Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16721666 times)
0 Members and 73 Guests are viewing this topic.
« Reply #102800 on: September 22, 2021, 02:09:42 pm »
I am no Zucca for sure ! For I can't tell a router from a smartphone, and the only Italian I know is limited to "Pizza" and "Lamboghini Diablo", that's not much !  :-DD
And "Bella ragazza" surely? As a Frenchman you have your national reputation "pour l'amour" to keep up.  :)
« Reply #102801 on: September 22, 2021, 02:10:11 pm »
Anybody is looking for a good old 26GHz VNA for 450$ ? Shipping might be a bit expensive though :)
https://www.ebay.com/itm/284461294599
This is sad but I don't think I have the place for a giant like that.
NOoooo run away.....
Two big issues, no RF source (needs a 8341A) and that big slot on the top right side marked "Tape"  :scared:
About the only bit of any value is the S parameter test set and even that needs major mods to work with other analysers.
Then there all the cables, calibration and verification kits.
You can do much better for les total outlay unless you really need ultimate performance.
The following users thanked this post: Specmaster, Kosmic
Offline Kosmic
« Reply #102802 on: September 22, 2021, 02:33:03 pm »
True about the source, this is a problem.
You can have it. I'm not interested anymore  ;D
« Reply #102803 on: September 22, 2021, 02:39:29 pm »
Personally I'm fond of my desk being tidy, also my house being tidy. However, both are signs that I have done nothing other than tidying. Tidy is a situation that lasts around me only for so long as I am not doing anything productive. Therefore I am deeply suspicious of anyone with a tidy desk or house, to my natural way of being it suggests that they have nothing productive to do.
No, tidy takes no effort nor waste of time if you put something back in it's place after you're done using rather than just tossing it aside for "later". And I have a specific schedule for "tidying" the place which wastes very little time. All it takes is discipline.
And as you can see by my project posts I am VERY productive.
« Reply #102804 on: September 22, 2021, 02:54:40 pm »
This is as "untidy" as it gets since I have 2 projects going on at once. The Type 547 occupying bench 2 which forced other equipment to the floor underneath. And the 212 in pieces on bench 1. This is a very rare event and not a normal occurrence and if I decided to clean it up within 10 minutes you'd never know it was this messy.
The following users thanked this post: ch_scr, cyclin_al
« Reply #102805 on: September 22, 2021, 03:06:46 pm »
I didn't say that it was de facto a sign of an unproductive person, just that to someone with my nature it makes me suspicious of apparently innate tidiness. Having a suspicion ought to be regarded as separate from judging, condemning and sentencing someone. One doesn't jump straight from the former to the latter unless one is an arsehole.
As to being generally suspicious of you personally. Well, you were the man who originated the eighty year old stripper thing. If that isn't grounds to at least cast a skeptical, "What's up with that fella?" sideways look at you, then I don't know what is.  :)
« Reply #102806 on: September 22, 2021, 03:11:42 pm »
...But in this video he simply substituted NiMH packs. I thought they had different charge requirements vs NiCad. Is that really a good idea without modifying the charge circuit?
In principle, yes... in practice, modern low-impedance and LSD NiMH AAs as sold for consumer use are amazingly abuse-tolerant and will serve for many years, as long as you get in the habit of fully discharging them and recharging them like once a month or so, and don't leave them on a constant trickle charge. I've swapped over to NiMH on oodles of RC transmitters and calculators over the last couple decades with zero change in the charge circuitry.
Alternately, could build a cheap 18650 pack with a cheap BMS PCB, but you'd need to add a CV/CC regulator set to 12.6V/~.5A in the charging circuit. That's what I did for the boi's BT speaker here:
https://www.eevblog.com/forum/3d-printing/3d-printer-yet/msg3566783/#msg3566783
Works a treat!
*juicy*
You know if they sell a board somewhere that include the charger and protection for lithium battery ? on aliexpress I only find protection boards
They are called a BMS board; provides charging/balancing/OVP/OCP/Over-discharge function. All you have to provide is a regulated charging voltage per the datasheet; usually Number of Cells x 4.2V + 0.5-2V or so. Oh, and make sure your charge supply is not grossly excessive current capacity for desired charge rate; while they usually do provide OCP in discharge mode, not always so in charge mode.
I bought assorted oodles of them at Banggood for $40 back when I started my eBike project.
 :-/O
Offline Vince
« Reply #102807 on: September 22, 2021, 03:23:06 pm »
"Bella" what ?!  ;D
No doesn't ring a bell at all sorry !  :-\
Don't care about national reputation !  ;D
We also have the reputation to be all sorts of negative things, should I also make sure they are all true ?!  ;D
Besides I am the antithesis of your typical French. By French standards I am an outsider, abnormal, the ugly duck... don't take any of what I might say or do as a reference, French people are NOT like me !   :-DD
Offline Kosmic
« Reply #102808 on: September 22, 2021, 03:27:17 pm »
Works a treat!
