Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16695081 times)
Carl_Smith and 78 Guests are viewing this topic.
« Reply #111725 on: January 20, 2022, 05:00:44 am »
Other weirdos in here are looking at that hand-lettered serial number 045 and sighing...
I know the feeling. Takes one to know one.
*Takes a bow and put on best Elvis grin and southern drawl*
"Spank you! Spank you vurry mu-u-uch!!!"
« Reply #111726 on: January 20, 2022, 05:08:18 am »
A miracle....
I tried the /56 prefix DHCP Ipv6 on my WAN.
It seems to work.
I created two LAN /64 with prefix 0 and 1 as Tracking interface.
Did the ISP understood something about IPv6 in 2022?
Still trying to understand DHCPv6 Server/RA, do I need it in a Tracking interface? mah...
Next step DDNS with IPv6 holy cow it is a steep learning curve...
There's your problem; cows (holy or otherwise) are not IPV6 compliant. You have to stick them all on a IPV4 subnet and NAT the living hell outta them...  >:D
*knocks self unconscious with a /24 mallet*
Offline Zucca
  • EE meid in Itali
« Reply #111727 on: January 20, 2022, 05:15:06 am »
A miracle....
It seems to work.
no no no it can't be.
my WAN
my LAN1 tracking WAN
my LAN2 tracking WAN
My PC on LAN1
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . : localdomain
   IPv6 Address. . . . . . . . . . . : bla:bla:bla:1300:1d93:c5d9:53f2:ca2
   Temporary IPv6 Address. . . . . . : 2600:6c5e:4c7e:1300:3ddc:429f:edcc:9cb7
   Link-local IPv6 Address . . . . . : fe80::1d93:c5d9:53f2:ca2%10
   IPv4 Address. . . . . . . . . . . : 172.27.36.2
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . : fe80::4262:31ff:fe0a:7b4e%10
                                       172.27.36.1
PC LAN2
   IPv6 Address. . . . . . . . . . . : bla:bla:bla:1301:whatever
No idea who is giving the IPV6 and how... at least the two LANs are in different /64
« Last Edit: January 20, 2022, 05:16:54 am by Zucca »
« Reply #111728 on: January 20, 2022, 08:52:24 am »
I don't know... charging it fully and properly, woudl tak e14 hours... like any NiCd battery.
At 50mA I was fast charging it, pushin it, just to give it a quick shot see if there was still life in it in some way...
But charging it completely, would need to do it properly, so 14 looong hours at C/10 ie at 110mAH that's 11mA for 14H.
That's also what's written on the battery itself.
So I would have to time it so as to not overcharge it... OK I guess I can make an effort an keep track of start and stop time.
Just dug out my old NiCd charger ! Maybe I can just that instead...
We are on EEVBlog so before doing anything I tore it apart of course !  ;D
Oh boy it looks middle age crude in there !  :scared:
A transformer, single wave rectification and a current limiting resistor and that's it !
Plugged the battery in there and scoped the voltage across it... see for yourself.
Single wave indeed, and peaks at 12.5+ Volts !  :scared:
this crude pulsating voltage, that's torture, should be illegal ! How did law back then allow for these things to be sold at all ?!  :-\
so... looks like my lab power supply is two order of magnitude more refined than this charger eh ?
At least it's proper DC I am feeding the battery with, and I can control the current.
Well, kind of... it's a basic analog supply not a fancy HP/Agilent microprocessor haunted supply.
So I don't have great control over the current, in the low end. If I set the pot to the minimum, it will still give 40mA or so, or 75mA.. depends on the output voltage it appears.
I guess I can add a series resistor to get to the required 11mA.
Would be so nice to have fancy PSU where I could just set it to say 15Volts and limit current precisely to 11mA or whatever, trusting that it would stick to that no matter how the output voltage varies.
One day, one day....
EDIT : stupid me... there are two 9V slots in the charger. I plugged the battery in one, but was scoping the other/empty one !  :palm:
So the waveform was for an open circuit condition !
Now I am scoping the proper slot and I see DC with negligible ripple, and it tops at 10.3V or something now, ie the battery voltage I measured prior. So all seems well... letting it charge overnight, wrapped in a fire resistant blanket, floating in a large bucket of water, and smoke detector next to it. Have an IR camera with AI monitoring activity. If anything fishy is going on, I will get a text message on my smartphone.
Your bench charger is a better tool for this task .set the voltage to about 12 V and current to 10 mA put the battery on small plte or in a mug "just in case" and let it charge for >15 hours. Check voltage immeditely off-charge and off-load. Leave it with nothig connected for 12-24 h and check voltage off-load again. Report back. Ni-Cads like to be stored discharged so it might come back to life.
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #111729 on: January 20, 2022, 09:37:54 am »
Ugh, cloning a clockwork hard disk to SSD is a pain in the butt when there are bad sectors... This is going to take a while...
