Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17743630 times)
Vince, wkb, ddrl46 and 79 Guests are viewing this topic.
« Reply #100550 on: September 06, 2021, 03:19:03 pm »
Maybe not perfect but anytime you think your DMM has enough digits or your measurements ore 'ok' watch a Robrenz video or two  :-+ :-+
I suspect his next video the curvature of the Earth will be considered to make his parts 'flat'  >:D
The one after that is "Space time curvature and the effect of milling machines on workpieces", to be followed by "Feeds and speeds: Heisenberg uncertainty considerations".
Backstepping slightly, it used to be so that large lathes (bed length > 10m or so) had to be erected using gravity-indeptendent surveying equipment. Machine shop spirit levels conform themselves to earth curvature, and as a result, the bed, if righted to a level, will be bent.
Offline dl6lr
« Reply #100551 on: September 06, 2021, 03:27:12 pm »
Oh hell, you are too fast. Missed page 4020 during night, so this too late...
It's never too late, delete your self a place back to page 4020, if you're lucky you may even be able to get yourself to 0.1M post and 4020 photo on the right page....
Don't forget to screen capture though, before this fashion fucks the universe's time continuum backwards!
In fact I was attempted to post more shit to get to page 4020 that evening. But I was too tired to wait until the page was reached as the progress was nearly zero...
Btw the forum software sucks on a phone...
« Reply #100552 on: September 06, 2021, 03:35:57 pm »
I've experience of reading Usenet using GUI readers and curses readers (FreeAgent, slrn), both capable of understanding
In-Reply-To:
and
References:
headers.  Compared to that, all forums suck. Regardless of platform.
« Reply #100553 on: September 06, 2021, 03:43:42 pm »
This is the reason I rotate my scopes to the test rack on a regular basis. I was going to put the Type 321A on test but when I powered it up I was greeted with this mess. No sweep. So today on the bench for troubleshooting.
I figured another one of the germanium 2N2207 transistors had gone tin whisker short so armed with nothing more than the 87 set to ohms went to work. And in 5 minutes found the problem. Q183 in the pix. That 2N2207 had a tin whisker short back when I first got the scope and was replaced by me. Well, I should have checked my solder work a little more closely. The top lead (emitter) cold solder joint and had pulled away from the terminal strip.  :palm: :palm: Do I kick myself in arse now or later?  :-DD Oh well.
Works great with good solder joints.  ::)
The following users thanked this post: Vince, Brumby, BU508A, mnementh, Specmaster, capt bullshot, bd139, factory, Kosmic, cyclin_al, syau, Neper
« Reply #100554 on: September 06, 2021, 03:47:12 pm »
I will give you a virtual kick up the arse from here  :-DD
Still need me one of those scopes  :-DD
« Reply #100555 on: September 06, 2021, 04:01:17 pm »
I try to minimize my time on these terminal strips because I'm using 60/40 and mixing it with the silver solder. So I ALWAYS give the joint a tug with needle nose to make sure it's secure. But as the law of Murphy states, the ONE time you don't it will come back and bite you in the arse.  :o
My arse hurts.  |O :P :-DD
« Last Edit: September 06, 2021, 04:03:28 pm by med6753 »
« Reply #100556 on: September 06, 2021, 04:04:55 pm »
In-Reply-To:
and
References:
Yeah, it's as if the directed acyclic graph is a data structure completely unknown to anyone who started writing software after about 1980.
The following users thanked this post: mansaxel
« Reply #100557 on: September 06, 2021, 04:07:42 pm »
Oh don’t get me started on algorithms and idiots. I found a DAG the other day which someone had created a cyclic dependency on in a rules engine and had the cheek to argue it with me. Feckin Russel Group comp sci grad should know better.
