Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17489826 times)
0 Members and 83 Guests are viewing this topic.
Offline Brumby
« Reply #104475 on: October 12, 2021, 09:13:53 am »
Oh ... wait ...  ::)
Offline dl6lr
« Reply #104476 on: October 12, 2021, 09:23:34 am »
It's not just AVO that made meters without a range switch, here's one from Weston; https://www.ebay.com/itm/265188323058
I've seen Shango066 using a larger VOM similar to this in some of his resurrection videos.
In the seventies those analog multimeters from Italy called microtest80 and similar were very popular. See Reply #853 https://www.eevblog.com/forum/chat/show-your-multimeter!/850/
« Last Edit: October 12, 2021, 09:31:23 am by dl6lr »
Online tggzzz
« Reply #104477 on: October 12, 2021, 09:42:33 am »
NewsThump is an excellent satirical site which rapidly parodies real news stories.
Usually it is sufficient merely to read the URL, but in this case the picture is relevant.
https://newsthump.com/2021/10/12/blue-origin-crew-concerned-by-new-uniforms-ahead-of-shatner-space-flight/
The following users thanked this post: BU508A, mnementh, Andrew_Debbie, cyclin_al, dl6lr
Offline dl6lr
« Reply #104478 on: October 12, 2021, 10:29:05 am »
Got the -hp- nixie counter from eBay for the minimum bid. So now have to decide wether to collect or let em ship:
1295680-0
The following users thanked this post: Vince, Cubdriver, factory, cyclin_al
Offline GreyWoolfe
  • NW0LF
« Reply #104479 on: October 12, 2021, 11:07:53 am »
computer for daughter is finished, tested, and works. Received a Demolition Man pinball cpu board, some vias eaten away, but should be fixable. Also, finally back at size 18 and 30 kg weight shed.
Good job, are you still going for a size 14?
Yes. will take me another 20 - 30 kg. Just about 5 cm belly away from a size 16 Levi 550. Working on it. New clothes will deplete my TEA budget significantly ...
Congrats on the weight loss.  I am down 39.5 kilos myself.  don't blow the budget on clothing now.  We didn't.  I picked up 4 pairs of dress pants for work, company provides company shirts.  1 dress shirt, a couple of t-shirts as I still have some of my old baggy shirts for around the house, a pair of dress shorts as I only wear long pants for work, a few pairs of knock around shorts a a single pack of underwear.  Yea, we do laundry more often now but pants are still expensive when you are a size 50 and weigh 135 kilos.  I am also not above going to thrift stores to save money.  We will add to my empty side of the closet with I hit goal, hopefully around 86 kilos.  Keep the clothes count down for now so you have more money for TE!!
The following users thanked this post: mnementh, Saskia
Offline Neper
« Reply #104480 on: October 12, 2021, 11:15:02 am »
Anyway, experimented a bit. At first even with 60Volts (the two floating output wired in series) I could not light it up, zero light, zero current flowing, nada, dead. So I thought OK see, the LED string in there is open circuit, it's dead that's all. Then as I wasfiddling with the panel, suddenly I saw a very brief flash of white light !
Reminds me of Mr. C., our old physics teacher in advanced physics, a two-hour event per lesson. All would begin with him setting up some electrical experiment. On switching on, nothing would happen. Lots of murmuring and head scratching. Then, he cranked up the voltage. Still nothing. More murmuring. Reversion of polarity. Bang, flash, smoke.
"Assuming the experiment had succeeded, we would have measured something like the following values." And we'd be spending the rest of the two hours watching him do endless calculations on the blackboard while everybody slowly fell asleep.
Things got really exciting with gas discharge experiments which he preferred to do in bright daylight, so he had to run them at several times the usual voltage to be visible while the whole class was sitting in the rearmost two rows of seats behind a wall of book bags.
« Last Edit: October 12, 2021, 04:28:46 pm by Neper »
The following users thanked this post: Vince, capt bullshot, ch_scr, cyclin_al
« Reply #104481 on: October 12, 2021, 11:35:20 am »
Congrats, both of you.  :-+
I'm afraid to step on the scale at this point. I can see a difference in my face and legs after a month on hard Keto, but the shorts are still snug fresh from the wash, so I know I need to step up my activity level. Almost done moving...
*no popcorn for me*
« Reply #104482 on: October 12, 2021, 11:41:38 am »
hmm, wait, was that the piss in a sack or the ouch, can't lift nutting ...
just taking the piss out of you :P
The hernia was the can't lift nuthin but also contributed, but wasn't total cause, for piss in the sack. It's complicated but happy to report that everything in that department is normal now.  :-DD
Oh... she sed nutting, not de-nutting:phew:
and since we're sharing...
« Reply #104483 on: October 12, 2021, 11:57:52 am »
Someone interested in a used Keithley 2002 (NAWTS)?
Only 14851 Euro.  :o
 :-DD  :-DD  :-DD  :-DD  :-DD
https://www.ebay.com/itm/185100991675
Offline capt bullshot
« Reply #104484 on: October 12, 2021, 12:13:34 pm »
Ladies and Gentlemen of the T. E. A.
May I ask for your attention, please!
As you have might noticed, I've been in a rabbit hole for a while. Most probably I haven't found the exit yet.
But let me present a summary of this beginners journey through the world of timenuttery.
May I ask you to follow these links (first page contains links to all other ones):
http://wunderkis.de/tnfb/index.html
http://wunderkis.de/tnfb/fdif1.html
http://wunderkis.de/tnfb/fdif2.html
http://wunderkis.de/tnfb/dmtd.html
Thank you for your attention.
