The best car in terms of reliability that I ever had was a Lexus GS300 S1, 2nd place a Jag XKR (X150 model), 3rd place a Lexus LS400. Then: Subaru Forester, Subaru Forester ...
Anything from VW is meh.
And is your Skoda Octavia meh
The Octavia sucks.
The only reason I still have it is that it runs on 4 kg of CNG/100 km. That is 4€.
Seating: uncomfortable.
suspension: not up to the task
gearbox: making noises
I would like to teslarize it the Finnish way. But then again I am still getting some use out of it and currently cannot afford a new car.
Generally I find German cars to be good, I've had 3 Passats, and now on my 4th Skoda Superb, which has been the best car of them all, current one is 8 years old, had it from new and no major issues with it really, only let me down once when an alternator belt shredded itself.
Same here, I can’t blame VAG cars, I have driven them from 1984. I have now driven with two Audi A8L almost 500k in last 12 years with no major or constant faults. And one year with A2 3L in between them just for fun
The one I drive now had 87k when I bought it, now there is 428k in dial.
This has happen in addition normal service (oil, filters, two set of brake pads and one set of discs, etc):
Boot didn't lock, bought a second hand spare lock from eBay.
Air suspension alarm, couldn't lower the car. Bleed valve cable was broken, snapped on bad road or cut against sharp edge, one couldn’t tell.
Picture in foldable center display disappears now and then. But no worries, I have a phone app for it. I hit it with the phone and display comes back to life.
Air-con stopped due to rotten cooling fan fuse holder behind front bumper. New fuse holder.
Water pump started to leak, not from the shaft but from core plug. Pump replaced.
Particle filter alarm due to faulty pressure difference sensor. Sensor replaced.
Glove box opening damper failed at -20C. Didn't bother to fix it.
Some oil underneath the engine but so little that one can’t tell where it comes.
Car didn't start in the morning at -10C. Intercooler hose full of ice, engine couldn't breath. Melting ice, draining water and nowadays I cover lower part of the grille at winter time.
Noise from front suspension. One ball joint and two arms replaced. But there is still some extra noise that needs attention in the future.
This might sound a lot, but nothing very expensive and this 340k ride has been very safe and smooth, also on frozen and snowy roads.
