You can save tape by typing in more than one label title in at a time. Like the "FUSES" label. Type it in and then add more label titles like this -
FUSES RESISTORS CAPACITORS
Put spaces between words (maybe 8 - 10 spaces) and then print it all out at once. Then cut between the label titles with scissors. Then you won't have all that waste at the front and back of each label.
Yeah but I do want some "wasted" space.. I mean I want all the lable to be the same width, the width of the drawer fronts, regardless of how long the character strings are for a given label.... just a bit of OCD there I admit !
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
It would look all over shop and untidy to me if the labels were all different sizes and didn't match perfectly the drawer width. OK think what you want of my OCD...
The printer has a parameter to control how much blank space you want to put between the labels... : narrow/medium/ large... and the last setting is called "chain"... it's supposed to be what I want : zero space between the labels. The printer lets you set the width of a label. Drawer are 50mm wide so I set the label 50mm wide. Then I center justified teh text into these 50mm, then selected Chain printing... but still, somehow, it still puts blank space between the labels, but it should not ! Weird... I think the Firmware of this printer is buggy or corrupt... must have done by a student somewhere in India
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
So I am trying to find ways to circumvent the buggyness of the printer.... for example I tried surrounding the labels with a frame, a rectangle all around the label. This way I have an easy guide to tell me where to cut with my scissors. But..... I find that adding frame on these narrow tapes just looks over crowed and crap. Looks cleaner and easier to read when there is just text and nothing else... so I am giving up this solution.
I am thinking of cutting the labels approximately, then stacking them up on a cutting mat, putting a custom made tool, 500mm wide, on top of the labels, then I would just have to trim the excess around the tool to make sure all the labels are perfectly 50mm wide. I made that tool by cutting piece of thick plastic from the cover of a margarine container... but I have no cutting mat and sharp blade / scalpel... only my worn out box cutter. So.... I am still working on it !
