calibrated, I would expect them to conduct a performance check and note down the ranges that fell into the pass mark parameters the manual gives and then move onto making adjustments where possible to the ranges that did not make the pass mark, and adjust them until they did achieve the pass mark status. Seems logical to me
All well and good until you consider that calibration labs also do weights, rulers, micrometers and many other things that cannot be adjusted. A proper calibration lab will always differentiate between calibration and adjustment; Mick, who can "Calibrate your tester for you gov." probably won't.
Online Vince
« Reply #118305 on: April 24, 2022, 08:41:45 pm »
Tek RM17 repair update
Only problem left is the trace moving up and down a  bit. With now zero filtering on the voltage divider, plus crappy caps decoupling that pre-amp supply... no wonder. So I will replace these x3 10uF caps and I guess it should get rid of that problem !  8)
OK so I did just that. Cobbled together a replacement C146 A/B/C 3 section cap, see how beautiful it is ? You are all jealous of my artistic talent, I know, I know...  >:D  :-DD
Just looked at my stock of SMPS / 400V caps, found a few 10uF , spot on the value of the old caps, fantastic.
Here is a little video I made of what the calibrator signal looked like on the 10/20/50mV ranges, i.e when using the pre-amp.
trace randomly moves a bit up and down, plus regularly it gets wild and gets all scratchy/super noisy, as if there was a bad switch contact somewhere.
Also, big spikes on the trailing edges !  :scared:
And of course the amplitude problem... but that has now been solved as we have seen.
Just in case, I put a plastic box no top of the caps.. safety first ! Then I power the scope up and... no explosion, good start. 10 seconds later... no smoke.... even better. 30 seconds later... a trace on the scope.... ohhhhhh....  100% fixed ! No spikes anymore no the leading edges, zero vertical movement, zero scratchiness... just a nice rock solid, super stable, clean sharp square wave ! I like that a lot !  :D
Just goes to show that even these 60+ year old antiques can still do great things... I can't get enough of the joy it brings me to see such an old scope display such small signal so cleanly, so sharply, so rock solid... it's not a toy, it's a proper piece of TE  8)
So  I think that's about wraps it up for this scope ! All fixed. Just need to order decent new caps and tidy up this hack, the button it up !
I can now resume work on the Rochar Nixie DMM  >:D
The following users thanked this post: Cubdriver, med6753, Specmaster, cyclin_al, syau
« Reply #118306 on: April 24, 2022, 08:55:59 pm »
 :horse: :horse:
/HTH, HAND
Oh yeah and to walk into such a place and not trip over your tongue/yaw is a real achievement.
All the best gear everywhere including a few Siglent's  :) however just having good gear doesn't mean they have competent staff to use it.  ::)
Study the attached PDF Performance verification report (part of) and it demonstrates how some staff get into positions where they should know how properly to use 50 Ohm inputs but don't.  |O
« Reply #118307 on: April 24, 2022, 09:06:35 pm »
Results after a 2 hour continuous run.....
I'm calling it fixed. The HV Oscillator is loafing along at a stable 72V. Mounty.....please let Herr Felgendreher know that the repair was indeed successful and tell him how much I appreciate his efforts. He does some excellent work.  :-+
So onward and upward with the balance of the restoration/recap/calibration. ;D
The following users thanked this post: Vince, Cubdriver, BU508A, mnementh, Specmaster, capt bullshot, salvagedcircuitry, cyclin_al
Online Vince
« Reply #118308 on: April 24, 2022, 09:07:07 pm »
Oh... wow.... I hope at least that the guy got his money back and some apologies !  :wtf:
« Reply #118309 on: April 24, 2022, 09:16:59 pm »
Nope, one of the Cal lab staff busted it and it was discovered in routine performance verification (calibration) checks.
The Cal tech that runs their big Fluke universal calibrator said they needed 2KW rated 50 Ohm inputs for some of the muppets working there.  :horse:
« Reply #118310 on: April 24, 2022, 09:20:32 pm »
That is good news!  :-+
I'll write him tomorrow an email, together with the links to your reports, so he can check it out first hand.  :)
I am really relieved to see that the repair was a complete success (and that we do have now a happy Papa Smurf).  :D
The following users thanked this post: med6753, cyclin_al
Offline GreyWoolfe
  • NW0LF
« Reply #118311 on: April 24, 2022, 10:04:04 pm »
Don't ya just hate the smell of burning flesh  :-DD :-DD
Yes, especially my own.
