Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17492303 times)
0 Members and 95 Guests are viewing this topic.
« Reply #110550 on: January 06, 2022, 09:02:28 pm »
Hi everybody,
still not done moving. I will have the old flat empty sometime tomorrow and will need to do at least another 1000 miles to finish this feat. it's utterly exhausting and I don't know how many tons I lugged. worse yet, I just got note that someone wants to dump 3 pinball machines at my place which is currently suffering from an onslaught of moving boxes.
I currently don't have a computer so my posting activities are down to a minimum.
please bear with me and thank you for your concern.
Take care of yourself; don't top off all that hard work you've done getting fit with a shiny new back injury.
The following users thanked this post: Saskia
Offline factory
« Reply #110551 on: January 06, 2022, 09:06:22 pm »
In my collection I do have a HP 191A waveform scope
Cool. I've never seen hp waveform/vector scopes. Here, it always was Tek or Philips. Today, we've got some Harris, and the new SMPTE 2110 compatible Tek scopes. Which basically is "tcpdump" with a parser putting up a scope pic.
Probably not available outside the UK, but the BBC have a video of the North 3 outside broadcast truck in use, a lot more equipment was running, than was possible with the generator they were using at vintage vehicle shows.
Three of the Tek waveform monitors, the Tek vectorscope & their HP 191A TV waveform scope were in use, never seen the Racal 835 counter working.
Post production seemed to have a problem digitizing the tape too, or maybe they prefer oval dartboards.  :-DD
https://canvas-story.bbcrewind.co.uk/100objectsobtruck/
P.S. I don't think HP had a TV vectorscope in their product line, the TV waveform scope & a B/W TV picture monitor are the only ones I've heard of.
« Last Edit: January 06, 2022, 09:10:48 pm by factory »
« Reply #110552 on: January 06, 2022, 09:15:32 pm »
The dartboards at the BBC used to deform under the effect of all the BBC tea fumes from the canteen*.
*I used to have a friend who worked as a secretary at the BBC. If we were planning an evening out I'd meet her at the BBC and we'd eat in the canteen before going out. I can't comment on the infamous BBC tea as I never drank any, but the food was good for canteen food, and there was a self-service ice cream counter freezer like you'd find in a Baskin-Robins about 12 feet long.
« Reply #110553 on: January 06, 2022, 09:29:04 pm »
That looks fine to me, apart from the obvious horizontal error showing in the podium, the picture seems to have been upscaled too.
No, that's just an artifact of me taking a screenshot off a player on a 5K screen. My actual digitisation of it is 576p (so deinterlaced but not upscaled) but on my desktop screen that just happens to come out at 1656 pixels wide.
Sure the quality is OK, it's just by comparison with what one expects after looking at 1080p every day for years that what once seemed fine now seems rough.
The following users thanked this post: mnementh, factory
Offline factory
« Reply #110554 on: January 06, 2022, 09:36:38 pm »
If it has three separate DM8880N drivers, then I suspect one of those, other people have had them fail on the radio forum. Hopefully there is an equivalent that isn't made my National Semiconductor and is easy to find, but I doubt it.
If it's any use I do have a diagram for a Data-tech DPM (not quite the same) if it helps, would need scanning though, I have the DPM somewhere too.
And looking at your pics, the top PCB still has holes for the tubes of the older version, is it also made by Gralex?
Interesting - I hadn't noticed the holes for the nixie tube evacuation tips on the top board until you pointed it out.
The Panaplex meter was made by Gralex Industries of Farmingdale, NY, model 363BXC1A2S15; the HP part number is 1120-0621.
The nixie meter in the 432B was manufactured by Analogic of Wakefield, MA, model 2510-1B-1-RX-CX-A14; the HP part number is 1120-1526.
The Gralex layout board-wise is similar, but the interconnection scheme is much different.  The Wakefield nixie meter makes the connections between the top and bottom boards through the front board, but the Gralex meter uses the ribbon cable on the side to get signals from the upper and lower boards, and the front board is only connected to the bottom board.  Perhaps Gralex also made a nixie version that later evolved into the Panaplex-display units?  There seems to be a dearth of information on them online (at least that I can find).
-Pat
There seems to be some user manuals at least, for a couple of later Analogic DPM variants, Panaplex & LED;
https://elektrotanya.com/analogic_an2533_an2553_digital_panel_instrument_manual.pdf/download.html
LED only.
https://www.surplussales.com/Meters/pdf/mtr-an2570-1x1p.pdf
Another variant of the Gralex DPM here, but no manual.
https://groups.google.com/g/neonixie-l/c/KLm5kARZ25o
Will see if I can find my Data-tech DPM at the weekend for comparison.
« Reply #110555 on: January 06, 2022, 09:55:29 pm »
Went to unscrew the oven light in the kitchen; the lamp had failed after a pretty short service. As I tried to unscrew the clear glass cap over the lamp I suddenly had half the glass cap in my hand; the rest sat in the threads and would not come out. (A short discussion with a water pump pliers later, there was nothing else left to do but vac up the shards.) No wonder the lamp had broken if the integrity of the cap was compromised.  New cap, SEK 175 (about 16€). Also ordered a new disappearing knob for the function selector; the old one's been hanging on by a thread for some time. SEK 400. (about 38€ or so).  Bosch-Siemens Haushaltsgeräte are maybe not the highest possible quality, but their spare part service is second to none, if expensive.
