A friend paid a visit this evening, surprise gift, the board for his heat pump. It misbehaved, service tech swapped it and didn't even take the old board with him... so now it's mine !
Lots of good stuff on here...
- 3 big ass chokes/line filters
- 10 mains rated film caps
- A fuse, you can never have too many fuses
- A PTC
- Two MOVs
- 4 cute little 3A OMRON relays
- One big ass 30A relay, that's the big black "cube" on the RHS. From a distance at first I mistook it for a molded mains transformer, but no, it's a huge relay. 30A is a lot but still, looks oversized to me... but I am no relay engineer so must be a reason for its deluxe size...
- A 4 way DIP switch
- 10 Rubycon caps including a biggish 100V 470uF
- 3 power resistors including 2 big ones, 5W and 15W in a weird package similar to that of old electrolytic filter can caps... cylindrical, tall, skinny, radial/vertical, with a single terminal in the center and 3 "ground" pins on the outer ring. First time I see this type of package and foot print used for anything other than a can cap... you live and learn, that's cool....
- A couple opto-couplers.
- A big ferrite bead on the earth wires
- A TO220 7805 regulator.
- A Neon bulb between earth and neutral it looks like.
- A few SOT23 trannies
I am not complaining !!!
