Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17486712 times)
PA0PBZ, Original and 58 Guests are viewing this topic.
« Reply #114675 on: March 01, 2022, 06:24:52 pm »
yarp. but at least it works. better to have a working GPU than a brick.
Not if you're being attacked by, say, a wolf...
Offline Neomys Sapiens
« Reply #114676 on: March 01, 2022, 06:36:10 pm »
...a working GPU would allow you to explore the various outcomes of any move you and the wolf make and produce nice parametric diagrams of them!
« Reply #114677 on: March 01, 2022, 06:47:52 pm »
Only if it's attached to a working PC and monitor, which was not mentioned. Also, I'm not sure the wolf would be patient enough to wait while you wrote and ran the software.
« Reply #114678 on: March 01, 2022, 06:50:30 pm »
And they would give you something to discuss with, and show to, the wolf while it was gnawing on your leg. I'm sure that the wolf would appreciate that.
Offline GreyWoolfe
  • NW0LF
« Reply #114679 on: March 01, 2022, 07:02:30 pm »
We are far more patient than you think.  We will track and harry you for miles/hours before we deem you ready to be killed and eaten. ;D
Offline Saskia
« Reply #114680 on: March 01, 2022, 07:28:40 pm »
my wolves are well behaved.
The following users thanked this post: SeanB, Vince, med6753, mnementh, Neomys Sapiens, FransW, factory, cyclin_al
« Reply #114681 on: March 01, 2022, 07:46:12 pm »
But...but...but we got a really good correlation when charting the received damage in the first attack (as normalized trauma index) over the wolf's astigmatism and the relative angular velocity! Observations in the field show that we can make an accurate prediction valid for 62% of cases within 0.1 of outcome (on a scale from 0..1) for anything from a completely sharpsighted to a totally blind wolf!
« Last Edit: March 01, 2022, 07:49:57 pm by Neomys Sapiens »
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #114682 on: March 01, 2022, 07:48:12 pm »
But will cut a bitch if provoked.
-Pat
The following users thanked this post: mnementh, Saskia
« Reply #114683 on: March 01, 2022, 07:49:30 pm »
Let me guess..the large one is Fairbairn, the second Applegate and the third one Sykes?
The following users thanked this post: Saskia, duckduck
« Reply #114684 on: March 01, 2022, 08:14:19 pm »
To get away for a moment from charting and modelling wolves bears, I received a strange logic probe from IBM, complete with carry case in Burberry design. For technologies it allows to select between Multi, MST2/4 and MST1. Can someone with enough IBM product knowledge translate that into regular logic families for me or do I really have to dig through the accompanying, awfully small-printed, manual? It came to me for 3.-€ out of curiosity..if I never find any use for it, there is at least a interface cable fitting also on 5mm modular probes to dual 0.64pin.
The following users thanked this post: mnementh, ch_scr
Offline Saskia
« Reply #114685 on: March 01, 2022, 08:27:04 pm »
finally some bastelfrickeldoodling ...
The following users thanked this post: SeanB, Vince, McBryce, mnementh, capt bullshot, ch_scr, cyclin_al
Offline Zucca
  • EE meid in Itali
« Reply #114686 on: March 01, 2022, 08:31:26 pm »
tu rutututu dudu tuutuutu tuu tut tutu..
Can you hear that too?
Ой полным полна моя коробушка
Есть и ситец, и парча.
Пожалей, душа-зазнобушка,
Молодецкого плеча....
Offline Saskia
« Reply #114687 on: March 01, 2022, 08:48:05 pm »
audio is working, yes...
Online tggzzz
« Reply #114688 on: March 01, 2022, 09:15:18 pm »
Anybody want some dekatrons in a Panax ratemeter/counter? Plus some form of bench multimeter.
https://www.the-saleroom.com/en-gb/auction-catalogues/1818-auctioneers/catalogue-id-sr1810603/lot-a36611a4-5023-4d3e-bd02-ae3e010e899e
« Reply #114689 on: March 01, 2022, 09:17:37 pm »
I worked with MST2 on the S/370-3158 but that was 47 years ago and I'll be damned if I can remember the logic levels for 1 and 0. But I do remember the supplies necessary to power MST2 which was +1.250V and -3.00V but that's not going to help you. Sorry, you're gonna have to read the fine print or this link might help.
http://www.bitsavers.org/pdf/ibm/logic/MST-2_Module_Data_Apr74.pdf
The following users thanked this post: Neomys Sapiens, ch_scr
« Reply #114690 on: March 01, 2022, 10:15:20 pm »
I dunno... If you watch the ads, you'd swear those GPUs are full of dragons and swords and machine guns and avenging angels and shit ...
