The RV55 has arrived. In one piece, and visually good condition. Nothing seems broken, no transport damage. Happy.
Also: The instrument is bleeping enormous. Compare to the 8060 -- I thought I was lucky getting a large instrument on my -hp- 400H (which was, at the time, marketed as having a larger display than its elder brethren). This easily is 35-40% larger than the 400h. Gorgeous in every way. No internal pics yet; I literally took it out of the package and switched it on. (It gets quite cozy.)
It unfortunately reads only about 90% of actual value. The TT-15 puts out 1030mV 1KHz according to the 8060, but as you see, that only shows up as 900mV on the RV55. I'll parallel the meters to check it's not loading the Fostex, though. It should not; it's a 1MΩ input impedance instrument, but the TT-15 is not the highest quality source available, so while trust might be good, it's surpassed by control...
