Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16977601 times)
wkb, BrianInTexas, AVGresponding and 92 Guests are viewing this topic.
Offline Vince
« Reply #115775 on: March 17, 2022, 10:20:54 pm »
[..} had four units to recap, I went with slightly overkill on the 2465B (with the TV trigger option board) with some Nichicon BT series.
[..] need to buy another EF651625 battery (didn't realise so many had the battery), wish I had seen Small Battery Company as they have the correct type for less than Farnell. Mouser offended me by not being able to send the battery (which is not made in the US). Don't think a round battery will fit on the board, you will probably need to add some wires & mount it somewhere else.
Ohhhh.....noooo....  :palm:
When TerraOperative said the original Battery was available but no export.... it did not occur to me that maybe... as you saw.... you could by a non-original... with the package/specs !  :palm:
Just searched Google for " LTC-7PN ", and sure enough you can by a LTC-7PN in Frog land. Farnell France has it like in the UK... for 20 Euros. Google found me a French website that sells them for half that price, 11 Euros.
The cylindrical one I bought is a Varta "half" length AA cell, 14.5mm diameter, with axial leads, so I should have no problem soldering it to the foot print on the PCB. Diameter-wise, it might fit without relocating it, because TerraOperative in his video did just that, using a Panasonic, see picture below, from his video.
Thanks then.... now I know if the Varta doesn't fit, no worries the LTC-7PN is still readily available locally for 11 Euros  :-+
https://www.batteries4pro.com/fr/piles/lithium/3,18259-pile-lithium-36v-750mah-ef651625-ltc-7pn-4894128152996.html
That one from the French seller is not correct for the LTC-7PN (EF651625) used in some Tek 2445x 2465x scopes, seems to be missing the two mounting pins from the other side, look for the same part number but with four pins.
Ah yeah you are right. No big deal though, a bit of hot snot or a dab of super glue, will fix that ! >:D
... but no need to. Found another French site that sells the 4 pin version, same as yours it looks like.
Barely more expensive, 12 Euros instead of 11. Still way cheaper than Farnell then :
https://www.pilesminute.com/1919-pile-prismatique-ltc-7-ef651625-lithium-36v-750mah.html
OK so it's cool then, the battery "situation" is all figured out, I can get a nice OEM like replacement.  8)
« Last Edit: March 17, 2022, 10:22:37 pm by Vince »
« Reply #115776 on: March 17, 2022, 10:58:25 pm »
DISQUALIFIED !  :-DD
The Fluke 87 is hardly a cheap bare bone meter like the 10/11/12 are !  >:D
the 87 s a very nice meter, good accuracy, high count/resolution, good features, and expensive.
I would love to add one to my collection (have 4 old Fluke DMMs in all), but here at least, the Fluke brand markup is too much. They aren't good enough value for money. That's why I prefer buying Metrix MX 53/54/56, way better value for money overall.
I can't justify spending 90 euros on an old Fluke 73 say, or 75 ot 77 even, when the same money can get me a MX54/C for example. It just does not compute at all...  :-\
So the few Flukes I do have, are only with me because I was lucky enough to find them at price point that makes sense.
If I can find a nice 87V for a price I like, I would buy it. Well, not now of course, no money for TE atm....
Of the 10 Fluke DMM's in my stash the 87 is the only one I bought new in 1997. Yes, it wasn't cheap.
I've never regretted the money spent on FLUKE. EVER. I got my 87 when I was working for Philips while working my way through my first degree, before they were even available for sale. I paid for it out of 6 paychecks, and it was my go-to meter for 30 years. IMHO, that is unbeatable ROI.
There's a reason this emoji :-DMM looks like a FLUKE 87.  ;)
I also love my Flukes, that being said, if I was buying a new meter, it wouldn't be a Fluke, it would be another Brymen, the second only new DMM I have brought in my life.
Fortunately, they're made such that you can buy one decades old and still be reasonably certain it will still say BAMMM! ;)
 :-/O
That is true, all 5 of mine all agree within 1mV each other and that is dammed impressive  :-+
« Reply #115777 on: March 17, 2022, 11:03:59 pm »
Resistor Nuts!
Just got my mitts on some nice resistors  :)
Yes that is over 200 Vishay S102C metal foil reistors. seven useful values from 240 R to 50 K, 0.01 and 0.02% nad of course ultra stable. Most common is 1 k 0.001%. S102Cs run about £15 each when new. There may be even more coming...
And in other news, I got no response from the seller to two messages about the Metrix MX52Ex. So I raised a case on ebay and got a £15 refund. so an unused DMM for £16 nd some repair time  :D
The following users thanked this post: Vince, Zucca, BU508A, mnementh, ch_scr, Kosmic
« Reply #115778 on: March 17, 2022, 11:05:58 pm »
An off-the-beaten-track auction in Hampshire UK, collect or arrange collection. Looks like a silent key clearout. The crappy pictures appear to show a Tek 2445, A TTi function generator, a Gould oscillator, and an Advance RF signal generator.
https://www.the-saleroom.com/en-gb/auction-catalogues/pump-house-auctions/catalogue-id-srpum10214/lot-2757a91c-acad-4bfa-b319-ae5a01041ff4
The RF signal generator is a Heathkit one (possibly RF-1U), not an Advance.
