Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16691344 times)
Kosmic, KG7AMV and 126 Guests are viewing this topic.
Offline Neomys Sapiens
« Reply #114200 on: February 21, 2022, 02:24:51 pm »
My parents had the ceiling of their dining room painted purple .... you know: 7 on the colour code chart.
The painter questioned them, but they were quite clear about it.  When he finished, he said it actually didn't look too bad.
YUCK! Just add some warts and mynocks!
« Reply #114201 on: February 21, 2022, 02:31:30 pm »
The short-circuit current obviously exceeded the breaking capacity of the fuse.
I'd say that as far as "breaking" goes, it did a fine job.   ...   I'll show myself out.
*halfheartedly lobs 1/2 a soggy ol' boot towards Belgium over his morning moose pee (only slightly burnt at this hotel) and baggied banana-nut muffin*
I dunno which is worse... this coffee, or the fact I might actually be starting to like it...
:o  *twitch... twitch... twitcha-twitch...*
US coffee is always a disaster -- the fact that Starbucks is viewed as an improvement speaks volumes. I've already written about the three coffeemakers in Malvern PA (none as black as the 5000 holes in Blackburn Lancashire) so won't reiterate that, but just want to share the fact that people expect our corner of the world to bog down in snow completely tonight. And I'm going out for beers and lies with colleagues tonight...
Drive carefully, unless you can melt your way (flatulently)...
Thanks for the good wishes... we are still traveling through the Adirondacks, where the weather summary is: "Don't like the weather? Wait 5 minutes." :o
A'aight... SWMBO is cracking the whip to get out before checkout...
*scribbles imaginary exaggerated signature on imaginary stack of newscast talking points*
"I'm not Dennis Miller, and I am outta here!!!"
Offline Saskia
« Reply #114202 on: February 21, 2022, 03:28:14 pm »
bloody enablers ...
went to Reichelt ...
huuuuge mistake ...
more later ...
The following users thanked this post: Zucca, mnementh, cyclin_al
« Reply #114203 on: February 21, 2022, 03:33:29 pm »
Not universally so. While I'd agree that even a cup of UK instant coffee [A decent instant coffee, obviously. Not Nescafé original.] would be preferable to what you're likely to get served in most places in the US, it is almost impossible to get a bad cup of coffee in Seattle. I don't know what it is about the place but every cup of coffee I had there was either good or great. And no, I didn't go into a Starbucks, which may be why I can give such a glowing report of the place.
« Reply #114204 on: February 21, 2022, 03:51:10 pm »
Probably. I've only ever changed planes in Seattle, and I do think I that as I had managed to upgrade with points to Business Class for the trip home I was busy drinking wine in the lounge, foregoing the coffee.
Offline m k
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-YFE
« Reply #114206 on: February 21, 2022, 04:58:56 pm »
Yesterday I spot-weldet a banana contact tab of my differential probe against a grounded PSU casing with 230V AC.  :palm:
The welding is excellent.  :-DD
This little bit of accidental dissimilar metal welding got me thinking.
In electronics equipment construction I occasionally come across things that could be best done with a little bit of resistance welding of dissimilar metals. Things that come to mind include:
  • Welding a grounding strap (tinned copper type) to the inside of the lid of an aluminium case.
  • (Extreme case) Welding the bottom of a stud/bit of all-thread to the inside of a case for a fixing/grounding point.
  • Welding a spade lug to a case for a ground bonding point.
  • Tacking metal mesh (SS?) to the inside of a cooling grille (Al, Fe?) - both for ground continuity and even possibly all the mechanical support required.
That covers a range of oomph from "Probably needs some real welly and a proper discharge welder" for a stud you actually needed to have some mechanical strength to jobs you might even consider doing with a 'toy' like the capacitor discharge welders used to stick nickel strips on batteries (tacking mesh around a grille opening).
Obviously using fully fledged professional pulse resistance welders designed for the job is cheating (and expensive) but improvising with cheap automotive spot welders and battery tab welders might be an interesting area to explore.
