And the trains themselves. Here's a bit of sound from a Belgian AM62 EMU, recorded between the driver's cabin on the right and the control cabinet on the left:
https://aporee.org/maps/files/AM66.mp3
Speaking of which: does anyone have or could someone point me to an audio recording of a contactor engaging... the typical klonk and the buzz?
Let me work on it. I have a contactor in a project that is almost finished (and was almost finished last week, and was almost finished last month... and was almost finished a year ago).
Short version of the story:
I have rebuilt a control box of a spa (hot tub) using a contactor, relay and electro-mechanical switches even including bi-metalic strips.
The old box was 120V only with a 1.2kW heater element and safety elements were bypassed:
The new version is 120V for pump and controls and 240V 4.4 kW heater element with safety elements replaced:
The only thing left is to add labelling:
Long verson of the story:
The 8060A DMM was used in this project. You can see the RM564 in one of the photos; this Spa needs to be completed (among other things) before I can work on the RM564.
SWMBO found a cheap used Spa. It was actually fairly priced and a suitable type of spa for our property. Since I was already installing a free* used pool, adding this should not be a big deal (tm).
In reality, it has been a whole project unto itself.
Unfortunately, it became linked with building a deck during a lumber shortage.
Unfortunately, Murphy found plenty of opportunity.
- need to replace a cracked drain plug
- I now know where water
is most likely to WILL freeze in the pipes
- it needed 3 orders from DigiKey to get all the correct parts (with extras to get minimum orders for free shipping
SWMBO has also stated that it is required to have an alternate means of physical cleanliness (the spa) while I am doing renovations of the bathroom.
Renovations of the bathroom are required due to hard corrosive water corroding the plumbing fixtures; currently baths are prohibited and showers are worrisome (I have my work office directly below in the basement
