As to having a coax or a screened cable, coming from the back of it, is that so bad?
Not "baaaad"... I mean just unpracticla and weird, having a coax looping from the back.... woud you find it convenient and natural to have every piece of TE in your lab, your scopes and generator and power supply and what not require you to plug the oupui cable at the back ?!
Power socket however, you only plug it once and you do'nt want it in the way, so every piece of TE, even vintage stuff (but Metrix it seems !
) have the power cable/socket at the back... seems obvious and natural to every manufacturer...
After all, you are talking about putting a IEC socket there to stop it from zapping you, I doubt that you would be able to mount it in the front where the old 2 pin socket is located
Well I guess one could make anything fit, with a big enough chainsaw !
But it wold look really too out of place... a BNC socket in comparison is much more acceptable... to me
Any way, its over to you, its yours, and you will have to live with what ever solution you come up with
Yes it's mine !
... and having a BNC at the front an IEC / power at the back is just like any scope ever made (but Metrix...) probably, so yes I could " live with that " just fine, just like everybody here lives just fine with the same setup and every piece of gear they have !
Why don't you try pushing one of these adapters you have into the antenna socket on that TV you have been given and see if it fits as tightly in that?
Hey good idea !
Result : fits perfectly !
Then I had another idea.... have that other piece of Metrix TE, that huge Wobulator boat anchor if you remember that one. It has many sockets, and comes with a little jumper cable so you can connect one socket to another, in order to setup the instrument properly. So, first I tried the adapter into all the sockets on that Wobulator : would never go in, hard as a rock.
Then I took the jumper cable and tried to shove into the RF generator... fits perfectly, both ends of the cable do !
So... does not look like tolerance issue... looks more like the size was 9.0mm back in the day when these were used for TE stuff, but 60 years later where they are only used for TV consumer stuff, they now make it 9.5mm instead, that is all... so it's a lost cause so... if I get bored of my hack sawed adapter one day, I guess next step is retrofit a BNC socket instead.... and you would won that one... you get a cookie... you want them with just chocolate chips, or hazelnut chunks as well mixed in ?!
I also note the refined / elaborate construction of the plugs of the jumper cable, see pic below. It's a 4 slit design, which measures exactly the same diameter as the socket (9mm), so again no tolerance issue there, and it has a circular spring/clip inside , towards the top, inside a little groove. Clever... the 4 slits let the plug deform a bit to get into the socket, but the spring keeps it from deforming too much. Makes for a more reliable contact. Someone was thinking and trying to get these crappy connectors as best they could make them.