*juicy*
 :-/O
« Reply #102809 on: September 22, 2021, 03:37:58 pm »
212 first power up attempt. Installed jumpers which bypass batteries. Reassembled boards. Applied power. Nothing. Checked mains fuse. Is OK. Checked board connections. Are OK. Plugged in mains again. Got a snap and pop and a tiny smoke signal.   |O  Mains fuse didn't blow.
Guess I gotta study the schematic.  ::)
The following users thanked this post: xrunner, Vince, mnementh, Specmaster, capt bullshot, Neomys Sapiens, bd139, ch_scr, cyclin_al
« Reply #102810 on: September 22, 2021, 03:43:38 pm »
Well, that's easy to explain. Don't pussy foot around. Go for the throat. It's either "shock and awe" or fold your tent and go home.  :P :-DD
« Reply #102811 on: September 22, 2021, 03:54:54 pm »
Yes, well... Cerebus tends to be more of the "surgeon's scalpel and razor wit" camp; you tend more towards the "blunt force" approach.
Both have their pros and cons. ;)
Out. Standing. In my field.
Offline Zucca
  • EE meid in Itali
« Reply #102812 on: September 22, 2021, 03:56:29 pm »
A real italian talk sweet only 5%, the rest 95% is cussing.
Believe me no other language can compare to Italian for cussing....
The following users thanked this post: shakalnokturn
« Reply #102813 on: September 22, 2021, 04:00:11 pm »
Also a cheap HP 3457a with scanner card for 160$ on the bay
https://www.ebay.com/itm/124913065280
|O bloody shipping costs!
« Reply #102814 on: September 22, 2021, 04:07:46 pm »
A real italian talk sweet only 5%, the rest 95% is cussing.   Believe me no other language can compare to Italian for cussing....
I thought this was the generally accepted metric... aside from that guy who likes to "wipe his ahh-sss with silk"...?
Never do anything half-assed. Go whole-ass or stay home. ;)
« Last Edit: September 22, 2021, 04:13:47 pm by mnementh »
« Reply #102815 on: September 22, 2021, 04:14:26 pm »
Nice of you to say, but I suspect that I'm more notable for my pratfalls and encyclopaedic knowledge of perversions, fetishes and other paraphilias and tendency to spot the double entendre  potential for the latter in anything.
« Reply #102816 on: September 22, 2021, 04:16:15 pm »
I'm pretty certain that Arabic can give you a run for your money. But yes, Italian cussing is almost poetic.
« Reply #102817 on: September 22, 2021, 04:19:50 pm »
Well, that would explain this variant on the above meme which I just stumbled across...
I'm certain I'll have more than adequate exposure before too long...:o
« Reply #102818 on: September 22, 2021, 04:35:17 pm »
Says the guy who just said "para-feel-ya"... ;)
I like to think I fall in that camp; but honestly, more often I just fall...
« Last Edit: September 22, 2021, 04:37:08 pm by mnementh »
Offline tggzzz
« Reply #102819 on: September 22, 2021, 04:36:08 pm »
Oh hell... someone hide all my bank cards and hit me in the head before I do something foolish...
Current price is about the same as the cost of the Fischer connector (with a minumum order of £250, IIRC).
You just need to install some proper binding post. Not those Fischer rubbish :)
Vandals, the lot of 'em :)
The Fischer connectors are wonderful to handle; they ooze high precision engineering (as well as causing money to ooze from bank accounts).
Besides, I was just trying to be friendly and provide a disincentive to buying it. It has to be noted that your comments are more in keeping with TEA/GAS ethos!
You might be interested in this then (80$).
https://www.ebay.com/itm/234198036430
Fortunately I have two Fischer connectors; must make a cable for the second one sometime.
Offline Neomys Sapiens
« Reply #102820 on: September 22, 2021, 04:40:30 pm »
No need for such vocabulary. When a Frog approaches, only 'Mamma paffuta' remains in the open. The fleet-footed girls will have safely escaped.  :phew:
Offline tggzzz
« Reply #102821 on: September 22, 2021, 04:43:28 pm »
Here's an old photo to show how bad it can get here  :-DD
Bad? That's normal :(
The following users thanked this post: bd139, shakalnokturn
« Reply #102822 on: September 22, 2021, 04:44:00 pm »
That's all very clever but when dealing with Neanderthals like me the true meaning, be it an insult or whatever, may not be realized until sometime later when the light bulb comes on or you may be dealing with a burnt out light bulb. Blunt force is always so much more effective and satisfying and it leaves no doubt that you've been kicked in the nuts.
Offline nixiefreqq
« Reply #102823 on: September 22, 2021, 04:51:20 pm »
had a guy in vicenza yell at me once.   had to get a local to translate.  it came out:
"i piss in the milk of your mother."
had to think about it for a couple of days before i got mad.  (and even then it was still funny).
(didn't hemingway use that one too?)
free range primate
Offline Saskia
« Reply #102824 on: September 22, 2021, 04:51:29 pm »
A loaded gun on my table certainly helped improve my negotiation skills.  J/k  :-DD
In reply to med ...
« Last Edit: September 22, 2021, 04:53:02 pm by Saskia »
