Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17905536 times)
trackersoft and 24 Guests are viewing this topic.
Offline factory
« Reply #104300 on: October 08, 2021, 07:02:50 pm »
The second of the two crusty hp relics I bought a few weeks ago, the 3480B/3481A voltmeter, with option 004 (isolated BCD output).
Inside with shield cover removed from the 3841A plug-in and not much to see underneath.
Regulator board A1, with nice rusty RCA transistors and two internal layers, making it a four layer PCB, this board also contains the reference diode.
The clock & digital-to-analog memory logic board A2, no crystal reference for the clock of this DVM, just a simple transistor multivibrator and another early 1970's multilayer board.
TBC....
« Last Edit: October 08, 2021, 07:44:14 pm by factory »
Offline factory
« Reply #104301 on: October 08, 2021, 07:36:02 pm »
....Part 2 of the crusty hp 3480B/3481A voltmeter.
The polarity amplifier board A3, this board has space for the ratio option A3 A8 (might not be compatible with the option 004, I haven't checked).
And the digital-to-analog comparator board A4, with it's colorful selection of adjustment pots.
A few pictures of the mainboard A6, this has the power supply capacitors, display logic and a spare IC, well that's a first  :o. Also a pair of rusty legged TI 7475 IC's and the display decoders are regular 74 series with a hp part no. & not a custom part for a change. :-+
The last pair of boards are the option 004 isolated BCD output assembly A11, the manual mentions this can be used with the some hp 211x series computers and later on in the manual mentions use with a digital recorder, maybe it'll work with the 5055A (if I ever get found to checking/fixing it).
The isolation is pairs of inductors against that insulation strip between the boards.
These boards didn't want to come out, camera shy or hidden fixings??  :-DD
TBC....
« Last Edit: October 08, 2021, 09:41:55 pm by factory »
The following users thanked this post: xrunner, Vince, Cubdriver, BU508A, mnementh, Specmaster, capt bullshot, ch_scr, Kosmic, cyclin_al, Neper
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #104302 on: October 08, 2021, 08:24:51 pm »
Very cool.  I have it's brother, equipped with a 3485A Scanning Unit in my repair queue.  Interesting to see the innards, and the 3480 seems to be a pretty rare bird in my experience.
-Pat
Offline factory
« Reply #104303 on: October 08, 2021, 08:44:24 pm »
....Part 3 of the crusty hp 3480B/3481A voltmeter.
And finally the 3814A buffer amplifier plug-in, this seems to be quite an uncommon choice with only one range (10 volts), if fact there seems to be bugger all on the web, well apart from the catalog entry and the Jan 1971 Journal article; https://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1971-01.pdf
Unfortunately the plug-in didn't seem to want to come out, not sure why it's stuck and I don't want to break anything trying to force it out (the front & latching mechanism are plastic).
View from the top, with shield/cover removed, not much to see here.  :blah:
And the bottom cover removed, revealing quite a lot of transistors for a single range DVM plug-in, possibly making this set-up the largest digital panel voltmeter I've ever seen.  :-DD
The low serial number makes me think I'll struggle to find a service manual for it, possibly the third to leave the Scottish hp plant.
And a bit of testing after reassembly, oh dear my 4½ digit voltmeter has taken a downgrade to a 3½ digit DVM. :--
It zeros OK but seems to need some repair, as the 3.7V cell is reading a bit on the high side.
First things to check would be the PSU & +10V ref, then move on to a test plug (details in the crappy service manual from Agilent) to eliminate the plug-in, hopefully the fault is not with the plug-in.
This will have to wait, as I'm currently working on the 207A sweep oscillator.
« Last Edit: October 08, 2021, 08:47:02 pm by factory »
The following users thanked this post: xrunner, Cubdriver, BU508A, med6753, mnementh, Specmaster, ch_scr, Andrew_Debbie, cyclin_al
Offline factory
« Reply #104304 on: October 08, 2021, 09:03:11 pm »
-Pat
I've seen a couple of the 3485A scanner plug-ins in the past, probably a good choice for use with the 5055A recorder I have, they even supplied them as a set.
And you get lots of BD's favourite switches.  :-DD
Not seen a teardown as far as I know yet.
« Last Edit: October 08, 2021, 09:07:08 pm by factory »
Offline cyclin_al
  • VE3TSD / VA2XAR
« Reply #104305 on: October 08, 2021, 09:25:06 pm »
*currently gusseting a bedframe for my son*
Just put a bottle jack under it and be done ... that is what I did.
