Some of the TE I collected from PP last Monday, not pictured is the box of
hp 180/181 series SA plug-ins (all been raided for parts by previous owner), Cox TV encoder thingy, Huntron Tracker, box of cables and the lot of books (which did include three folders of HP journals, all random years).
The
hp 182A & 182T, the later 182T has a longer CRT with the internal graticule illumimation, plus uses higher HT. I noted the 182A was only in the catalog for a two years before it got replaced by the "C" model. The 182A is S/N 1140U00139, made in the South Queensfery
hp site in Scotland.
Tek 453, looks a PITA to replace the cropped off power cord.
Saved an AVO Test Set Multi-Range No. 1 from becoming another lamp foot or timepiece or tooth-blue audio device.
And unlike the last AVO 8 I acquired (with O/C meter), this one appears to be functional & no leak-tubes left inside, I've not yet checked the accuracy though.
hp storage normalizer with the often missing lead, unfortunately has the network analyzer card fitted, no idea if it can be used with the 180T SA like this.
The Racal 9835 counter has a bit of a rattle, found this TCC smoothing bomb loose inside.
Systron-Donner/Datapulse 88 pulse generator, according to the book the '99' version doesn't have the +5V 1A PSU built in.
