Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18064734 times)
0 Members and 61 Guests are viewing this topic.
« Reply #107700 on: November 26, 2021, 05:22:41 pm »
Thats what me and my boys all thought, but its the same in Firefox, Edge and Chrome. I was wondering if it might be Windoze 10 related as I don't recall noticing that before downloading the Novemeber update.
Nope, also happens on OS X. Only tried on Chrome, but I suspect it is the web site that does it, nothing else. Aliexpress have done it for ages, so I suppose Ebay just figured they'd sell more if they did too.
Offline factory
« Reply #107701 on: November 26, 2021, 05:44:02 pm »
Did anyone here get the HP LogicDart that was in the PP aucton?
Didn't see that one, was it hidden amongst a pile of other TE? Did it make any less than the one on EPay last week?
Offline ch_scr
« Reply #107702 on: November 26, 2021, 05:45:53 pm »
Здравствуйте товарищ милливольтметр! https://www.ebay.co.uk/itm/175033826065
Oohh that's a special one, it says "Millivoltmeter". They usually say "Voltmeter", regarding of features, number of digits etc.
The seller has thankfully provided a high res shot of the schematics, now we can see, it's an AC-Millivoltmeter:
And look at that glory!
Fet input, mystery ic, opamp, transistor amplifier - it's even powered by a self-oscillating switch mode supply :popcorn:
No expense spared on that one!
In the bottom left of the display we can see some of the specs "0.1mV-300V 2.5% 20Hz-1MHz B3-55A"
2.5% is a bit of a bummer, but I'll guess there is a good chance it is still in spec...
The following users thanked this post: mnementh, capt bullshot, cyclin_al
« Reply #107703 on: November 26, 2021, 05:57:47 pm »
Doh It was Ramco not PP.  :palm: I wasn't able to watch either auction end.
« Reply #107704 on: November 26, 2021, 06:07:50 pm »
Not heard of this manufacturer before, no doubt Robert, Cerebus, or tggzzz can elucidate: https://www.ebay.co.uk/itm/224708780108
Not me.
Someone's going to have fun with that mains cable.
Nor me. The S+E logo vaguely rings a bell, but only a tiny handbell; that means I've seen it before but I can't add any useful information beyond that.
Found this: https://www.radiomuseum.org/dsp_hersteller_detail.cfm?company_id=12221
Yes, best known for their big reel to reel instrumentation tape recorders. I think the recorders were the main reason EMI bought them. The recorders were still in active use in the aviation industry well in to the 1990's. I know one company that only destroyed their archive 1" tapes around 2015. The tapes probably outlived the aircraft whose data was on them.
Ah! Now instead of C8 handbell I think I'm getting G6. Yes, I think I can remember seeing S+E tape machines rack mounted for data logging or telephone logging.
7000 recorder
https://drive.google.com/file/d/1vSLl92J68OgTXttoL2nugCa_MGHp0d3w/view
Seems Penny and Giles took them over from EMI.
Their recorders were used for early "digital" (recording was FM) audio work at Abby Road Studios
It says "portable". For Geff Capes maybe. Damm things are at least 43kg (95 lbs). They are a awkward shape / size too.
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #107705 on: November 26, 2021, 06:07:57 pm »
No. But I tried :D
« Reply #107706 on: November 26, 2021, 06:19:44 pm »
Cool, I haven't seen a chess computer for years. I used to have one, but cannot remember what happened to it  :palm:
Did you pawn it? You should rook in the attic, it knight be there. You really should check, mate.
The following users thanked this post: Vince, med6753, mnementh, Specmaster, ch_scr, cyclin_al
« Reply #107707 on: November 26, 2021, 06:20:48 pm »
"Used" Spectrum Analyser fro ProAvit on ebay
www.ebay.co.uk/itm/255248173936
 :palm:
They can keep it  :-DD
"cables have been cut on the internals " :-DD
"Oh fer cryin' in the mud; that's the one I stomped to bits, then rubbed my balls all over it..."
"...to make sure nobody would ever touch it again. And somebody still dug it out of the dirt to sell online..."
The following users thanked this post: Per Hansson
« Reply #107708 on: November 26, 2021, 06:25:32 pm »
This has to be the oldest Solartron I've seen so far: https://www.ebay.co.uk/itm/334232124623
Hmmmmm... I do believe I see 3DP spacers made to refit that with modern output terminals and color coding. While I personally couldn't care less, it does set off the ol' anachronism detector something fierce...  :o
Another thought... do we really know if that was even made by the same Solartron we know & love for their "special" connectors...?
no  :popcorn:  for me...
Yes. https://www.radiomuseum.org/dsp_hersteller_detail.cfm?company_id=8231
« Reply #107709 on: November 26, 2021, 06:27:38 pm »
7000 recorder
Huh.... that's actually quite a interesting bit of dinosaur tech right there. Thanks for bringing it to light in here!
 :-/O
« Last Edit: November 26, 2021, 07:28:24 pm by mnementh »
« Reply #107710 on: November 26, 2021, 06:29:02 pm »
Hey Med, is that mess in the scope not just sawdust ?
Maybe it is, maybe it isn't. Who the freak knows until I start cleaning. But it DOES stink so I suspect more than "just" sawdust.
Some woods do stink as you know but the smell is normally lost after a while as sawdust. Maybe a rat pee'd on the scope and it soaked some in to retain the stink.
Anyways it's probably been stored in a small workshop to get such a coating of dust.....I'm sure it will be just fine Med.