« Reply #110556 on: January 06, 2022, 09:58:16 pm »
« Reply #110557 on: January 06, 2022, 10:00:26 pm »
To me a "disappearing knob" sounds like one that regularly ends up inside the dog/cat/toddler.
« Reply #110558 on: January 06, 2022, 10:19:04 pm »
Yes, the BBC staff were well catered for (pun intended), I've had many a lunch in the TV centre at Wood Lane with the engineers there and met a few celebrities as well.
Similar at ITV on the South Bank as well, I was there once with my boss to look at some problems they were having with lighting controls in a few offices not performing correctly. We were in a lift and who should step in, but Jim Rosenthal and he immediately called my name and started chatting to me like long a last brother. When we got out the building, my boss said to me who was that and how did he know you, I told him who he was, (he was clearly a bit jelly), but I never told him that I also knew his brother, and we used to work together and I also knew his mum.
Funny, but the boss never came out with me anymore after that event, so that was a real winner  :-DD :-DD
« Last Edit: January 06, 2022, 10:22:46 pm by Specmaster »
The following users thanked this post: THDplusN_bad
« Reply #110559 on: January 06, 2022, 10:22:55 pm »
Oh, the video showed just nicely here. As cramped as OB vehicles usually are, indeed. In the late 90s I installed the sound system in  4 different OB vans for a video production company. That was a learning experience, and it was the foundation of the broadcast knowledge I use to this day -- I was at the outset reasonably good with a soldering iron and behind a mixing desk, so what was required was taking that experience and move it into the different realm of TV production. One had to learn, and learn fast.
And, today I'd be hard pressed to perform the actions of contortion required to produce acceptable soldering joints at the back of a equipment frame in the sound room, reachable only via a hatch on the outside.  :-DD
« Reply #110560 on: January 06, 2022, 10:28:38 pm »
It normally is latched flush with the surface but can be pushed and then springs out, allowing operation. Once one's done with the ovenizing, and "off" is selected on the rotary, it can be pushed latched in again.  As long as the retainer that stops the spring pushing out from pushing it off too far is not broken it will stay in the panel. But the retainer breaks, and the knob falls out...
Offline tautech
« Reply #110561 on: January 06, 2022, 11:07:33 pm »
The SO asked for help with some gardening........who likes gardening !  :rant:
If it can't be done with a machine it's not worth doing !
By luck we were asked to babysit a baby digger while its owner went on holiday and it would be downright rude to have it go rusty from lack of use.  ;D
The following users thanked this post: med6753, wolfy007, cyclin_al
« Reply #110562 on: January 06, 2022, 11:25:39 pm »
While you're digging dirt we're supposed to get 4 inches plus of the white stuff tonight.
Offline tautech
« Reply #110563 on: January 06, 2022, 11:29:27 pm »
:horse: Gardening Mulch laddie not dirt.  :P
Offline Brumby
« Reply #110564 on: January 07, 2022, 12:47:39 am »
Give it time and it will become dirt.
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #110565 on: January 07, 2022, 01:12:37 am »
We got 2-3 inches yesterday. Time to go buy snow tires I guess..... Back to factory stock rims for a while.. How embarrassing...  :P
« Reply #110566 on: January 07, 2022, 02:20:49 am »
Back in the 1990's I worked at a company in Chelmsford (part of Marconi) who used to do the fit out of the OB vans for the BBC and also other companies around the world.
« Reply #110567 on: January 07, 2022, 02:22:42 am »
We had a few flurries yesterday morning, but nothing that settled.
« Reply #110568 on: January 07, 2022, 02:40:43 am »
Lines like that take me immediately back to the classic 1970s sequiter:
« Reply #110569 on: January 07, 2022, 02:45:56 am »
Yup. 3-6" here, and the threats of a snow day were made official a couple hours ago. I had to go out and get milk and some scrips for SWMBO in case we get snowed in for a day or two; when I got back I had to drive across the lawn so I could park behind the trailer, as we have to keep the street clear for snow plows.
Brrruce is gonna get some more white stuff on his tail tonight!
The following users thanked this post: Specmaster, cyclin_al
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #110570 on: January 07, 2022, 07:58:47 am »
*cries*
WTF happened to that?
Was at the bottom of a pallet. I'm guessing a forklift driver missed his turn.
Offline McBryce
« Reply #110571 on: January 07, 2022, 08:16:28 am »
EV's  :blah:  :blah:  :blah:
Take it here:
https://www.eevblog.com/forum/renewable-energy/
What have EV's got to do with Renewable energy? They're all charged from coal burning power stations!
McBryce.
Offline Ice-Tea
« Reply #110572 on: January 07, 2022, 08:56:41 am »
Nah, mine is charged mostly from my own solar and nuclear power. For the time being.
Also: that phrase reads as if I have my own nuclear power.  :-DD
Offline McBryce
« Reply #110573 on: January 07, 2022, 09:06:46 am »
On a forum where people own partical accelerators and mass spectrometers, that doesn't seem all that unreasonable.
McBryce.
The following users thanked this post: Ice-Tea, mnementh, Specmaster
« Reply #110574 on: January 07, 2022, 09:23:41 am »
McBryce.
Do you consider CRTs as partical accelerators?