« Reply #100558 on: September 06, 2021, 04:17:29 pm »
There are 3 on US Ebay right now. Including one that was in a US Navy undersea program and LOOKS like it was under water.  :palm:
https://www.ebay.com/itm/133043285512?hash=item1ef9ff6e08:g:0RwAAOSwtkRcz14I
https://www.ebay.com/itm/203529515683?epid=1823713478&hash=item2f634df2a3:g:454AAOSw91Ng9L65
https://www.ebay.com/itm/133709947269?hash=item1f21bbe185:g:FzgAAOSwCmhgZCd6
And then we have this asshole. Who is he kidding?  ::)
https://www.ebay.com/itm/274561554260?_trkparms=ispr%3D1&hash=item3fed24d754:g:HDAAAOSw7GVfowLu&amdata=enc%3AAQAGAAACoPYe5NmHp%252B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSlHY%252FYTip4QFVjNQrCEJt6mQUNF%252FiC0yteVS9IjMG2X82Dba1AcOHBcAh7fcrZE8Xt%252B7EMKX04ldvw8Afjf1mHRRDObsBKe%252Bc%252F2Ur24rzm2jbw4V1p5URfaNAHLkE7cjw5zlVguYByUzaWw%252F41y6uzzutPO4mMLXEOoEFhHpirqlHIzMmRJ7%252BZStnJGzV7PV03H4l5sSW14OQewRl4lZJG5l28bcQv9UxECW47%252F8U%252FGEEOSqld5%252B%252FJ%252BxM0pzsnHvhTzci0WJfBsEtGgrhBhbtucJVUcpQcd8vxceV%252BHIpkvEJXKhFM%252FGFKcZ5WPpFLBA%252FOhuSydum20eggP97iyTK8BLdhwGN4MSpB4FtPXc%252B7HKZrCsxKF0ppJf%252BeKzJ%252BIXLNsQRh0TNFiBvVs4%252F6e6%252FSSIFj6mueB0Jh3q3qVRT0QyXcSv94azo8YV4NaRN%252Bysqcsh8o3mjM6UyQk6MSbY%252BKz%252F8N0IRDTMY4xtOFFvBHz2kN4hLTuT0748VCf32a6udIcBv4esuDGDL8QsCJci0Y2X%252F1k1ndhiCQZ9UcvRuvnwORsG970T77Jx11Xkieg2dWPSJl5X9n10AqstGq4e%252FPFPLZ81cXRGxQBWFopGIRw5DIIF6QhEH2N%252FLWLGLdMSkb9DwXN5jMwgRXcfewnJvjCaK9ETbpV5l8B%252B9JtDcRaQQHZACkMpHAtymBbXp2pPc0K6BwF%252Bs763sHCzp9D2vTCznLlx7kw%252FtlJMvzIR%252BnVRd4Uj0wIOz2%252FXy0Kr1yOE%252FUU8bQnJOnXltXjLPmZ8Vn%252FTMjzNxjLK%252B4uOObDg0pWWylhOyk25gIt9SuuaaCNkJviccEXDUDz%252FBC0MePiiw6g%253D%253D%7Campid%3APL_CLK%7Cclp%3A2334524
The following users thanked this post: Specmaster, factory
Offline Neomys Sapiens
« Reply #100559 on: September 06, 2021, 04:20:37 pm »
More plug ins from yesterday's haul:
And it had the cables/grabbers!
-Pat
Due to his module collection, Cubdriver is probably approaching a point where his answer to problems in any field of E/E technology will always be the same: I'll fetch my Tek7xxx!
« Reply #100560 on: September 06, 2021, 04:32:28 pm »
Wow that's quite a shit show if there ever was one.
I missed the last one here. It went for £55 working. Unfortunately I was stuck in hospital with my insides clogged up at the time  >:( :-DD
« Reply #100561 on: September 06, 2021, 04:34:25 pm »
Yes, the 100,000th post did go through several changes of occupancy and when things started settling down, it was my post that was found there.  To help reduce the tendency for rewriting history and because the collective desire for bitseeker to occupy that post had become rather remote, I sought to make a celebratory statement - hence this:
To celebrate this significant milestone - we direct our thanks (and all the blame) to the founder of this thread...
I trust there were some who appreciated that second image...
I did, but given the gold tolerance band, it could have been referring to any reply between 95,000 and (yes ok, most of these haven't been written yet) 105,000.
I will add oil on to the fire at this stage by pointing out that reply number 100,000 is post number 100,001 since the OP is un-numbered (0), and so technically the 100,000th post is reply number 99,999...