If you think that's bad you should have seen the state of aircooled avionics equipment back in the days when they allowed smoking on aircraft....
If you think that's bad, you should try rummaging around for truck-cab components in an inch of green liquid charitably described as "decomposing animal proteins". I can still remember the smell, and that was more than 30 years ago...
Offline cyclin_al
  • VE3TSD / VA2XAR
« Reply #107711 on: November 26, 2021, 06:34:02 pm »
I don't even want to touch that.  :scared: The fate of this Type 547 is sealed. Parts unit only and will never be brought inside. I'll vacuum it out as best I can. I don't even want to speculate how all that crap got in there but you can bet rodent pee and crap is mixed in with it. Yuck.  :o :o :wtf:
That does not look as bad as you describe.  I do not see anything that looks like rodent poop.  What I see looks more like sawdust, so I am inclined to suspect a gorilla, rather than a rodent.  Rodent piss tends to cause rapid corrosion, which I do not see evidence of either.
For example, I left a box with my nail guns in the kennel a couple of weeks ago.  A mouse got in and chewed up all the styrofoam and ruined the box.  The mouse piss destroyed the racks of nails, there was little left of the nails.  Yep, in weeks it was as bad as an exposed nail outdoors for 20+ years.  Luckily, the nail guns themselves were spared.
« Reply #107712 on: November 26, 2021, 06:34:18 pm »
2.5% over that bandwidth and voltage range is pretty impressive imo. It looks to be in great condition too, but the price is too salty for me, given I'm not a wobbly-pointy meter licker.
« Reply #107713 on: November 26, 2021, 06:35:21 pm »
Did anybody get that voltage divider or even know how much it went for, I forgot to bid on it  :palm:
Offline ch_scr
« Reply #107714 on: November 26, 2021, 06:47:18 pm »
The price is too damn high for sure! Also, look at the sheer size of that damn case - which reminds me:
"How do you know the KGB has bugged your bedroom? You come home to find an additional wardrobe..."
The following users thanked this post: mnementh, Specmaster, Neomys Sapiens, AVGresponding
« Reply #107715 on: November 26, 2021, 06:48:32 pm »
"I... I... I just can't... There isn't enough stockpile to mount an appropriate response; I'd have to import boatloads of soggy ol' boots from England, just to lob them all back across the pond..." :o
Offline factory
« Reply #107716 on: November 26, 2021, 06:54:26 pm »
You guys need to tell me your user names in the future. I don't really want to bid against you if I can avoid it.  :palm:
Mine, yours and David's aren't difficult to work out :) Glad you got lots of 7151s :)
Mine is easy to work out, but "factory" on it's own was already taken.
All that RIFA (Schaffner) madness smoke just waiting to be released.  :-DD
And he got some of the old Fluke calibrators, just keep them away from Zhoefler.
Not me, the KVD went for £55.
https://www2.ppauctions.com/lot/161450/lot-202
« Last Edit: November 27, 2021, 02:35:15 pm by factory »
« Reply #107717 on: November 26, 2021, 06:58:21 pm »
Just goofing around here. Giving that repaired Type 1A1 some burn-in and a good workout. 10MHz square wave on a 50MHz B/W scope and plug-in as verified on the 7260A. Sweep on scope max'ed out and set to X5 mag. Not too shabby.  :-+
The following users thanked this post: Vince, mnementh, Specmaster, ch_scr, cyclin_al, AVGresponding
« Reply #107718 on: November 26, 2021, 07:05:29 pm »
Heh! You should talk shop with my wife; been years since she got her last fix of Bell Choir... ;)
Offline Ice-Tea
« Reply #107719 on: November 26, 2021, 07:33:41 pm »
Yeah, I think I may have cost you a fair bit and vice versa.  :-\
« Reply #107720 on: November 26, 2021, 07:36:41 pm »
Another Solartron 7081 from UK.   https://www.ebay.com/itm/284541597525
Look like crap and it's already more than what I would be willing to pay. Too bad, shipping to Canada was actually acceptable  :)
Christ... couldn't even be arsed to run a damp rag across it.  :o
Yup... that's been one of my laments for as long as I can remember. While I have gotten some good deals as a result, I've also gotten stuff that wasn't worth even that little bit of assache...  :-//
 :horse:
« Reply #107721 on: November 26, 2021, 07:38:36 pm »
I make no apologies.
In this pad, buns and bad puns are King and Queen, and you bishop remember it!
« Reply #107722 on: November 26, 2021, 07:51:07 pm »
Oh, and the stupidly cheap GenRad LCR arrived. It's currently toasting off the seasonal delivery condensation by the fire. I'll give it a poke with the mains in a bit.
Weighed in a small quantity of offcuts today, sandwich money for all the team next week...
Snow is forecast in 10 minutes. Quattro says: "meh."
« Reply #107723 on: November 26, 2021, 08:01:37 pm »
Ugh, I've been behind a knackers truck on the road before. You can still smell them miles after you have passed.
Offline factory
« Reply #107724 on: November 26, 2021, 08:06:04 pm »
Looks to be a newer version of the SRS153 here;
https://www.vintage-radio.net/forum/showthread.php?t=160377
The terminals might be replacements but I doubt the spacers are 3DP, but they are fairly old too, probably the sort RS components used to sell.
Note: these are unregulated PSU's.
More history of Solartron here;
https://www.gracesguide.co.uk/Solartron_Electronic_Group
« Last Edit: November 26, 2021, 08:25:11 pm by factory »
The following users thanked this post: cyclin_al, AVGresponding