Although I do have my bedframe in the garage from a previous lifetime (before kid, before marriage), but her antiques count more ...
Sounds like you need to upgrade in the Nixie counter dept.
Yeah, now I need one that counts higher.  :-+
(in reality, I need to pull out that HP nixie counter and clean it up, and complete a lab so I have somewhere to put it)
Offline Cubdriver
  • Nixie addict
« Reply #104306 on: October 08, 2021, 09:45:56 pm »
Interesting - yours has a burr.  Mine is mid '71 engineering rev, (1127) US made.  00103 is definitely an early one!!
-Pat
« Reply #104307 on: October 08, 2021, 10:07:07 pm »
Dave has a D'oh! moment... guess he shoulda done the daveCAD before he pulled a " 'ere, 'old me Foster's an'n watch this!"
 :-DD
Offline tautech
« Reply #104308 on: October 08, 2021, 10:26:09 pm »
Yeah definitely amateur hour.  |O
Offline factory
« Reply #104309 on: October 08, 2021, 11:35:08 pm »
-Pat
S/N 00103 is for the 3481A plug-in , the mainframe is a lot higher.
« Reply #104310 on: October 09, 2021, 01:45:04 am »
Not one I have seen before (or have a NEED for >:D ) eBay auction: #324821359264
Looking at the single photo it will likely be out of the Yokogawa Hewlett Packard Japanese production and likely match the Decade Capacitor frame I have - nope still dont NEED it  :-DD
VK6 side of the country and some other HAMmy type gear listed as well.
The following users thanked this post: Vince, mnementh, factory
Offline Neomys Sapiens
« Reply #104311 on: October 09, 2021, 05:04:48 am »
So you have already an at least passable 600Ohm step attenuator?  :-//
« Reply #104312 on: October 09, 2021, 05:09:40 am »
Nope but I have 50 and 75  \$\Omega\$ step attenuators - still not bidding  :-DD
« Reply #104313 on: October 09, 2021, 06:05:46 am »
No discord today. Am off to do some powerboatin' with the Middle Boy:
Then with Minor Boy to a boy scout night in the forest.
Missed a 5245L to a sniper the other day. Still too few Nixie counters (1) in the shop.
Offline Cubdriver
  • Nixie addict
« Reply #104314 on: October 09, 2021, 06:24:18 am »
I popped the covers off and took some photos of mine (unbalanced version) earlier, but still need to upload and post them.  Neat little thing, and, unsurprisingly given its provenance, quite well built.
-Pat
« Reply #104315 on: October 09, 2021, 06:45:04 am »
Oh my, that is a sorry lot! You really, really need to do something about that! Although you might very well start with the impedance not covered at all,,,
« Reply #104316 on: October 09, 2021, 06:47:29 am »
 :-DD
Yep, saw that one the other day, just goes to show we all have our days when Murphy gets yeh  :-DD
« Reply #104317 on: October 09, 2021, 06:54:49 am »
At $5AU pesos for the pair or about 3 Euro I reckon I am still in front  ;)
Offline vk6zgo
« Reply #104318 on: October 09, 2021, 09:16:33 am »
Nah! my days of precision 600 Ohm measurement are long gone!
« Reply #104319 on: October 09, 2021, 09:40:31 am »
Carrots are healthy ergo those and my other Vegan Beer snacks tonight are healthy too as I have seen the data >:D
« Reply #104320 on: October 09, 2021, 09:58:45 am »
3 fried eggs, 4 local product breakfast sausage, huge cuppa coffee with 3 heavy cream : 4 grams carb, 630 kcal.
Also quite yummy, and jump-starts my heart. I'd post a pic, but it's all gone. :-DD
« Reply #104321 on: October 09, 2021, 10:02:09 am »
My spidey sense is telling me cooked via that method they are not all that healthy. It looks good which means that it ain't no good for you.  :-DD
Offline tautech
« Reply #104322 on: October 09, 2021, 10:05:35 am »
Healthy enough to get you out of the scratcher bright and shiny for Discord in the morning ?  :P
« Reply #104323 on: October 09, 2021, 10:30:42 am »
Depends 3am and 5am were last nights unscheduled awakenings I actually got some sleep circa Discord time this morning.  :palm:
« Reply #104324 on: October 09, 2021, 10:47:46 am »
Meh. Been all sorts of out of sorts the last week or so; too much to do, too little time... 4am-5am up & making breakfast... then a nap til 10 or noon has been the last couple nights.  :-//
whu-we-talkin'-abooot...? :=\