The TTi Function Generator is TG120, 20MHz.
« Reply #115779 on: March 17, 2022, 11:11:28 pm »
...Found another French site that sells the 4 pin version, same as yours it looks like. Barely more expensive, 12 Euros instead of 11. Still way cheaper than Farnell then :
Honestly, Vince... since you have that Varta cell on the way, I'd stick with that if it's a 1/2AA (14.5mm x 26mm) cell. It will def fit, as the Panasonic cell TerraOperative used is a BR-2/3A cell, which is ~17mm x 33.5. Varta's quality of manufacture is legend; probably the only brand I'd stack up against Panasonic in this application. I dunno that I can say that about the Chinesium one you linked to. All you need do is a little bead of silicone sealant along the bottom-most surface of the battery before you slide it into place. I've done more such replacements in various bits of gear than I can count. :-//
 :-/O
« Last Edit: March 17, 2022, 11:18:02 pm by mnementh »
« Reply #115780 on: March 17, 2022, 11:32:55 pm »
Just got myself the bargain of a lifetime, a brand new and sealed Bosch 18V combo drill set worth £156 and I got it, with full warranty, for less than £50.
The following users thanked this post: Vince, Robert763, BU508A, mnementh, ch_scr, cyclin_al
« Reply #115781 on: March 17, 2022, 11:38:37 pm »
Resistor Nuts!
I just picked up a couple of 10k 0.1% ANs, which are very similar to the S102C, for £4 each. I had no immediate need for them but I had a need to purchase something arbitrary just to make sure that my new debit card had been activated properly and they were the first interesting thing I tripped over. Actual values 9,999.859Ω and 10,000.186Ω. Quite how far out from nominal any particular Vishay bulk metal foil resistor is, is a pretty arbitrary thing - they are all laser trimmed and they are all always well inside tolerance. I guess the point where they give up for "not particularly special" resistors (e.g. 0.1%) is a question of "How close can we get in two or three measure/trim cycles?".
One of the interesting side effects of the fact that they are all laser trimmed is that you can order completely arbitrary values from them for the same price as a standard value. For small orders that aren't worth the set up of the machine that prints the value on them they hand write the values on. Very cute.
The following users thanked this post: SeanB, Vince, Zucca, BU508A, mnementh, Neomys Sapiens, ch_scr, cyclin_al, syau, Martin Miranda, DH7DN
Offline Zucca
  • EE meid in Itali
« Reply #115782 on: March 18, 2022, 03:15:01 am »
Business case calculation for solar panel installation...
According to my energy company planes, I have to give back the grid at lest 101.38 Kwh/month to break even and start to make .06-.04$/Kwh.
I am very temped to buy a stupid amount of LiFePo4 and serve them a glorious middle finger!
Of course I will cancel the contract on the 4th July...
Offline Saskia
« Reply #115783 on: March 18, 2022, 06:23:13 am »
this is exactly what I would do and what I will be doing once I have the cash from the sale of my appartment which will hopefully happen next week (cash until early May)
The following users thanked this post: Zucca, cyclin_al
Offline VK5RC
« Reply #115784 on: March 18, 2022, 07:05:35 am »
We had an 8kW of solar panels put on our roof about 7yrs ago, as 2 storey house ie awkward, it cost was about AUD~11k, we pay approx 38c/kWhr and receive 6c/kWhr fed back in, we have a sunny hot summer - so we now have minimal electricity bills all year except winter (6kW reverse cycle AC the only heating and cooling), the solar system paid for itself by the 4th year. Hopefully we are having a battery put in shortly (supply issues!) - I don't think the pay off period will be as good (at the current electricity prices) but I am betting that they won't stay the same. We also have a lot of solar in our state (south Australia) and they are talking about a feed in charge. If I recall correctly - our state, with a lot of solar and quite a few wind farms (37 degrees south - so in winter just get a bit of the roaring 40s) about 60% of the state's energy use is renewable ⚡👍.
Offline Vince
« Reply #115785 on: March 18, 2022, 08:01:34 am »
Resistor Nuts!
The brightness of your LEDs will now be set peeeeerfectly !  >:D
Quote from: Robert763
This is indecent, stop bragging... I don't want to hear about this meter anymore, unless it's to sell it to me....
Offline Vince
« Reply #115786 on: March 18, 2022, 08:04:15 am »
 :-/O
Yes sure, Varta first since I have already paid for it ! :-DD
No need for silicone, as I said it's got axial leads so will be held firmly on both sides. It's small / light, a terminal on each side is plenty enough to keep it in place. It's not like I was playing football with the scope  ::)
... That being said I guess a bit of silicone would not hurt, but I don't have the stuff they use on circuit boards. I would have to buy it, which means for the same price I might as well buy the proper battery to begin with... and reuse the Varta for something else...like fixing that GOULD 1604 scope which has a leaked battery. I could reuse the Varta there.