  :popcorn:
The following users thanked this post: shakalnokturn
« Reply #100562 on: September 06, 2021, 04:37:34 pm »
The detail for the US Navy one states that it works which I find hard to believe. Buy it.....and then get your money back when the magic smoke releases.  :P :-DD
« Reply #100563 on: September 06, 2021, 04:45:54 pm »
A few ebay picks, hopefully relevant:
These are not bad, if you like quirky old LED DMMs:
https://www.ebay.co.uk/itm/324778684908
Cheap for now:
https://www.ebay.co.uk/itm/324778699404
Donor for a card extender?:
https://www.ebay.co.uk/itm/393543461678
Somewhat salty price but at least open to offers:
https://www.ebay.co.uk/itm/114972553819
This better be full of unobtainium parts for this money:
https://www.ebay.co.uk/itm/265299452416
The following users thanked this post: mnementh, bd139, Andrew_Debbie, factory
« Reply #100564 on: September 06, 2021, 04:54:02 pm »
I'm mostly self-taught, so I most of the time don't know what name whoever put on whatever I'm doing, but have over the years amassed a pretty thorough habit of checking my work against at least some reasonable constraints.  My methods often are a tad crude, mostly in the interest of completeness, but they tend to work.  And I own my mistakes.
« Reply #100565 on: September 06, 2021, 05:03:43 pm »
Fuckers want £500 to ship it to Sweden. Fantasy-land, all over.
« Reply #100566 on: September 06, 2021, 05:10:07 pm »
It’s all garbage anyway.
Got the TDS2012 up. It’s rather less crap than the TBS.
The following users thanked this post: xrunner, mnementh, factory, Kosmic
« Reply #100567 on: September 06, 2021, 05:11:45 pm »
Cheap for now:
Wow, that is cheap. I fully expect that price to escalate to the stratosphere before that auction is over.  :o
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #100568 on: September 06, 2021, 05:15:14 pm »
A local ham has a whole garage full of that sort of parts stash. All from a bygone era. If he knows I'm working on a radio for another ham he always tells me if I need any parts to just let him know. I of course thank him, but nothing whatsoever in that garage would help me out.
But, if restoring an old vintage radio, sure there may be something I can use in there.
« Last Edit: September 06, 2021, 05:16:45 pm by xrunner »
Offline McBryce
« Reply #100569 on: September 06, 2021, 05:16:18 pm »
  :popcorn:
Oh, don't start the "Do you start counting from 0 or 1 discussion"!! That could be longer than this thread.
McBryce.
The following users thanked this post: Brumby, bitseeker, mnementh, AVGresponding
« Reply #100570 on: September 06, 2021, 05:21:52 pm »
Yeah there’s one of them round here. His wife left so he put up thousands of little drawers up all down his hall. All full of damp carbon composition resistors and stuff like that  :-DD
I’m dreading a relative kicking the bucket soon as he’s another one. There are boxes and boxes of tubes. Literally thousands of the things. I’m going in with a hit list and the rest goes to clearance.
Offline factory
« Reply #100571 on: September 06, 2021, 05:29:50 pm »
Guys, you're slacking
I was divided on whether I should post a 4018 or not.
McBryce.
Please don't double down on that joke!
Does no one actually have these parts? the last few all look snurched from other sites. I found a random PCB earlier and may/will post pictures on the appropriate page, or if I miss the page due to work, will post it anyway.  :horse:
As I do a lot of vintage computer repairs, yes, I have boxes of TTL and CMOS through-pin chips, I just couldn't be bothered looking for the correct part and photographing it when I can find a clear picture of one in seconds on the interwebs.
McBryce.
Here we are, one CD4023AE IC.
Edit: oops wrong picture, should have been this one.  :-DD
« Last Edit: September 06, 2021, 05:32:59 pm by factory »
The following users thanked this post: Vince, BU508A, bd139, shakalnokturn
« Reply #100572 on: September 06, 2021, 05:31:09 pm »
The loonies want £60 to ship within the UK! On something that would cost £5, tops.
« Reply #100573 on: September 06, 2021, 05:40:56 pm »
McBryce.
McBryce.
Sometimes it's therapeutic to powder stuff like that  :-DD
The following users thanked this post: mnementh, factory
Offline Andrew_Debbie
« Reply #100574 on: September 06, 2021, 05:58:54 pm »
Yup.   On my watch list.   Will bid if the price stays sane.
