(1) Steering Wheel KEY 1
(2) Steering Wheel KEY 2
(11) CAN BUS TXD
(12) CAN BUS RXD
(14) BRAKE. I guess it means brake pedal...
(17) ILL ...like in "Illumination" / backlight ? I see that this wire goes straight to the external can bus decoder box...
(18) ACC ... accelerator ? They monitor the brake pedal so why not the Accelerator pedal ![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
(19) ANT .... "Antenna" I guess ? Power feed to extend a telescopic antenna ? Or power a roof mounted amplified antenna ?
(20) REVERSE : I guess it means reverse GEAR, probably used to automatically switch to the rear view camera video feed...
These will either go to two buttons, or to multiple buttons with a resistor network so each button press creates a different resistance that is read by the unit to know what button is pressed.
This may be a standard, or may be configurable in the unit for different car manufacturers.
(11) CAN BUS TXD
(12) CAN BUS RXD
Self explanatory. Some CAN bus stuff, not sure if it connects to the car's CAN bus, or to add-on modules.
I assume it connects to the brake switch or brake lights for some function.
Illumination, connect it to the wire that switches to +12V when you turn on the headlights.
It'll make the buttons light up, dim the screen etc for 'night mode'.
Accessories, Connect it to the wire that switches +12V when you turn the key to the first or 'ACC' accessory position.
A +12V output that activates when you turn the unit on to provide power for electric antennas/amplifiers/etc
You guessed correctly. Connect it to the reverse tail lights.