« Last Edit: March 18, 2022, 08:10:53 am by Vince »
Offline Saskia
« Reply #115787 on: March 18, 2022, 08:51:44 am »
@Zucca get them while you can. You can always install a battery later.
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #115788 on: March 18, 2022, 08:56:50 am »
Hmm, no replies from the German ebay seller I'm looking to buy parts from (who only seems to ship in Germany).
Anyone know of a decent freight forwarding company in Germany?
Online BU508A
« Reply #115789 on: March 18, 2022, 08:59:45 am »
PM me the details and I'll see, what I can do for you.
Offline Saskia
« Reply #115790 on: March 18, 2022, 09:28:38 am »
sorry, too much on my mind right now. send link I can buy and forward if Mounty cannot help
Online BU508A
« Reply #115791 on: March 18, 2022, 09:31:17 am »
No worries, I think, I can sort this out. :)
  • Country: jp
« Reply #115792 on: March 18, 2022, 09:33:17 am »
Thanks to both! :) PM sent to BU508A
« Reply #115793 on: March 18, 2022, 11:26:44 am »
 :-/O
Clear 100% silicone sealant as you get from the hardware store is all I've ever used. Just let it cure fully before you power up.
You're missing the main point, which is the quality of the cell. I'd glue the Varta 1/3AA cell or a Panny BR2/3 in place rather than that Chinesium battery that "fits perfectly" every time. They're a 30-year cell (yes, I know design life isn't that long; but we've all seen ones that were still serving duty 30 years later, and are not at all surprised); that Chinesium battery company hasn't even existed for half that long.
« Last Edit: March 18, 2022, 11:32:20 am by mnementh »
Offline Brumby
« Reply #115794 on: March 18, 2022, 11:33:04 am »
I'd be inclined to add a "neutral cure" qualification to that.  Acid cure would make me anxious.  (Not that I've ever used silicone.)
Offline Zucca
  • EE meid in Itali
« Reply #115795 on: March 18, 2022, 11:45:57 am »
Unfortunately I am not in a rush, here my plan:
1) Install first PVs in every possible inch on my roof and my south facing home wall. Microinverters of course.
2) Install geothermal, build a second garage and maybe install new windows (according to my Flir what I habe now is a joke, cheap ass builders I hate them so much)...
3) Do some math and buy enough LiFePo4 that so that if the sun will not appear in the sky, I will still have energy to power my home for three days of completely darkness.
« Reply #115796 on: March 18, 2022, 11:57:32 am »
<SNIP>
<SNIP>
NO, Hell No.  :scared: :scared:
NEVER use  general purpose silcone RTV sealant on PCBs or electronics. They release acetic acid during cure. some of this WILL get trapped between the rubber and components. This can cause corrosion. It does not matter how long you leave it to cure.
Non acid cure silicone is acceptable.
What is 100% silicone anyway? This product says it's 100% silicone but its white and contains mildewcide  :palm:
https://www.loctiteproducts.com/en/products/build/sealants/loctite_100_silcone.html
« Last Edit: March 18, 2022, 11:59:22 am by Robert763 »
The following users thanked this post: cyclin_al, Neper
« Reply #115797 on: March 18, 2022, 12:11:38 pm »
Make certain that the µinverters are tested for EMI/RFI as a system, not in isolation without the antenna lengths that typically occur in an installed system.  The noise floor from a typical contractor-installed µinverter PV system must be seen on the SA to be believed... Here, both the aviation authority and the military have issued disconnect-and-dismantle orders to several home owners that had "professionals" install systems, sadly enough a bit too close to "something important".
Twisting the cables and screening the inverters apparently has made wonders in some installs, but they remain a nuisance.
« Reply #115798 on: March 18, 2022, 12:25:28 pm »
<SNIP>
<SNIP>
3 decades of experience repairing remote controls and PC MBs and other such gear says that's bunk. "Will be trapped" and "can" cause corrosion obviously is not the same as real life.
Do as you see fit. I'm not gonna argue this one; I've repaired and used remotes and computers for literally decades with regular 100% GE silicone, as available at any hardware store. I've never had damage to the PCB, nor electrical fault as long as I didn't power up before it was fully cured. And yes, some of these I've had to go back in 10-20 years later and repair other faults.
Definitely better than most of the hot-snot products I've seen used in production, some of which which hold moisture and become a path to ground.  :palm:
Cheers,
 :-/O
« Last Edit: March 18, 2022, 12:31:58 pm by mnementh »
« Reply #115799 on: March 18, 2022, 12:34:17 pm »
The acetoxy cure silicones, as well as exuding methanoic acid, have rather poor and unspecified dielectric properties. The real stuff, like Dow 738, comes in at 19 kV/mm and, if you can find it, is a better bet than building supplier's neutral cure silicone. If you can find it, it's only £10 for a 100ml tube, but like everything else at the moment there seem to be supply problems - my usual source has a 115 day lead time on it.
The following users thanked this post: mnementh, Neomys Sapiens
