Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17500121 times)
_rushin_or_draggin_, Runco990 and 124 Guests are viewing this topic.
« Reply #101950 on: September 15, 2021, 10:33:19 pm »
Beware! We had quite a few of these "always on" - after only a year a considerable number had gone bust; not only faded but missing lines and various glitches  :wtf:
In general, blue OLED have the shortest lifetime of the "phosphor", yellow has AFAIK the longest.
I was counting on that year but how about a few days?
It is my suspicion that these "super-cheap" AliEx OLED displays (and probably the driver chips on the FPC as well) are probably B or C or outright reject stock that were dumped by major producers as faulty or maybe too many bad per panel. Then the bottom feeders come and do the "playing the odds game" on how many faulty displays actually go out vs how many buyers can actually be arsed to hassle them for a replacement...
« Reply #101951 on: September 15, 2021, 10:40:49 pm »
@BD139
Just noticed that PCBWay are now offering transparent solder mask, and if I remember correctly you were looking for the same.
Ahha thanks for the heads up on that one. Much appreciated. I will run next order through them  :-+
« Reply #101952 on: September 15, 2021, 10:46:19 pm »
I think that's probably unnecessarily paranoid. The truth is that OLED just isn't 'there' yet for 24x7x365 operation. I've heard a lot of reports of OLEDs used in first tier equipment, like HPAK multimeters, that have exhibited short lifetimes relative to more mature display technologies, and that's without the stress of 24x7x365 operation.
The following users thanked this post: Specmaster, ch_scr
« Reply #101953 on: September 15, 2021, 10:54:53 pm »
I dunno... we use a lot of the cheapies with our RC tinkery. Things like FPV receivers and add-ons for our transmitters and even for debug on FCs when they're on the ground. Infant mortality rate is high enough we usually buy in lots of 3 or 5 to make sure we have at least one or 2 spares per project; and we often wind up needing them. EDITED to adjust overly broad generalizations.
I dunno... I used a lot of the cheapies with my RC tinkery. Things like FPV receivers and add-ons for my transmitters and even for debug on FCs when they're on the ground. Infant mortality rate was high enough I usually bought in lots of 3 or 5 to make sure I had at least one or 2 spares per project; and I sometimes wound up needing more than 1 spare. This was common enough that we did have discussions on it.
I gotta think that major manufacturers demand better and get better than that.
« Last Edit: September 15, 2021, 11:10:24 pm by mnementh »
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #101954 on: September 15, 2021, 11:09:03 pm »
I have more displays in my box-o-goodies, both OLED and LCD. The LCDs I have don't do graphics like this can though (which I will be utilizing). I didn't have another like the one that went bad, but I do have several smaller ones, 0.96", but with the same 64 x 128 pixels (SSD1306 controller). The top 16 rows of pixels are yellow and the rest blue. I have more work to show than you have seen, but all I needed to do was switch libraries, change a few lines of code, and they work the same with no changes in any scaling (but again they are too small now for my tastes).
I think I'll 3D print the enclosure for this display project so it sits under or on top of my GPSDO. I may yet still go with the OLED, I need to do some shopping. But if it fails - meh - I'll just port what I have over to some other graphics display and make another enclosure. It's not like it's mission critical stuff.  :)
« Reply #101955 on: September 15, 2021, 11:17:33 pm »
Of course the weather turned hot again so this boy is much grouchier than normal because it's hot and uncomfortable in here. So just for giggles I plugged in and turned on the window A/C. It has been running now for several hours with NO funny business. The control board is behaving and responding to commands. So apparently there is a very intermittent issue. When I pull it out in a few weeks I'm going to put it in the garage rather than in here in the closet so I have room to rip it down and see if I can get to the control board. Maybe I'll get lucky and it is nothing more than a leaky cap or perhaps a spider or two got in there.
After being on for about 4 hours the random function change and beeping has returned. But interestingly it does NOT change the function of the cooling unit itself. It's still running happily at the temperature initially set and providing cooling. So for now I'm just ignoring the random beeping because it's still hot/humid but comfortable in here.
« Reply #101956 on: September 15, 2021, 11:29:18 pm »
Yup. Have oodles of them in my junk in storage; just bought a 3-pack of that very display for my Circuit Python box a couple months ago. Plug-in SPI bus and cheap as chips makes it still cost effective even if you do have failures.
moo...?
Offline tautech
« Reply #101957 on: September 15, 2021, 11:32:46 pm »
Sounds like dying PSU caps for sure.
Our nearly 20yr old dishwasher started such BS a little while ago but power cycling seems to fix it for a while.
Old laser printer loses its USB and LAN connection too which I'll bet is bad PSU caps too which solves the riddle why PSU PCB's are available for them all over eBay.
Offline Vince
« Reply #101958 on: September 15, 2021, 11:45:55 pm »
Today's installment on the 575. Not much happened but hey, progressing none the less  :-//
https://www.eevblog.com/forum/repair/tektronix-type-575-curve-tracer-repair-and-restoration/msg3690901/#msg3690901
« Reply #101959 on: September 16, 2021, 12:03:08 am »
Oh I’m the sort of bastard who they should be scared of. Recently someone sent me a UPS package scam link by SMS. I contacted the one man shit box colo based in Iceland hosting it and they told me they only respond to local legal jurisdiction letters and to go away.