Offline FransW
« Reply #104485 on: October 12, 2021, 12:33:11 pm »
Around 10∧(-30) s to the final target.
Regards,
Frans
PE1CCN, Systems Engineering, HP, Philips, TEK, BRYMAN, Fluke, Keithley
« Reply #104486 on: October 12, 2021, 12:38:52 pm »
Wow, Cap'n... I knew you had taken a deep-dive on this project; had no idea how deep.  ;)
No wonder it took you weeks; had to come back up slowly to keep from getting the bends.  :-DD
Well-played!  :clap:
I still don't know what time it is...  :o
Online tggzzz
« Reply #104487 on: October 12, 2021, 01:27:52 pm »
Maybe you'll want to upgrade to a MAC SA5*, where "mac" means "minature atomic clock". It is a rubidium atomic clock you can mount on a PCB.  >:D
http://ww1.microchip.com/downloads/en/DeviceDoc/Miniature-Atomic-Clock-MAC-SA5X-Users-Guide-DS50002938A.pdf
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #104488 on: October 12, 2021, 01:41:55 pm »
...or,  for the  really PRO TEA guys, there is a CSAC (chip scale atomic clock, but in Caesium instead of Rb) from the same manufacturer.
Great stability, but phase noise is awful.
« Last Edit: October 12, 2021, 04:27:22 pm by Wolfgang »
« Reply #104489 on: October 12, 2021, 02:06:34 pm »
https://octopart.com/990-00123-000-microsemi-58698750
Dev Kit is only US$962!!! :-DD
I don't think atoms care what time it is... and if they do, they already know on a quantum level... :o
« Last Edit: October 12, 2021, 02:13:12 pm by mnementh »
The following users thanked this post: FransW
« Reply #104490 on: October 12, 2021, 02:35:08 pm »
Just a wee tad more expensive then one of these.  :P :P :-DD :-DD
The following users thanked this post: mnementh, Specmaster, FransW
« Reply #104491 on: October 12, 2021, 02:41:18 pm »
NewsThump is an excellent satirical site which rapidly parodies real news stories. Usually it is sufficient merely to read the URL, but in this case the picture is relevant.
« Last Edit: October 22, 2021, 05:31:34 pm by mnementh »
Offline Saskia
« Reply #104492 on: October 12, 2021, 02:50:40 pm »
Heads up for all German members...
The German Institute for Broadcast Technology (IRT) in Munich is being disbanded which in itself is a shame and a sin but there's nothing we can do about it. They're currently auctioning off all of its assets, mostly office furniture and computer/network equipment but also various electronics and TE. The list includes things like Rohde & Schwarz ADS with a starting bid of 200 euros, HP Universal Counter, Modell 5314 A, various decoders, encoders and analyzers, a Tektronixs (sic!) 2430 scope starting at 50 euros, Weller WECP 20, 3D printers, Rohde 6 Schwarz FSQ8, CMW500, Tektronix TDS 724A, Audio Precision System One +DSP, Rhode & Schwarz SAF... over 1800 items.
https://www.reich-bayern.de/de/objekte/au-116/liquidationsversteigerung_der_irt_institut_fuer_rundfunktechnik_gmbh_teil_2_-_ha?Lstatus=1
Do note: +18% fee, +19% VAT, no shipping, bidder collects.
they have a lot of interesting Equipment but with the taxes and fees it gets  expensive
placed a couple of bids ...
The following users thanked this post: ch_scr, Neper
Online nfmax
« Reply #104493 on: October 12, 2021, 03:46:48 pm »
Just diagnosed a dead woofer in one of the Rogers LS4a speakers in my dining room. I bought these second hand 25 years ago. Tested with my Gould J3B audio signal generator, which I bought second hand more like 30 years ago. It doesn't get out much these days, but it does have a built-in very low impedance output that can put 3VRMS into typical speaker loads. The ideal TE for this particular job!
I found a replacement woofer on eBay - let's hope it works...
The following users thanked this post: mnementh, Specmaster, ch_scr, Neper
Offline Saskia
« Reply #104494 on: October 12, 2021, 04:30:49 pm »
Tek 2430 any good ?
Offline Neper
« Reply #104495 on: October 12, 2021, 04:33:21 pm »
Someone working their way through the looong list at the IRT auction, I see...  :)
« Last Edit: October 12, 2021, 04:38:07 pm by Neper »
Offline Neper
« Reply #104496 on: October 12, 2021, 04:36:25 pm »
We had Rogers speakers all over the place at BFBS Cologne, in the late 70's. Mostly driven by Quad power amps. I had a pair of LS3/5a in the O/B van. Fond memories...
The following users thanked this post: nfmax
« Reply #104497 on: October 12, 2021, 04:41:18 pm »
Tek 2430 any good ?
Yes dear. Decent scope. It's sort of an early hybrid analog/DSO. Have one. A few "gotchas". First, the NVRAM battery should be changed. I've done it and I can take you through the process. I also did a total re-cap of the PSU and again I can help with that. But one thing you should NEVER do is operate it outside the case for long periods. There are certain hybrid modules that will overheat and self destruct. Yes, found THAT out the hard way. That's the reason it has a large and somewhat noisy fan.
The following users thanked this post: Saskia
Online tggzzz
« Reply #104498 on: October 12, 2021, 04:42:41 pm »
I've got a couple of Rogers Studio 1 speakers, which are better than my ears now :(
Shortly I'm going to have to decide what to do with my father's Wharfedale Dovedale 3 speakers, which in some ways I prefer.
Offline factory
« Reply #104499 on: October 12, 2021, 04:56:45 pm »
Actually I quite like that version, does away with those pesky intermittent/dirty range switches you normally get.  :-+