Has anybody done any improvisations in this area? Any battle stories, bodges that turned out actually good,  experiments that failed disastrously?
[Cue stories from SeanB of exploits,  in typical South Eifrican style, with an infeasibly large stick welding supply and some innocent victim piece of equipment. :)]
Offline Zucca
  • EE meid in Itali
Offline THDplusN_bad
« Reply #114208 on: February 21, 2022, 05:09:33 pm »
bloody enablers ...
huuuuge mistake ...
more later ...
I share your pain. I only source material from them when I cannot find any better alternative...  :palm:
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #114209 on: February 21, 2022, 05:11:38 pm »
Was somebody without a power source.
AllSurplus has some in Arizona.
https://www.allsurplus.com/asset/239/21865
https://www.allsurplus.com/asset/324/21865
https://www.allsurplus.com/asset/328/21865
https://www.allsurplus.com/asset/332/21865
I have 2 or three pallets of gear inbound.  Maybe I should sit this one out...
Offline Saskia
« Reply #114210 on: February 21, 2022, 05:47:30 pm »
bloody enablers ...
huuuuge mistake ...
more later ...
Actually I source stuff from them all the time. There is absolutely no place where I can get better pricing.
I planned to pick up some ESD protection stuff (which I did) and came home with a R&S RTC1002 with MSO option which is said to have the 300 MHz update installed ...
Offline Saskia
« Reply #114211 on: February 21, 2022, 05:52:35 pm »
ok, just checked.
Options installed:
I2C / SPI - permanent
UART/RS232 - permanent
CAN/LIN - permanent
Mixed Signal - Permanent
Function Generator - Permanent
300 MHz Option - Permanent
Price: yes ...
The following users thanked this post: mnementh, Neomys Sapiens, ch_scr, Kosmic, cyclin_al
« Reply #114212 on: February 21, 2022, 06:07:00 pm »
Oops - hopefully, no hard feelings!  8)
Offline Zucca
  • EE meid in Itali
« Reply #114213 on: February 21, 2022, 06:11:00 pm »
Is that your first scope?  >:D
« Reply #114214 on: February 21, 2022, 06:19:48 pm »
Now it is her FIRST scope! (in the sense of ranking)
« Reply #114215 on: February 21, 2022, 06:23:23 pm »
bloody enablers ...
huuuuge mistake ...
more later ...
Did you get probes with it? For the MSO option? And some active probes for the regular channels seem also to be a good idea! As well as a 100:1 or two.
Offline Saskia
« Reply #114216 on: February 21, 2022, 06:39:36 pm »
the 2 normal probes are missing, the MSO pod is included. Also missing is the calibration certificate.
I am currently using the testec probes that I got with my portable Tektronix 720 ...
Now don't hit me, but I like the Keysight UI better. Can't say anything about the actual accuracy ... Boot up speed is so far ahead of Keysight that it makes you weep.
The following users thanked this post: BU508A, mnementh, Neomys Sapiens, ch_scr, cyclin_al
Offline Saskia
« Reply #114217 on: February 21, 2022, 06:41:26 pm »
Nah, why should I ?
my problem is that the Reichelt staff knows me toooooo well. They greet me with my first name and try to enable my TEA.
I am spending way too much there ...
The following users thanked this post: THDplusN_bad, mnementh, cyclin_al
Offline ch_scr
« Reply #114218 on: February 21, 2022, 07:46:21 pm »
Nah, why should I ?
We're all very glad (and proud) of you, single-handedly preventing Reichelt from going under ;D
Offline factory
« Reply #114219 on: February 21, 2022, 08:04:14 pm »
Got a bit distracted yesterday & never got round to testing the 5340A with the replacement PROMs.  :-X
Went to a HAM radio sale and came back with a 18GHz Systron Donner counter model 6016, a hp 333A distortion anaylzer (for less than the PPauction prices), some random parts, vacuum bulbs, some lamps and two bags of mixed ICs.