So they ended up getting “the wrath of having fuck loads of cheap VPS hosting credits” unleashed at them. I burned 13TB of my bandwidth quota before it melted the other end  :popcorn:. 20 nodes running “ab” 500 threads per node on their 1MB JavaScript hairball.
I bet that made up for not being able to execute those bastard caps yesterday, and brought a smile to your face then eh?
Online Kosmic
« Reply #101960 on: September 16, 2021, 12:09:24 am »
Talking about soldering iron, anybody know if the new T245 JBC Clone are any good ? Supposed to be 200W. I really doubt it.
https://www.aliexpress.com/item/1005002983155657.html
Edit: Was reviewed over here doesn't look bad.
« Last Edit: September 16, 2021, 12:42:03 am by Kosmic »
Offline 25 CPS
« Reply #101961 on: September 16, 2021, 01:23:02 am »
This came up in my Youtube feed:
Notice at the 4:07 mark what they've repurposed to hold the equipment on?
The following users thanked this post: Vince, mnementh, Specmaster, AVGresponding
Offline AaronLee
  • Country: kr
« Reply #101962 on: September 16, 2021, 04:08:27 am »
I give up. What is a system source device used for?
It's used to measure the depth of one's pockets.
The following users thanked this post: BU508A, mnementh, ch_scr
Offline Brumby
« Reply #101963 on: September 16, 2021, 04:35:52 am »
I thought that's what the Infiniium scopes were for.
Offline AaronLee
  • Country: kr
« Reply #101964 on: September 16, 2021, 04:42:05 am »
Infiniium scopes are, but in addition they also measure the level of insanity.
« Reply #101965 on: September 16, 2021, 05:45:21 am »
They might, but there were a lot of special carts made for broadcast too. For later versions of Slo-Mo we employed tape (Betacam or Digital Betacam, most of the time), coupled to a controller that looks pretty much like that one, minus the clock face; time was displayed using 7-segment LEDs. Remote connection was RS-422 using 9-pin D-sub and a protocol that IIRC comes from Sony. Now, we have HDD recorders, most of the time from EVS in Belgium. The only thing telling that they're not a tape machine from the rear is the PCI slots; the rest is covered in 75Ω BNC and XLRen.  The EVS remote handles, well, they look pretty much like that one, minus the clock face; time is displayed using a LC display. Remote connection is RS-422 using 9-pin D-sub and a protocol that IIRC comes from Sony. We've successfully built a TCP/IP remote solution using Moxa terminal servers...
Offline ch_scr
« Reply #101966 on: September 16, 2021, 06:52:17 am »
These units certainly are quite long at 460mm / 17½"
« Reply #101967 on: September 16, 2021, 07:35:31 am »
I bet that’s Chinese watts. They are like American gallons  :-DD
The following users thanked this post: RtBNL, mnementh
« Reply #101968 on: September 16, 2021, 07:37:20 am »
Annoyingly there’s no real satisfaction doing this due to the automation.
I do have a large bag of 1uF 25v capacitors here which I am considering stuffing across the mains though  :-DD
« Reply #101969 on: September 16, 2021, 08:13:03 am »
It proves we ain't stingy. Now here's a rope.  :P :-DD
Offline shakalnokturn
« Reply #101970 on: September 16, 2021, 08:36:22 am »
A few guidelines for your new project:
The following users thanked this post: mnementh, Mortymore, bd139, cyclin_al
Offline capt bullshot
« Reply #101971 on: September 16, 2021, 09:01:59 am »
Sometimes here (@work) serious stuff gets tested: figure a 400V 3phase supply, capable of delivering 100A or more, a 3ph bridge rectifier and a series/parallel combination of e.g. 820uF / 400V electrolytics. For testing, one of the electrolytics gets shorted. Nice boom happens a few line frequency cycles later, sometimes blowing the enclosure of the tested apparatus apart. As it is company confidential, I can't post videos of such fun, alas.
The following users thanked this post: Vince, BU508A, bd139, ch_scr, shakalnokturn, Kosmic, cyclin_al
« Reply #101972 on: September 16, 2021, 09:44:14 am »
Your company has consulted ElectroBOOM?  ;D
« Reply #101973 on: September 16, 2021, 09:50:17 am »
People here are about sane enough to not build a jacobs ladder from MOTs and then try to catch it with bare hands ;)
But anything else (like bureaucracy, management, ...), yes it looks like inside a madhouse, but can't tell apart who's a warden and who's an inmate. So acting like Mehdi or Andy would rather be a sign of sanity ;)
« Last Edit: September 16, 2021, 09:53:15 am by capt bullshot »
« Reply #101974 on: September 16, 2021, 09:53:47 am »
Hard to beat a lightning direct effects high energy test for deliberate electrical Ka-Boom with uncertain outcome.
The ultra high voltage attacnment and isolation tests look impressive but they don't blow the test item apart (and sometimes through the roof, literally) like the high energy tests.
Typically 3 parts to the applied test current. It starts with 200,000A for 500us with a 50us 10% to 90% rise time (3200A/us). Then 2,000A for 5ms followed by 200 coulombs in 0.25s to 1s at 200A to 800A.
First two are capacitor discharge, last was historically a big bank of commercial vehicle batteries but some people now use big DC power supplies.
The following users thanked this post: mnementh, capt bullshot, Neomys Sapiens, shakalnokturn, cyclin_al