Offline GreyWoolfe
  • NW0LF
« Reply #118312 on: April 24, 2022, 10:11:26 pm »
Pineapple and Bits o' Pig are a taste combination made in heaven... mixed with any form of tomato sauce, not so much.   :-\
and fuck anchovies. with a shovel.   :P
Pineapple offends both my Italian and Sicilian heritages.  Anchovies, however, are a completely different story, I'm with med on this.  Even on Cauliflower crust as we don't eat simple carbs any more, an entire jar of anchovies with capers goes just right and doesn't even offend Mrs GreyWoolfe.  I am presently experimenting on making my own crust as the cheese added to store bought is bad for my intestines.  Tonight was taco pizza.  fajita seasoned ground chicken, sauteed onions and green peppers, jalapenos, pizza sauce and vegan cheddar cheese because of issues with regular cheese.  Taco pizza should probably offend those same heritages but somehow it doesn't.
« Reply #118313 on: April 24, 2022, 10:25:41 pm »
Do these connectors fit for an old HP3400A?
If the [hp] is made in what was then West Germany, yes, they probably fit. I've got a Model 400h VTVM made in the early Bundesrepublik that takes that connector.
It's an US one.
Then you need a PH-163 as Cubdriver wrote; the Heizgerätestecker won't do. Good luck. I've got two, one with my 5221 and one with my 200CDR. I also have about 100 ordinary C13 cables. And a batch of Heizgerätestecker, which still can be bought as NOS. (A lot of toasters, waffle irons and other appliances here take the connector, so there is a large non-TE "vintage chic" market. )
« Reply #118314 on: April 25, 2022, 12:14:46 am »
An extremely versatile portable multimeter not found often in good shape:
https://www.ebay.de/itm/304459208262
You might recall that mine came out of the DMMcheck-testing right on spot.
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
  • Country: jp
« Reply #118317 on: April 25, 2022, 01:45:42 am »
It's a GPIB printer, looks like basically an heavy-duty receipt printer, I guess it mostly just prints out screenshots.
I have the enhanced printer software already, so should be fun to play with (I'll have to replace/3D print the cosmetic plastic front and rear trim pieces too).
« Reply #118318 on: April 25, 2022, 03:46:51 am »
Announcement instead of content: From Wednesday, April 6, 2022, Yahoo! JAPAN is no longer available in the EEA and the United Kingdom
Offline Saskia
« Reply #118319 on: April 25, 2022, 05:37:23 am »
There are external thinkpad keyboards available - either with that miniature joystick or with a touchpad.
I have one of those and I find it useful (happy is too strong an expression)
Offline Saskia
« Reply #118320 on: April 25, 2022, 05:41:38 am »
no. But the data should be recoverable.
This reminds me. Gotta set up some backup.
My large NAS is still not reconnected, this will take some additional time (first need to finalize the lab and bring order to the universe put in flooring, heating, juice.
But I do have another NAS (2 bay,small QNAP or Synology, don't remember) and some spare hard drives.
Time to set it up I guess.
The following users thanked this post: Neomys Sapiens, cyclin_al
  • Country: jp
« Reply #118321 on: April 25, 2022, 05:59:07 am »
Here's a pic from the listing.
Paid equal to US$60 including shipping. It's a bit beat up so might become a parts mule for my nicer units.
The following users thanked this post: Vince, cyclin_al
« Reply #118322 on: April 25, 2022, 06:04:50 am »
The data contained on my computers is really only useful to me and doesn't contain anything I consider "sensitive" so my backup strategy is modest but effective. I utilize Google Drive but I don't let it run in the background. I run it manually and under my supervision when I feel the need then I shut it down. I have an external hard drive off line and once a month I bring it up and use Macrium Reflect to run a full clone of the hard drive. I then shut it down off line.
Offline Saskia
« Reply #118323 on: April 25, 2022, 06:12:18 am »
I have several backup drives in various locations plus some data in a vault. However there are computers holding critical data and some that only have a few important documents (such as my tax filings)
The TP450S was the one I did some of my tax filings on and wrote some somewhat important documents so I should make a backup of the data folders.
I need to reorganize my data storage anyway but this is going to take a lot of time ...
Offline DC1MC
« Reply #118324 on: April 25, 2022, 06:14:16 am »
https://page.auctions.yahoo.co.jp/jp/auction/k1047442985
We will never know:
Please be informed that from Wednesday, April 6, 2022, Yahoo! JAPAN’s services are no longer available to our users in the EEA (European Economic Area) and the United Kingdom, as it has been determined by Yahoo! JAPAN that providing a continuous service environment in these regions would be difficult. Please note that services listed under “Services available after Wednesday, April 6, 2022” below will continue to be available.
Please note that all Yahoo! JAPAN services are accessible after this date if access is made from Japan.
We sincerely apologize for any inconvenience this may cause and thank you for your understanding.