Spent a few hours in the afternoon sorting through the 74 series ICs and putting them in one of the spare drawer units. A mere 320 odd of them so far, including many I hadn't got in the surplus parts I bought from work, plus one type I'd never heard of before, a combined counter,latch,driver IC for number readout bulbs (74142).
Still got the other bag of analog ICs, audio, radio & TV ICs, voltage regulators, some processors & EPROMs, etc. to sort through, the seller reckoned there is about 700 in total.
Also bought some old stock neon bulbs from the same seller with 2" long leads, now I've got no excuse not to replace those dead decimal point lamps, in some of the 524xL series hp counters.  :-DD
The Systron Donner counts in self test, but has an issue with the last number readout, it's stuck with two & the decimal point lit.
There was also a hp 141T spectrum analyzer for sale, with the 8555A plug-in, I didn't buy it as I already have two of those (currently broken), plus my back said no to carrying it back to the van, it did sell but was still there when I went back after lunch (2pm ish) to buy the rest of the ICs & neon lamps.
P.S. Three other bidders wanted the hp TDR on ePay more than me, it made £63 + £35 shipping.
« Last Edit: February 21, 2022, 08:20:08 pm by factory »
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #114220 on: February 21, 2022, 08:26:13 pm »
Nice haul, David!   :-+
-Pat
Offline Cubdriver
  • Nixie addict
« Reply #114221 on: February 21, 2022, 10:10:52 pm »
I recently got a bunch of old (like late 70s-mid 80s) computer grade electrolytic caps, and have been re-forming them on the bench over the past week or so.  On a whim, I decided to bring up an old Honeywell DVM purchased a few years back out in CA and use it to monitor the voltage across the cap being re-formed.  It's an interesting old beast, looks to be from about 1967 based on the newest component date code I spotted at a glance, and doesn't seem to be able to store the reading - instead it counts up from zero every time it updates.  It may be supposed to store the reading (HP counters from several years earlier than 1967 could), but since I've yet to locate a manual for it I don't know for certain if that's normal or if something inside is amiss.
It's cool in that it has a VERY large display, but a bit distracting in the way it blanks for each update (blanking is an option controlled by a switch on the back, and is less distracting IMO than having the blur of the rapidly counting display with every new reading).  Following is a quickie video of the meter in operation, and a link to the gallery with further pictures of it.  I'd forgotten when making the video that I had in fact posted the pics of the insides that I took when I first got it - thought they were probably buried somewhere in a memory card, so ignore the comment about needing to take pictures of the innards.
Gallery link: https://pmanning.smugmug.com/Electronics/Honeywell-620B-DVM
-Pat
The following users thanked this post: Vince, doktor pyta, med6753, mnementh, wolfy007, ch_scr, factory, cyclin_al, BILLPOD
« Reply #114222 on: February 21, 2022, 10:19:49 pm »
Just returned from a round trip taking the Lady Copper home and this package was waiting for me. Whatever is in there was packed very well.
It's the Tek Type 105 Square Wave Generator. Appears to be in very good condition. It's missing the fuse and cap in the back. And the range control is partially jammed. Tear down will have to wait. Either later tonight or tomorrow.
The following users thanked this post: Cubdriver, mnementh, Specmaster, wolfy007, ch_scr, FransW, Kosmic, cyclin_al
« Reply #114223 on: February 21, 2022, 10:22:35 pm »
To conclude the admission testing of the FG501, indeed everything is in working order at this newest addition to the TM500 zoo.
- swept by the FG503
- gated by a PG502
- and the sync output is also accounted for
And in contrast to the big boi (FG504) it does not seem to need switch maintenance.
The following users thanked this post: Cubdriver, med6753, mnementh, ch_scr, Kosmic, cyclin_al
« Reply #114224 on: February 21, 2022, 10:25:50 pm »
This picture says 'decision time'. Left - to the lab, Right - into the soup!
