The T201 (same as the T202, but sold without battery - or maybe an earlier version? Is the T201 the Signalcomputer 01 and the T202 the Signalcomputer 02?)
It is even less a multimeter that the TekMeter, as it can't do Ohms at all. But that multi-parametric display with error/precision does have it's merits - and it can do 10kHz without losing it! Sorry for the pics, but the camera was almost refusing to focus on this thing.
Then a beast that came out of hiding in a literal sense: The Nordmende Transistorvoltmeter, which I pledged to BU508 a long time ago and then it hid under other stuff not wanting to draw my attention. BU, you have some work cut out if you still want it! Those pots are jittery as hell and I'm not sure if that is all...but it works somehow, so the movement is fine.
Another little beastie whose appearance was planned for todays' Tierschau, the SOAR 3100 pen multimeter, had to excuse itself with a case of galvanic indisposition - it has digested at least one of its own battery contacts. It will be back after a quick restoration, so it claims. We will see whether this holds more credibility that the pig's saying that it will go only to a show in Parma and be back next week...
Stand by for next weeks episode : either Her Majesties' Schlumbergers or the electronic Multizets.