Offline THDplusN_bad
« Reply #111730 on: January 20, 2022, 11:46:33 am »
Why doesn't it start by ' B ' / Beaverton ? US scopes made it to Europe, but an European scope making it to the US sounds weird / backwards... hell I don't think I ever found out what the '0' plant code corresponded to ?! Was that US then ? But why not use B like all the others ?! I am lost...
Was there ANOTHER manufacturing plant in the US ?!
It's about time I learn about it ! :-[
The 'B' prefix must have come later - I just looked at a few of my older ones (310, 310A, 506, 531A, 545B, 561A, 575s) and all have straight numeric serial numbers.  The 561B has a 'B' prefix, as do the 434 and 465B at a glance.  FWIW.
-Pat
Good Day,
that's easy. This Type 515 simply predates Tektronix' international sites, i.e. the locations in Heerenveen/The NL or in Guernsey/Channel Islands See https://w140.com/tekwiki/wiki/Category:Tektronix_buildings
Cheers,
THDplusN_bad
« Reply #111731 on: January 20, 2022, 12:32:49 pm »
no no no it can't be.   my WAN
...No idea who is giving the IPV6 and how... at least the two LANs are in different /64
 >:D
Dwagons are also not IPV6 compliant. We fight every gawddamn Mb of the way there and back... ;)
« Last Edit: January 20, 2022, 12:52:25 pm by mnementh »
« Reply #111732 on: January 20, 2022, 12:49:18 pm »
   Oi... spinning rust is sooooo slow... :palm:
Currently updating my old gaming rig (Athlon FX-8350 8-Core 4.0GHz/16GB DDR3-667/XFX RX580 Black Edition) which has been in the trailer unused for 2 years to the latest Win10...
I think I could post you a surplus SSD from work via boat and it'll arrive before your updates have finished. :D
« Last Edit: January 20, 2022, 12:52:01 pm by mnementh »
  • Country: jp
« Reply #111733 on: January 20, 2022, 01:09:05 pm »
Ooohh, it's so fast now. It boots into Windows 7 desktop in like 10 seconds flat. swoon
The following users thanked this post: mnementh, cyclin_al, tonyalbus
« Reply #111734 on: January 20, 2022, 01:40:27 pm »
<snip>
CIDR:           2600:6C00::/24
NetName:        CHTR-V6
NetHandle:      NET6-2600-6C00-1
Parent:         NET6-2600 (NET6-2600-1)
NetType:        Direct Allocation
OriginAS:       AS20115
Organization:   Charter Communications (CC04)
Yes, that address is a public v6 address too. And your prefix would be 2600:6c5e:4c7e:1300::/56
My cheat-sheet-app ("sipcalc" -- is on places like /usr/ports or an apt-get or in this case Homebrew) says:
Network range      - 2600:6c5e:4c7e:1300:0000:0000:0000:0000 -
                     2600:6c5e:4c7e:13ff:ffff:ffff:ffff:ffff
I have 2 off /48 blocks, one from Hurricane Electric, one from my colo provider. I'm moving away from the HE block because HE has such a horrible reputation that I get hit by Cloudflare dDoS protection and visual puzzles / CAPTCHAs all the time. Also, the block was once registered to a Russian software company, which means all GeoIP-lies are worse than usual. And that is some achievement.  But I'm going to keep the block, just not use it except for reserve connectivity.  A VRF will be implemented so I can separate routing out -- I've had some less than stellar results trying to push traffic from one of the blocks through the other transit. That ain't gonna work well..
« Reply #111735 on: January 20, 2022, 02:17:27 pm »
10 lb picnic roast. All sides seared and seasoned; the usual suspects play their usual role. ;)
Now on a bed of frozen stir-fry veggies (broccoli, carrots, green beans, sugar snap peas, water chestnuts, red bell peppers, onions) and in the oven at 275°Frankenfurter until the veggies start to cook. Then covered until core reaches 165° and finish uncovered to 170-180°.
*toddles off to build a BOM for home electrocution electrification*
« Last Edit: January 20, 2022, 02:31:02 pm by mnementh »
« Reply #111736 on: January 20, 2022, 02:29:35 pm »
Hmmm... has anyone heard from cyclin_al since he reported the septic pump incident...?  :scared:
EDIT: Pinged him via SMS; he got a reprieve from SWMBO in the form of "get the snow cleared so you're not keeping the neighbors up til 1AM". He says he now has a replacement pump on hand and is currently in the collecting tools and putting the boots to his own rearend stage.
