@Vince,
Nope, I am
not angry at all, and I would have thought that it was perfectly obvious that I and others here were just trying to give you the benefit of many years of experience. Back in the day, the vast array of plug / socket interfaces that we currently enjoy was not available. I have had frequency generators before, British made with coax sockets by Belling-Lee on them as standard, simply because that was all that was available at the time and spares were available in most electronic shops because they were in common use so replacing them was not an issue.
Parts, as we all know or should know, do become unobtainable and so sometimes compromises have to be made in order to return things to full functionality, and it was proving to be the same with your socket, so I was just advising you of other options that were open to you,
but as I have pointed out in the posts, those solutions also depend on what your desired end result was. It is your equipment, therefore your choice, plain and simple, its no skin off my nose is it
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
EDIT:
I have read your reply to menmenth, which was also not warranted, you really should read carefully what people are telling you and then make your own mind up about which you go with the advice given, it just that advice, not instructions.
