Keep doing that Vince as we all need pulling into line when laziness rears its head.
Oh and how's your garage coming along ?
It's coming along....
Got the steel reinforcements delivered, as well as a palette of concrete blocks I need to raise the foundations to where I need them to be.
Ordered a concrete mixer truck, poured the concrete, all 7m3 of it. Paid a bit extra to get the 13m long telescopic belt conveyor option. Makes life so much easier. Guy has a radio remote control with a joystick and can easily and accurately steer the concrete all along the trenches. Also paid a little extra and ordered the "super fluid" concrete formula (extra dose of thinner additive and fine gravel rather than coarse), as the EU norm allows. Was like soup. Along with the conveyor, made the job a breeze and the few friends I had hired for the day to spread the concrete with rakes, did not have much if anything at all to do. Soup spread nicely all by itself.
Interesting you use conveyors over there when all remotely placed concrete is pumped here although usually a special 10mm pump mix as few can pump 20mm aggregates.
Pump was not even considered as simply not necessary, conveyor is enough as you can see. Pump is also prohibitive anyway, so ruled out right there. Quote says 500 Euros for the pump, for 5m3 of concrete. But I had 7m3 so god knows how much more they would have charge for that.
Even the conveyor was a luxury, but at 150 Euros it was a luxury I could justify, as the other option, ie having the truck dump all the concrete at its feet/wheels.... did not appeal to me !
![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif)
So I made an effort and coughed for the conveyor.
Total bill 800 Euros of concrete + 150 for the conveyor, total 950 Euros.
Is the top on the foundation blocks to be FFL ?
I don't know what " FFL " means
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Google says it means in French "French Federation of Losers "...
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
What must you use over the earth between the footings under the floor slab ? Compacted aggregate then fines and a moisture membrane ?
Yes, a thick layer of 20mm gravel, 10cm minimum but as much as you can afford really. Then a bit of sand on top of it, to make the surface smooth enough to then lay a plastic membrane to keep moisture from contacting the slab and degrade it over time.