*says a prayer for a fellow canuck up to his eyeballs in it*
« Last Edit: January 20, 2022, 02:47:55 pm by mnementh »
« Reply #111737 on: January 20, 2022, 05:57:36 pm »
*pokes TEA thread with a stick*
*returns to carving the Roast of Doom*
« Reply #111738 on: January 20, 2022, 06:12:17 pm »
Pokes back.  :P
So much on here while the good weather lasts....got the first 4 spits of rain in a month yesterday and proper rain coming next week.....the pastures and some water tanks badly need it.
Offline Saskia
« Reply #111739 on: January 20, 2022, 06:22:30 pm »
oh woe eeez meeee
 I stumbled across a Keysight N6700B ...
muuuuuust rezeeeeest
aaaarggghhhh, caught in the make-offer-event-horizon ...
tacker..hack..clacker
offer accepted ...
aaaarrrgllll
The following users thanked this post: Brumby, ch_scr, cyclin_al
« Reply #111740 on: January 20, 2022, 06:36:48 pm »
I was busy fixing something that wasn't broken. (my router config)
In other news: We've got covid, all of us. Am very happy that those eligible got our shots. No-one is beyond mancold/flu in seriousness. It feels like a bad case of season flu, so most likely is Omikron and not one of the old ones.
Currently hoping that my parents (who I met last this saturday, when we had, unbeknownst, the virus in the family.) will be able to cope. They have gotten their 3rd shot, and are very careful, so there is hope.
Edit: And the anti-vaxers go: "It's just like the virus targets us. Illuminati 5G indeed!"  (In Sweden, the data says that adults between 16 and 60 are 21,1 times more likely to end up in ICU if they get covid and aren't vaccinated.)
« Last Edit: January 20, 2022, 06:40:18 pm by mansaxel »
Offline Saskia
« Reply #111741 on: January 20, 2022, 06:40:06 pm »
GBS !
The following users thanked this post: mansaxel
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #111742 on: January 20, 2022, 07:11:23 pm »
FedEx has been juggling the HP 5340A.  The initial arrival date estimated by eBuy was this coming Monday, based on the fact that it was being shipped via ground.  Thing is, it's coming from New Jersey, basically a state-and-a-half away.  That night I got a notification it would arrive on Wednesday, perfectly reasonable if it was shipped immediately as NJ is normally an overnight for ground shipments, but I didn't seriously expect it would be that fast.  Of course, no joy yesterday.  Last night, another notification that it would instead arrive today popped up.
Now to the tracking history.
FedEx got their hands on it in Moonachie, NJ at around 1815 on Tuesday the 18th.
It was "picked up" in South Hackensack, NJ at 2000 on the 18th.
It arrived at South Hackensack, NJ at 1940 on the 19th (?? - did it take a ride to nowhere and back?)
It left South Hackensack at 2158 on the 19th.
It arrived in Middletown, CT at 0245 on the 20th (this morning)
At 0339 this morning, it was flagged with a delivery exception for an unreadable bar code label, which was allegedly replaced.
And there it sits, no further updates since.  Perhaps it will make it here tomorrow...  Shipping something from basically one state away shouldn't be this complicated.   :palm:
-Pat
« Last Edit: January 20, 2022, 07:13:15 pm by Cubdriver »
The following users thanked this post: mnementh, factory, cyclin_al
« Reply #111743 on: January 20, 2022, 07:16:10 pm »
GBS !
George Bernard Shaw?
Ginger Beer Shandy?
Giant Bowls of Spaghetti?
Gigantic Ball Sack?
The following users thanked this post: BU508A, mnementh, cyclin_al
« Reply #111744 on: January 20, 2022, 07:29:15 pm »
-Pat
I assume the 5340A came from AllTest? FedEx has always been very prompt to me. Overnight. And of course AllTest packed it to withstand a nuke.  :-+
« Reply #111745 on: January 20, 2022, 07:32:24 pm »
Wow, sorry to hear you've all got the dreaded bug. Hopefully as you stated it will be mild for all of you. I get my Moderna booster on 9 February. Had my 2nd shot on 30 August.
Offline Neomys Sapiens
« Reply #111746 on: January 20, 2022, 07:38:13 pm »
oh woe eeez meeee
offer accepted ...
aaaarrrgllll
See..I told you!
 ;D
« Reply #111747 on: January 20, 2022, 07:43:48 pm »
I was here but not here; napping while my Agilent U1401B warmed up in high ohms range over 4 hours or so for the purposes of the "Meters with low volts ohms range" thread.
« Reply #111748 on: January 20, 2022, 07:47:03 pm »
Goof of the week:
wtf do they use those power supplies for?
The following users thanked this post: Zucca, mnementh, ch_scr, mansaxel, cyclin_al
Online ch_scr
« Reply #111749 on: January 20, 2022, 07:50:04 pm »
Second OCXO board populated - works! Very fun to watch the two OCXO drift apart initially by fractional degrees on the multifunction counter with the help of the DMTD. On that front, Rev 3 was populated as well, but powerup will have to wait until tomorrow.