« Reply #114691 on: March 01, 2022, 10:29:53 pm »
Yes, but by definition, it wouldn't be a "working" GPU without those things. ;)
and before you say it... It's not a GPU when it's being used for mining or AI compute, etc... it's a coprocessor. :P
« Reply #114692 on: March 01, 2022, 11:03:41 pm »
And then bore the wolf to death by presenting him all those nice and very colourful diagrams?
How cruel ...
Death by OSI-layer 8.
 :-DD
« Reply #114693 on: March 02, 2022, 01:28:11 am »
Yesterday I spot-weldet a banana contact tab of my differential probe against a grounded PSU casing with 230V AC.  :palm:
The welding is excellent.  :-DD
This little bit of accidental dissimilar metal welding got me thinking.
In electronics equipment construction I occasionally come across things that could be best done with a little bit of resistance welding of dissimilar metals. Things that come to mind include:
  • Welding a grounding strap (tinned copper type) to the inside of the lid of an aluminium case.
  • (Extreme case) Welding the bottom of a stud/bit of all-thread to the inside of a case for a fixing/grounding point.
  • Welding a spade lug to a case for a ground bonding point.
  • Tacking metal mesh (SS?) to the inside of a cooling grille (Al, Fe?) - both for ground continuity and even possibly all the mechanical support required.
That covers a range of oomph from "Probably needs some real welly and a proper discharge welder" for a stud you actually needed to have some mechanical strength to jobs you might even consider doing with a 'toy' like the capacitor discharge welders used to stick nickel strips on batteries (tacking mesh around a grille opening).
Obviously using fully fledged professional pulse resistance welders designed for the job is cheating (and expensive) but improvising with cheap automotive spot welders and battery tab welders might be an interesting area to explore.
Has anybody done any improvisations in this area? Any battle stories, bodges that turned out actually good,  experiments that failed disastrously?
[Cue stories from SeanB of exploits,  in typical South Eifrican style, with an infeasibly large stick welding supply and some innocent victim piece of equipment. :)]
You might be interested in the Philips Resistance Welding Handbook found HERE:
https://frank.pocnet.net/other/sos/Philips_ResistanceWelding_Handbook.pdf
Offline VK5RC
« Reply #114694 on: March 02, 2022, 01:41:10 am »
How cruel ...
 :-DD
Watch out for the wolves at vk5rc - lick you to death!
« Reply #114695 on: March 02, 2022, 01:45:18 am »
Thanks I'll take a look. I've two or three complete welding handbooks/textbooks but they tend to be a little light on resistance welding, and of course on the most fun type of welding - explosive welding.
« Reply #114696 on: March 02, 2022, 01:47:19 am »
Wolves, OK, we were talking about wolves, but why did you post a picture of some complicated sort of floor mop? Is it for mopping up wolf drool?
« Reply #114697 on: March 02, 2022, 01:56:00 am »
Nah, don't you see that hairy leg? That's the wolf!
The following users thanked this post: ch_scr, cyclin_al
« Reply #114698 on: March 02, 2022, 02:57:49 am »
This is the defective power switch out of the Type 105. Discovered something interesting. On that brass plate it states 3A/125v and beneath it UL approval. On the cardboard is the maker's mark of "F" within a circle.
On the bottom of the plastic housing it is stamped 6A/125V and 3A/250V. Huh? I give up, which is it at 125V?  :-// Also again is the maker's mark of "F" within a circle. I have no idea who that maker is and they probably are no longer around anyway. It certainly isn't Switch Craft.
« Last Edit: March 02, 2022, 02:59:22 am by med6753 »
The following users thanked this post: Vince, ch_scr
Offline Zucca
  • EE meid in Itali
« Reply #114699 on: March 02, 2022, 03:17:56 am »
It means "Failed".
« Last Edit: March 02, 2022, 03:20:32 am by Zucca »
The following users thanked this post: med6753, Specmaster
