One must say that help is sought and found on TE topics outside of this thread on the EEV forum too. A forum member contacted me about the Unigor 6e based on some post of mine here or elsewhere. He asked whether I have a circuit diagram with component values or a BoM for the instrument. Unfortunately, I had to negate this. Incidentally, I had already worried about the very same issue, because of the problem with the R and C ranges found during checkout with the DMMcheck. Some days later, the member came back to me and told me that he ha found someone on the forum who, after having had the same problem, actually bought and digitized the service manual. He had already cleared with this user that I would be allowed to contact the holder of the document. So now I have those values and I will discuss with the latter guy whether it could find it's way onto one of the known servers.
On a completely unrelated topic, I was reminded somehow that in my toolcase #1 resides one of the most useless DMMs produced by Fluke, i.e. a model 79-III. I bought it NOS when I found out that the Fluke 87 did not take the compression in this case well, which was the reason for the re-occurence of the dislocated LCD problem. The thought behind was that this average DMM should be sufficient in this kit, as one of the dedicated T&M kits would be along often. But it irks me that it is missing the min/max function, which I deem critical. I will probably replace it by a Fluke 115 and gain a bit of space as well. So if anyone does have a craving for a Fluke 79-III when I will have aquired a replacement, you can call dibs.
My aquisition of the day is a sort of dummy load (N in, BNC out) from the company T&M research in Albuquerque NM.
They are known for their pulse current monitoring resitors and related items. It could of course be a dud, but for 13.52€ it would not hurt much. I also got a 6GHz LP filter from the same seller and I'm looking at some of his other items too, making it even more economical.
I'll let myself into the cookie jar, thanks..
